#1 2022-02-04 01:52:01
torquebar
[SOLVED] message from the grub underworld
I'm not what you would call a knowlegable deb/dev user (yet, possibly for years to come)
I'm struggling with using 4 distros on alternating days, and to
prevent grub from stepping all over itself I usually limit grubwork
to my go2 distro which for now is Suse. I'm only saying this to
show where the following boot process began :-)
All the /etc/fstabs on all distros use only disk-by-uuid (since I
reluctantly gave up on the use of dev-names). This would suggest
(to me) that there is no reason why dev-names such as /dev/sda2
should ever appear in the said boot process involving any
installation.
YET, on maybe every 10th boot of Devuan up pops the
error shown in the snapshot (sorry, out of focus took with my kodak):
error pasted onto desktop
I *think* the source of the message is Devuan but I ain't sure.
Partitioning is as follows
(1 = Artix, 2=Devuan, 3=Slack, 4=Leap, 5=Tumbleweed)
Desktop deathstar primary 1tb ssd
Device          Start        End   Sectors  Size Type
/dev/sda1        2048  209717247 209715200  100G Linux filesystem
/dev/sda2   209717248  419432447 209715200  100G Linux filesystem
/dev/sda3   419432448  629147647 209715200  100G Linux filesystem
/dev/sda4   629147648  838862847 209715200  100G Linux filesystem
/dev/sda5   838862848 1048578047 209715200  100G Linux filesystem
/dev/sda6  1048578048 1258293247 209715200  100G Linux filesystem
/dev/sda7  1258293248 1468008447 209715200  100G Linux filesystem
/dev/sda8  1468008448 1677723647 209715200  100G Linux filesystem
/dev/sda9  1677723648 1887438847 209715200  100G Linux filesystem
/dev/sda10 1898948608 1907337215   8388608    4G Linux swap
/dev/sda11 1907337216 1909434367   2097152    1G BIOS boot
GPT PMBR size mismatch (1 != 7814037167) will be corrected by write.
All operational OS partitions are regularly backed up with dd so that
I'm not too worried but I would like to get rid of the nuisance, more
importantly maybe some Dev devs would also want to know
cheers
Edit: 2022-02-12
Since my OP I had successive failures and just now I had a double fauilure affecting
two separate installed oS'es on my g73
It does seem like NOT a Devuan issue at all, the other system
just now was Slackware; BOTH failed because /dev/hdb could
not be found. I should have checked how fdisk saw the disk-1
before doing the just previous grub routine, I had not. Interestingly
the Leap system from which the boot was set up booted fine so
that AGAIN does in it seems point to os-prober. So I next
booted into Leap again, this time I did check, the primary disk WAS
/dev/sda, repeated the boot ritual, and all went fine following.
As outlined before ONLY my Suse systems ever see the primary
drive as other than /dev/sda  ...this has to be "IT". At the time
I launch Yast to lay boot code the Leap system is all up. Is systemd
a factor in id-ing disks by dev-name?
Who, has loved us more?
#2 2022-02-04 18:28:12
Re: [SOLVED] message from the grub underworld
If you're dropped to an initramfs shell then I don't think /etc/fstab has been read. The problem must be with the GRUB configuration. Please share that here along with the output of lsblk -f. Thanks.
#3 2022-02-04 21:19:24
torquebar
# lsblk -f
NAME   FSTYPE FSVER LABEL         UUID                                 FSAVAIL FSUSE% MOUNTPOINT
sda
├─sda1 ext4   1.0                 25568ecc-3f4c-410d-8cfb-bb45afc10051
├─sda2 ext4   1.0   s1t4-dev      f203d9ec-a53c-4f33-ad2a-222cf8f8dbcd   24.3G    32% /
├─sda3 ext4   1.0                 c8bef1d4-9f78-4608-90a2-f79c58a4bf15
├─sda4 ext4   1.0   ssd250-4      b1a083e6-cf65-4ecf-8f2c-dfc604ab4672
├─sda5 ext4   1.0   ssd250-5      a49723a1-bc42-4b71-988c-5b50c7c8c7bc
├─sda6 ext4   1.0   ssd250-6-swap 6bfded0b-dd3e-49e3-bba5-6066b8cd7111
├─sda7 swap   1     250gb-7-swap  c1503ccd-60a2-4520-a917-e1155cfa8122                [SWAP]
└─sda8
sdb
└─sdb1 ext4   1.0   ssd1tbblk-1   71aa45cc-6665-4d53-bf9d-434055f2dd6c    583G    31% /0/dx
sr0
ignore the labels. they're unused residuals
What exactly can I supply under "grub configuration"?   I never opted
for the Dev installation to deploy boot code but I understand that when
Suse sets up the boot it does poll all grub configs (if that option
is checked). Since the cosy days of grub legacy I'm not familiar with
these new files totaling (their sum -1)  too many :-)
#4 2022-02-04 21:32:07
We need to see /boot/grub/grub.cfg from whichever system is controlling the bootloader. You claim this to be "Suse" (openSUSE?) in the OP but if you're not sure run the set command from the GRUB command line to see the configfile variable and it's location.
