#1 2022-03-29 15:46:04
aleksa101
Restore panel
Hello. I wanted to remove a shortcut on a panel, but I deleted the entire panel. Friends tell me how to return the panel on the desktop, or how to create a new one?
#2 2022-03-29 17:10:32
Re: Restore panel
Via the menu .
Applications > Settings > Panel
#3 2022-03-29 17:21:10
aleksa101
Re: Restore panel
It doesn't work, it throws an error. Maybe there is a command to roll back this action?
#4 2022-03-29 18:08:36
Re: Restore panel
Have you tried logging out of the desktop and then log in again? I've deleted my panel a few times by accident. It always comes back on login.
If you're in the middle of something and can't log out, run xfce4-panel from the Run dialogue or from a terminal. You can get a Run dialogue with alt-F2.
#5 2022-03-29 18:12:50
aleksa101
Re: Restore panel
#6 2022-03-29 18:19:55
aleksa101
Re: Restore panel
I rebooted several times, but the problem was not solved. Now I will try to do as you say. Can you please tell me what is the best way to write a command for the terminal?
#7 2022-03-29 18:41:49
aleksa101
Re: Restore panel
Thanks, dear friend. Everything worked out!
#8 2022-03-29 20:48:58
Re: Restore panel
Glad you got it fixed. For future reference, those GDBus errors complaining about missing .service files are just noise from programs that expect you to be running systemd, even though they may not require it. I see them often when I start programs from a terminal.
