#1 2022-03-13 23:23:07
Lorenzo
Runit: dbus runscript broken
Hi all,
Just a warning to runit init users, that the dbus runscript that I provided on this forum is now broken on Debian (at least for me) and I suspect the change will hit Devuan soon: synthoms are that dbus fails to start and everything that depends on it is broken (so your DE, login manager and other dbus services too will malfunction)
in short, if you are using a dbus runscript that has an exec line like
exec chpst -umessagebus dbus-daemon --system --nofork --nopidfile
I suggest to change it to
exec dbus-daemon --system --nofork --nopidfile
Using chpst seem to break recent version of dbus as it can't access to its own socket.
Dbus is able to drop privileges by itself.
Lorenzo
#2 2022-03-14 16:13:24
Re: Runit: dbus runscript broken
I am unable to reproduce the problem. I just upgraded my daedalus with runit. The dbus version went from 1.12.something+devuan3 to 1.14.0-1devuan1, and my desktop still comes up after a reboot. Looks like it's all working ok.
This line is still present in the runscript:
Running xfce with lightdm here. What would you like me to check?
#3 2022-03-14 17:04:04
Lorenzo
I'm still affected in Debian, not sure exactly if it's a change in dbus or something else. Devuan is rebuilding dbus without systemd bits, so maybe that's why it's not affected? (just a wild guess)
In any case dbus is dropping privileges and run with the messagebus by itself, so the 'chpst -umessagebus' is useless, but as long as it doesn't cause harm..
I'm with slim and LxQT. Not sure, as long as nobody complains, I'll just leave a warning here in case with a future upgrade things start to break.
Thanks
Lorenzo
#4 2022-03-14 18:03:19
xinomilo
Unknown
same with @fsmithred, unable to reproduce.
currently running lightdm & MATE on devuan ceres (sid), but mostly work with openbox.
dbus 1.14.0-1devuan1
runit 2.1.2-45
will also try with the suggested line on next reboot.
#5 2022-03-18 09:09:45
xinomilo
Unknown
no problems with openbox either, but changed runscript as proposed, no actual difference noticed. everything works as it did before.
