#1 2022-02-09 06:15:26
SpongeBOB
[SOLVED] date -s trigger animation ?
A short video thousandths of words -> https://sendvid.com/vdiyk5um
(if you know an opensource platform to share video, I'm all ears)
#2 2022-02-09 06:37:01
SpongeBOB
Re: [SOLVED] date -s trigger animation ?
Hoo I see what it is, it's just triggering the screensaver lol
So this is minor "bug", is there a place where to references them ? git etc. ?
#3 2022-02-09 06:42:02
xinomilo
Unknown
https://www.joinpeertube.org/
#4 2022-02-09 19:58:23
SpongeBOB
Thanks @xinomilo
#5 2022-02-10 15:47:54
I don't think so. If you're setting the time ahead by more than the timeout value for the screensaver then activation would be expected.
Why are you attempting to set the time manually? Can you not just install the ntp package and rely on the interweb instead?
#6 2022-02-11 08:04:12
SpongeBOB
Thanks HOAS, yes it make sense from a programing view. Anyway I think it could be possible to detect a manual change of the time and reset the counter for the screensaver, but this is being picky smile
Indeed, I generally use NTP ! but I just freshly installed Devuan on a VM and still building the firewall -> https://dev1galaxy.org/viewtopic.php?id=4876
off topic, Thanks to Devuan to fight for the Init Freedom ❤️
