#1 2022-03-07 08:17:41
gdstew
[SOLVED] Dual monitor configuration
I have a HP Ryzen 7 laptop with HDMI output and I would like to use the second monitor as an extension of the laptop screen giving me a 3840 x 1080 display. The second monitor is detected but simply displays the same thing as the laptop monitor. Is there any setup configuration or any other way to make this work?
#2 2022-03-07 08:28:24
Andre4freedom
Re: [SOLVED] Dual monitor configuration
Hello,
you say nothing about your configuration: which desktop environment do you use?
There should be a "Display" configuration applet in you DE. open it, let it detect all displays and set each one up. Make sure to remove the option that mirrors display 1 and 2. It should be that...
Good luck.
#3 2022-03-07 14:32:38
gdstew
You are right. I have upgraded to Chimeara using Xfce. As stated the second display is detected and I have attempted to set it up but there does not appear to be an option to do what I want to do. I have tried a couple of options with no success.
#4 2022-03-07 21:30:26
The program is xrandr, on the command line.
First just
$ xrandr
so you can see what your monitor outlets are called.
Second some configuration adjustment, e.g. like:
$ xrandr --output $mon2 --auto --right-of $mon1
which would enable $mon2 in its default resolution and logically place it top aligned to the right of $mon1.
Use man xrandr for information.
#5 2022-03-07 23:04:34
gdstew
Thanks for the reply. I seem to be on the right track but a problem has cropped up. Here is the output from xrandr and the command you suggested:
:~$ xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
   1920x1080     59.98*+  39.98
   1680x1050     59.98
   1280x1024     59.98
   1440x900      59.98
   1280x800      59.98
   1280x720      59.98
   1024x768      59.98
   800x600       59.98
   640x480       59.98
HDMI-A-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 458mm x 258mm
   1920x1080     60.00*+
   1680x1050     59.88
   1600x900      60.00
   1280x1024     60.02
   1440x900      59.90
   1280x800      59.91
   1280x720      60.00
   1024x768      60.00
   800x600       60.32
   640x480       59.94
   720x400       70.08
:~$ xrandr --output HDMI-A-0 --auto --right-of "Screen 0:"
xrandr: cannot find output "Screen 0:"
:~$ xrandr --output HDMI-A-0 --auto --right-of Screen 0:
xrandr: unrecognized option '0:'
Try 'xrandr --help' for more information.
xrandr: cannot find output "Screen"
:~$ xrandr --output HDMI-A-0 --auto --right-of "Screen 0"
xrandr: cannot find output "Screen 0"
Any ideas?
#6 2022-03-08 02:30:06
The monitor outlets are eDP and HDMI-A-0
#7 2022-03-08 05:04:29
gdstew
Thanks once again, How did I miss that? OK, now it's this (sometimes It just doesn't want to work!):
:~# xrandr --output HDMI-A-0 --auto --right-of eDP
Can't open display
I tried rebooting and then running the command and it did the same thing.
#8 2022-03-08 05:49:27
Well, it operates on the current display, as known in the DISPLAY variable or given as command parameter, and it's typically run as the logged in user (not root) in a terminal window. I.e., open your terminal window and type the command there.
#9 2022-03-08 12:05:14
gdstew
Success!, THANK YOU!
