#1 2022-03-23 21:05:22
deepforest
[SOLVED] init: No inittab.d directory found during boot log
All works but i want to know what this message mean?
smile
pyzNi 3.14zDa! smile
#2 2022-03-24 14:35:54
Re: [SOLVED] init: No inittab.d directory found during boot log
The *.d directories are a place for the administrator to put customized configurations that will not be wiped out if a new version of the config file is installed/upgraded. Something is programmed to check for files in that directory, and it's letting you know that there's nothing there.
It should be safe to ignore. I don't have that directory on my chimaera or daedalus installations.
#3 2022-03-24 14:55:44
deepforest
Thanks foe reply!
What can i do that the this message doesn't appear? Or simply just ignore it?)
smile
#4 2022-03-24 17:16:14
mkdir /etc/inittab.d as root might get rid of the message.
What is the full text of the message? And what other messages came out at the same time? Those might tell us what is generating the message. Look for it in syslog, dmesg, boot.log etc.
#5 2022-03-30 20:20:03
deepforest
Thank you very much! After creation of dir "/etc/inittab.d" no any warning messages at booting)
smile
#6 2026-03-15 09:47:34
fscara
INIT: no inittab.d directory found
#7 2026-03-15 22:16:53
My box runs on Devuan Daedalus ...
~$ uname -a
Linux devuan 6.1.0-44-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.164-1 (2026-03-09) x86_64 GNU/Linux
... and I also get that printout in /var/log/syslog:
$ cat /var/log/syslog | grep inittab
Mar 15 04:08:48 localhost init: No inittab.d directory found
Mar 15 07:53:41 devuan init: No inittab.d directory found
Mar 15 10:10:50 devuan init: No inittab.d directory found
Mar 15 14:11:47 devuan init: No inittab.d directory found
That printout is not present in anywhere else.
ie: /boot, /debug, /kern.log, /messages or /user.log.
My system does not have a /etc/inittab.d directory but it is quite evident that some part of sysvinit routine is looking for it.
Indeed ...
See here: https://fossies.org/linux/sysvinit/src/init.c
I think the best is to create the directory and remove the warning from the log.
It has probably been removed from the Debian installation process because systemd does not need it.
But Devuan does not use systemd.
#8 2026-03-17 21:34:36
abower
This functionality got added in 2020 so it probably never was used in Debian as standard!
https://github.com/slicer69/sysvinit/co … fcf8740c49
I had been wondering if we should get it added (via Debian) by default to encourage its use for drop-ins rather than maintscripts editing /etc/inittab.
#9 2026-03-17 22:56:27
abower wrote:
... added in 2020 so it probably never was used in Debian ...
Yes ...
But sysvinit asks for it (see link) so it should be there.
abower wrote:
... wondering if we should get it added (via Debian) by default ...
Hmm ...
Added via Debian?
Something that is directly related to sysvinit?   8^D !!!
Right ...
You could try filing a bug against INIT: no inittab.d directory found with the Debian devs.
But you will not like the reply.
TL;DR:
Something along these lines ...
"On your way, mate. This is not a bug, sysvinit is not part of the default Debian configuration".
Eventually and only for completeness' sake, someone with the required knowledge could volunteer to write a small metapackage to do that.
If not, just add it manually and get rid on an unneeded warning in syslog.
#10 2026-03-17 23:57:02
abower
Hi Altoid,
I would not be so sure!
Watch this space: https://bugs.debian.org/1131137
#11 2026-03-18 00:05:09
tyder
Maybe one could just add a line to the default /etc/rc.local in the first place?
[ -d /etc/inittab.d ] || mkdir /etc/inittab.d
I use this mechanism for other 'non-default' directories that are useful or necessary for me.
#12 2026-03-18 00:07:44
Happened to me once and have seen it happen to others.
But things sometimes change.
And nothing is certain exept death and taxes.
abower wrote:
Waytogo !   8^)
Valiant effort, thanks for that.
Let's see what happens.
#13 2026-03-18 09:20:26
FM81
There is no need, to check again and again, if the directory exists.
Once you've created it (as described in post #4), everything is fine!
And all files /etc/inittab.d/*.tab will be included in INIT-process.
Best regards, FM_81
The most brilliant role in comedy is that of a fool, he must not be in order to make it seem. (Miguel de Cervantes)
#14 2026-03-18 20:04:39
abower
And lo, it was done.
Oh ye of little faith!
The message will be removed and documentation added in the next upstream release. Expect in Freia. :-)
#15 2026-03-18 21:29:51
The message will be removed and documentation added ...
As long as what was done was the right thing, good going.
Congratulations. 8^D
I would not know how to use /etc/inittab.d so will not opine any further than this:
- the warning existed because sysvinit was looking for the /etc/inittab.d directory and did not find it.
- the (to me) obvious solution was to fix the installer to create it at install time; optional or not, sysvinit was looking for it.
- if there was some issue as how the *.tab files worked or had to be written, add the corresponding documentation.
- I am not too sure it is the right solution because the problem was not the warning, in itself a consequence.
- (to me) problem was the /etc/inittab.d not being where it should have been which generated the warning.
The use of /etc/inittab.d is a feature of sysvinit, maybe very few use it, maybe not.
The solution has only obscured its existence, I only learnt about it because of the warning and fsmithred's post.
As always, just my $0.02
#16 2026-03-18 21:46:45
abower
Hi Altoid, I also only learned about it because of the warning, and it didn't escape my realisation that this was a blessing! However, it is a newish feature really something of value to packaging developers and it will now be covered by the man page, which I think is appropriate. Any package that wants a drop-in for this directory will implicitly create it, which is the normal way for directories in Debian, so I agree with the accepted resolution.
#17 2026-03-18 22:43:54
abower wrote:
... it will now be covered by the man page, which I think is appropriate.
Indeed it is.
Your doing.  8^D
abower wrote:
... wants a drop-in for this directory will implicitly create it, which is the normal way for directories in Debian ...
Well ...
Here's the thing.
Please correct me if I am wrong.
Debian uses systemd and Devuan uses sysvinit.
The /etc/inittab.d directory is directly related/of use to sysvinit and whoever puts *.tab files in it.
Unless I am mistaken, I understand that it is of no use to systemd (or Debian) because it is sysvinit-ware™.
ie: absolutely irrelevant to the systemd package, thus to Debian.
See https://github.com/systemd/systemd/releases/tag/v260
systemd v260 Release notes wrote:
* Support for System V service scripts has been removed. Please make
      sure to update your software *now* to include a native systemd unit
      file instead of a legacy System V script.
      The following components have been removed:
      • systemd-rc-local-generator and rc-local.service,
      • systemd-sysv-generator,
      • systemd-sysv-install (hook for systemctl enable/disable/is-enabled).
      The corresponding meson options '-Drc-local=', '-Dsysvinit-path=',
      and '-Dsysvrcnd-path=' are deprecated, and will be dropped in a future
      release.
That being the case, it stands to reason that no Debian package will have a need to create the /etc/inittab.d directory.
So under no circumstance will it be 'normal' for a Debian package to create it, simply because it is written for Debian, a systemd enabled distribution.
Odds are that if a package required the use of /etc/inittab.d, it would not be allowed in the Debian repositories.
Don't have much else to add save a 'thank you' for the interesting exchange of ideas.
#18 2026-03-19 14:20:45
tyder
Of course not. But when this is run once per booting, I think I have the computing resources to do that. Putting rests of configuration procedures into /etc/rc.local and editing it as necessary for new installs has saved me a lot of work over the years. Not the least having to remember this kind of details  ;-)