If that variable isn't listed and you're not sure which system is controlling the bootloader then install the boot-info-script package in Devuan and share the output of
/usr/sbin/bootinfoscript
The output will be lengthy so be sure to use code tags.
#5 2022-02-05 02:21:07
torquebar
I have 2 Suse systems Leap-15.3 and Tumbleweed, almost all boots are set up using the former (quoting the grub.cfg from Leap). Sometime the boot is set up from Tumbleweed, the two are probably quite similar but I can quote that one too if needed.
NB. I ran
apt-get dist-upgrade
earlier and got some cautionary remarks at the end about initramfs, could not duplicate just now because there is nothing to upgrade.  I also installed Slackware-15.0 which writes itself an fstab using dev-names. So before so much as the first boot I edited that fstab to show uuids then ran grub on Leap. The resulting boot of Slackware bombed with a kernel panic 'unable to mount root fs', second attempt was manual
set root=(hd0,3)
linux /boot/vmlinuz root=/dev/sda3
boot
and worked fine. THEN I ran grub from Tumbleweed and that worked fine too, with the menu this time.  My primary ssd always shows up as /dev/sda on Artix, Devuan, Slackware but sometimes as /dev/sdb on either Suse system and since this result is variable and so is the OP issue I suspect there might be a connection.
# DO NOT EDIT THIS FILE
# It is automatically generated by grub2-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -f ${config_directory}/grubenv ]; then
  load_env -f ${config_directory}/grubenv
elif [ -s $prefix/grubenv ]; then
  load_env
fi
if [ "${env_block}" ] ; then
  set env_block="(${root})${env_block}"
  export env_block
  load_env -f "${env_block}"
fi
if [ "${next_entry}" ] ; then
   set default="${next_entry}"
   set next_entry=
   save_env next_entry
     save_env -f "${env_block}" next_entry
   fi
   set boot_once=true
else
   set default="${saved_entry}"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
  menuentry_id_option="--id"
else
  menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z "${boot_once}" ]; then
    saved_entry="${chosen}"
      save_env -f "${env_block}" saved_entry
    else
    fi
  fi
function load_video {
  if [ x$feature_all_video_module = xy ]; then
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
terminal_input console
terminal_output console
if [ x${boot_once} = xtrue ]; then
  set timeout=0
elif [ x$feature_timeout_style = xy ] ; then
  set timeout_style=menu
  set timeout=99
# Fallback normal timeout code in case the timeout_style feature is
# unavailable.
else
  set timeout=99
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/00_tuned ###
set tuned_params=""
set tuned_initrd=""
### END /etc/grub.d/00_tuned ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'openSUSE Leap 15.3'  --class opensuse --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-043b32d4-9cea-4bf2-9a86-a21b4859b4f5' {
	load_video
	set gfxpayload=keep
	insmod gzio
	insmod part_gpt
	insmod ext2
	set root='hd0,gpt4'
	if [ x$feature_platform_search_hint = xy ]; then
	  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt4 --hint-efi=hd0,gpt4 --hint-baremetal=ahci0,gpt4 --hint='hd0,gpt4'  043b32d4-9cea-4bf2-9a86-a21b4859b4f5
	else
	  search --no-floppy --fs-uuid --set=root 043b32d4-9cea-4bf2-9a86-a21b4859b4f5
	fi
	echo	'Loading Linux 5.3.18-150300.59.43-preempt ...'
	linux	/boot/vmlinuz-5.3.18-150300.59.43-preempt root=UUID=043b32d4-9cea-4bf2-9a86-a21b4859b4f5  splash=silent quiet mitigations=auto
	echo	'Loading initial ramdisk ...'
