#1 2022-04-12 19:15:22
deepforest
help me please install FVWM95 on Ceres
Look at compiling process video
https://streamable.com/v84307
and installed dependencies packages txt
https://pastebin.com/raw/iWcVZach
smile
pyzNi 3.14zDa! smile
#2 2022-04-13 00:04:13
Re: help me please install FVWM95 on Ceres
Firstly, when building you should use "make |& tee LOG" so that all output is captured in LOG. That makes it possible to review it all in more details.
In this case you will need to find the "error: ..." lines to figure out what the main problems are. All the warnings should really be tended to as well, but they doesn't stop the compilation.
I mostly got missing include files and needed to install:
# apt-get install libx11-dev libxpm-dev libxext-dev libxt-dev xbitmaps libxmu-headers
plus a light manual touch to remove some misplaced "##", and
now it looks like the link recipe of the Makefile needs polishing as well.
#3 2022-04-18 13:09:32
deepforest
Hello! Sorry for late reply.
Already is installed
root@devuan:/usr/local/src/fvwm95---#  apt-get install libx11-dev libxpm-dev libxext-dev libxt-dev xbitmaps libxmu-headers
libx11-dev is already the newest version (2:1.7.5-1).
libxext-dev is already the newest version (2:1.3.4-1).
libxmu-headers is already the newest version (2:1.1.3-3).
libxpm-dev is already the newest version (1:3.5.12-1).
libxt-dev is already the newest version (1:1.2.1-1).
xbitmaps is already the newest version (1.1.1-2.1).
Here logs.
https://drive.google.com/drive/folders/ … sp=sharing
smile
#4 2022-04-18 22:09:38
You seem to have include file(s) in /usr/local/include that disturb the process. Maybe you can move them away somewhere and try again?
E.g, first error in LOG says
/usr/local/include/X11/Xlib.h:5:8: error: unknown type name ‘XFontStruct’
which is odd since XFontStruct is defined in /usr/include/XLib.h (line 1052) from libx11-dev=2:1.7.5-1
Therefore I'm guessing you have some remnants from trials/experimentations in /usr/local/include
EDIT: Thought to mention:
  • I downloaded fvwm95-2.0.43f.tar.gz and unpacked that into /usr/local/src/fvwm95-2.0.43f/ for building
  • ran ./configure, then make repeatedly while dealing with its errors, resulting in pulling in those libraries and some minor edits to:
    1. modules/FvwmIconMan/FvwmIconMan.c
    2. modules/FvwmScroll/GrabWindow.c
    3. modules/FvwmTaskBar/Goodies.c
With that it compiles (with lots of warnings) for me, and I don't know how well it runs.
#5 2022-04-20 17:58:43
deepforest
@ralph.ronnquist
Thank you very much! Now, after clearing  /usr/include/ its installs good.
But how now i can use it? When i do logout and press F1 on login Slim screen i do not see FVWM96 session.
Here my /home/freeartist/.xinitrc
DEFAULT_SESSION=startxfce4
case $1 in
lxqt)
exec startlxqt
xfce4|*)
exec startxfce4
mate)
exec startmate
fvwm95)
exec startfvwm95
#exec $DEFAULT_SESSION
esac
smile
#6 2022-04-20 20:29:32
xfce4|*)
So the second option is that "if the argument $1 matches xfce4 or matches * (aka anything), then use startxfce4". That makes the remaining ones mere decoration.
For sure you meant them to be in a different order.
#7 2022-04-21 14:08:26
deepforest
Apologies, my bad. When i set default FVWM95 i.e.
DEFAULT_SESSION=startfvwm95
case $1 in
lxqt)
exec startlxqt
xfce4)
exec startxfce4
mate)
exec startmate
fvwm95|*)
exec startfvwm95
esac
Nothing is happened. After reboot or change session, Slim not enter to fvwm95, Slim sty at login screen.
smile
#8 2022-04-21 16:05:32
deepforest
after xinit command
/usr/local/lib/X11/fvwm95/XClassTaskbar
not found
smile
#9 2022-04-22 06:50:46
Firstly, I have to assume that you prepared that startfvwm95 script/program to run the binary, which by default installs into /usr/local/bin/fvwm95. Probably fine.
Next you are obviously entering a software maintenance mode which involves fixing "bugs" in the software to adapt it to the current X11 environment, and that's not something I want to commit to be involved in. I see there is a readme file regarding FvwmTaskbar; possibly related.
Good luck.
#10 2022-04-23 15:23:08
deepforest
Its all "red eyed nerding" too complex for me:/
smile
