#1 2022-04-03 16:03:07
alex77
Android studio real in Devuan?
Hello. I would like to switch to Devuan as the main platform, but I need Android Studio. She needs Systemd. Are there solutions for Devuan?
#2 2022-04-03 22:51:04
Re: Android studio real in Devuan?
Normal downloading and installation works fine.
Which part is tainted with badness?
#3 2022-04-04 06:10:06
alex77
You used this? https://developer.android.com/studio#downloads
Bulding sources arhives, or instaling deb-pakardges,  https://developer.android.com/studio/archive
Im dont anderstend, Will this work in Devuan, that's why I'm asking.
#4 2022-04-04 06:19:15
You download that linux tar.gz, android-studio-2021.1.1.22-linux.tar.gz
un-tar it at your favourite place, then follow its instruction (to run studio.sh)
You can do all this as "normal user", i.e. you don't need to be root.
And then it'll keep downloading stuff .. some 6G maybe.
Seems to work fine (on chimaera).
#5 2022-04-04 06:23:12
alex77
Thank you! Your answer very help my.
