#1 2022-04-21 11:57:45
draden
[SOLVED] How to auto-start an application during booting
I would like to enable the firewall (ufw) and also TOR on my system's startup (Chimaera). I found that i need to update rc.local and add the following:
    if [ -x /lib/ufw/ufw-init ]; then
    /lib/ufw/ufw-init start
    fi
Is that correct? Can someone help me how to configure these two process correctly? Also, openvpn auto-connect would be great. Now I am using cd /etc/openvpn sudo openvpn ....ovpn command in terminal.
Thanks!
#2 2022-04-21 12:46:58
Re: [SOLVED] How to auto-start an application during booting
I have done this.
Type in a console terminal... as root
 rc-update
you should get a list of services and their start-up status. like sysinit, default, off, recovery. (sorry it looks messy)
root@GlennsPref:/root  rc-update
           alsa-utils |                                              sysinit
              anacron |      default
         avahi-daemon |                        off
            bluetooth |      default
             bootlogd |                                              sysinit
             bootlogs |      default               recovery
          bootmisc.sh |                                              sysinit
           brightness |                                              sysinit
              cgroups |                                              sysinit
           checkfs.sh |                                              sysinit
 checkroot-bootclean.sh |                                              sysinit
         checkroot.sh |                                              sysinit
     clamav-freshclam |      default
     console-setup.sh |      default
                 cron |      default
                 dbus |      default
              elogind |      default
                eudev |                                              sysinit
                exim4 |                        off
             fail2ban |      default
            fwautorun |                                              sysinit
           fwlogwatch |      default
                  gpm |      default
              hddtemp |      default
          hostname.sh |                                              sysinit
           hwclock.sh |                                              sysinit
    keyboard-setup.sh |                                              sysinit
            killprocs |                            recovery
                 kmod |                                              sysinit
              lightdm |      default
           lm-sensors |                                              sysinit
       mount-configfs |                                              sysinit
 mountall-bootclean.sh |                                              sysinit
          mountall.sh |                                              sysinit
     mountdevsubfs.sh |                                              sysinit
       mountkernfs.sh |                                              sysinit
 mountnfs-bootclean.sh |                                              sysinit
          mountnfs.sh |                                              sysinit
       nethack-common |                        off
      network-manager |      default
           networking |                                              sysinit
             openntpd |      default
              privoxy |      default
               procps |                                              sysinit
 pulseaudio-enable-autospawn |      default           off
             rc.local |      default
            rmnologin |      default
                rsync |      default
              rsyslog |      default
            savecache |                        off
       screen-cleanup |                                              sysinit
             sendsigs |                        off
               single |                            recovery
                 slim |      default
                squid |      default
                  ssh |                        off
        stop-bootlogd |      default
 stop-bootlogd-single |                                              sysinit
                 sudo |                        off
              sysstat |      default
             umountfs |                        off
         umountnfs.sh |                        off
           umountroot |                        off
              urandom |                                              sysinit
           x11-common |                                              sysinit
                  xdm |      default
Also you can use this to see the status of the services.
service --status-all
root@GlennsPref:/root  service
Usage: service < option > | --status-all | [ service_name [ command | --full-restart ] ]
root@GlennsPref:/root  service --status-all
 [ ? ]  alsa-utils
 [ - ]  anacron
 [ - ]  avahi-daemon
 [ + ]  bluetooth
 [ + ]  bootlogd
 [ - ]  bootlogs
 [ - ]  bootmisc.sh
 [ - ]  brightness
 [ + ]  cgroups
 [ - ]  checkfs.sh
 [ - ]  checkroot-bootclean.sh
 [ - ]  checkroot.sh
 [ + ]  clamav-freshclam
 [ - ]  console-setup.sh
 [ + ]  cron
 [ + ]  dbus
 [ + ]  elogind
 [ + ]  eudev
 [ - ]  exim4
 [ + ]  fail2ban
 [ ? ]  fwautorun
 [ + ]  fwlog.sh
 [ - ]  fwlogwatch
 [ + ]  gpm
 [ - ]  hddtemp
 [ - ]  hostname.sh
 [ ? ]  hwclock.sh
 [ - ]  iwd.initd
 [ - ]  keyboard-setup.sh
 [ - ]  killprocs
 [ ? ]  kmod
 [ + ]  lightdm
 [ - ]  lm-sensors
 [ ? ]  mount-configfs
 [ - ]  mountall-bootclean.sh
 [ - ]  mountall.sh
 [ - ]  mountdevsubfs.sh
 [ - ]  mountkernfs.sh
 [ - ]  mountnfs-bootclean.sh
 [ - ]  mountnfs.sh
 [ - ]  nethack-common
 [ + ]  network-manager
 [ ? ]  networking
 [ - ]  openntpd
 [ + ]  privoxy
 [ - ]  procps
 [ - ]  pulseaudio-enable-autospawn
 [ - ]  rc.local
 [ - ]  rmnologin
 [ - ]  rsync
 [ + ]  rsyslog
 [ - ]  savecache
 [ - ]  screen-cleanup
 [ - ]  sendsigs
 [ - ]  slim
 [ + ]  squid
 [ - ]  ssh
 [ + ]  stop-bootlogd
 [ + ]  stop-bootlogd-single
 [ - ]  sudo
 [ - ]  sysstat
 [ - ]  umountfs
 [ - ]  umountnfs.sh
 [ - ]  umountroot
 [ - ]  urandom
 [ - ]  x11-common
 [ - ]  xdm
If your service is not listed to start you can add or del it from the list and run it, like this (for example)
rc-update add nftables default
rc-service nftables start
for the oposite, change add to del, and change start to stop.
I hope I got the question right, all the best. Glenn
#3 2022-04-21 22:48:03
MiyoLinux
I just run the following commands as root...
ufw default deny
ufw enable
After that second command, it shows a message saying that ufw is enabled and added to system startup.
...and you can check if it's  running with...
ufw status
