#1 2022-02-16 09:11:25
chomwitt
Unpredictable screensaver
Distro: Devuan GNU/Linux 5 (daedalus) (runit) Desktop: Xfce 4.16.0
Trying to figure out some unpredictable behavior on a fresh installation related among else  to screensaver (1)
i noticed that xsceensaver -systemd running . I wonder if that could create problems when systemd is not installed.
(1)
https://forum.xfce.org/viewtopic.php?pid=66137#p66137
Devuan(Chimaera)(Daedalus)  DS+WM: XorgX11server+StumpVM
#2 2022-02-16 12:37:45
hevidevi
Re: Unpredictable screensaver
in a terminal run
xscreensaver -demo
in a session.
then instead of xscreensaver -systemd run it as xscreensaver -no-splash in session settings or autostart or whatever starts xscreensaver. Logout and login etc etc.
#3 2022-02-16 14:23:17
It's xscreensaver-systemd and the manpage for it says:
The xscreensaver-systemd program is a helper program launched by xscreensaver(1) for systemd(1) or elogind(8) integration.  It does two things:
       * When the system is about to go to sleep (e.g., the laptop lid has just been closed) it locks the screen just  before  the  system  sleeps,  by  running  xscreensaver-command  -suspend.  When the system wakes up again, it runs xscreensaver-command -deactivate to make the  unlock  dialog  appear  immediately.   It  does  this  through  the org.freedesktop.login1(5) D-Bus interface.
       * When  another  process  on the system asks for the screen saver to be inhibited (e.g. because a video is playing) this program periodically runs xscreensaver-command -deactivate to keep the display un-blanked.  It does this until  the other program asks for it to stop, or exits.  It does this through the org.freedesktop.ScreenSaver(5) D-Bus interface.
#4 2022-02-18 06:49:19
chomwitt
Thanks for the reply.