	initrd	/boot/initrd-5.3.18-150300.59.43-preempt
submenu 'Advanced options for openSUSE Leap 15.3' --hotkey=1 $menuentry_id_option 'gnulinux-advanced-043b32d4-9cea-4bf2-9a86-a21b4859b4f5' {
	menuentry 'openSUSE Leap 15.3, with Linux 5.3.18-150300.59.43-preempt' --hotkey=2 --class opensuse --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.3.18-150300.59.43-preempt-advanced-043b32d4-9cea-4bf2-9a86-a21b4859b4f5' {
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt4'
		else
		fi
	menuentry 'openSUSE Leap 15.3, with Linux 5.3.18-150300.59.43-preempt (recovery mode)' --hotkey=3 --class opensuse --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.3.18-150300.59.43-preempt-recovery-043b32d4-9cea-4bf2-9a86-a21b4859b4f5' {
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt4'
		else
		fi
	menuentry 'openSUSE Leap 15.3, with Linux 5.3.18-150300.59.43-default'  --class opensuse --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.3.18-150300.59.43-default-advanced-043b32d4-9cea-4bf2-9a86-a21b4859b4f5' {
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt4'
		else
		fi
		echo	'Loading Linux 5.3.18-150300.59.43-default ...'
		linux	/boot/vmlinuz-5.3.18-150300.59.43-default root=UUID=043b32d4-9cea-4bf2-9a86-a21b4859b4f5  splash=silent quiet mitigations=auto
		initrd	/boot/initrd-5.3.18-150300.59.43-default
	menuentry 'openSUSE Leap 15.3, with Linux 5.3.18-150300.59.43-default (recovery mode)' --hotkey=1 --class opensuse --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.3.18-150300.59.43-default-recovery-043b32d4-9cea-4bf2-9a86-a21b4859b4f5' {
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt4'
		else
		fi
	menuentry 'openSUSE Leap 15.3, with Linux 5.3.18-59.37-preempt'  --class opensuse --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.3.18-59.37-preempt-advanced-043b32d4-9cea-4bf2-9a86-a21b4859b4f5' {
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt4'
		else
		fi
		echo	'Loading Linux 5.3.18-59.37-preempt ...'
		linux	/boot/vmlinuz-5.3.18-59.37-preempt root=UUID=043b32d4-9cea-4bf2-9a86-a21b4859b4f5  splash=silent quiet mitigations=auto
		initrd	/boot/initrd-5.3.18-59.37-preempt
	menuentry 'openSUSE Leap 15.3, with Linux 5.3.18-59.37-preempt (recovery mode)' --hotkey=1 --class opensuse --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.3.18-59.37-preempt-recovery-043b32d4-9cea-4bf2-9a86-a21b4859b4f5' {
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt4'
		else
		fi
	menuentry 'openSUSE Leap 15.3, with Linux 5.3.18-59.37-default'  --class opensuse --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.3.18-59.37-default-advanced-043b32d4-9cea-4bf2-9a86-a21b4859b4f5' {
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt4'
		else
		fi
		echo	'Loading Linux 5.3.18-59.37-default ...'
		linux	/boot/vmlinuz-5.3.18-59.37-default root=UUID=043b32d4-9cea-4bf2-9a86-a21b4859b4f5  splash=silent quiet mitigations=auto
		initrd	/boot/initrd-5.3.18-59.37-default
	menuentry 'openSUSE Leap 15.3, with Linux 5.3.18-59.37-default (recovery mode)' --hotkey=1 --class opensuse --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.3.18-59.37-default-recovery-043b32d4-9cea-4bf2-9a86-a21b4859b4f5' {
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt4'
		else
		fi
	menuentry 'openSUSE Leap 15.3, with Linux 5.3.18-8.13-rt'  --class opensuse --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.3.18-8.13-rt-advanced-043b32d4-9cea-4bf2-9a86-a21b4859b4f5' {
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt4'
		else
		fi
		echo	'Loading Linux 5.3.18-8.13-rt ...'
		linux	/boot/vmlinuz-5.3.18-8.13-rt root=UUID=043b32d4-9cea-4bf2-9a86-a21b4859b4f5  splash=silent quiet mitigations=auto
		initrd	/boot/initrd-5.3.18-8.13-rt
	menuentry 'openSUSE Leap 15.3, with Linux 5.3.18-8.13-rt (recovery mode)' --hotkey=1 --class opensuse --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.3.18-8.13-rt-recovery-043b32d4-9cea-4bf2-9a86-a21b4859b4f5' {
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt4'
		else
		fi
	menuentry 'openSUSE Leap 15.3, with Linux 5.3.18-8.10-rt'  --class opensuse --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.3.18-8.10-rt-advanced-043b32d4-9cea-4bf2-9a86-a21b4859b4f5' {
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt4'
		else
		fi
		echo	'Loading Linux 5.3.18-8.10-rt ...'
		linux	/boot/vmlinuz-5.3.18-8.10-rt root=UUID=043b32d4-9cea-4bf2-9a86-a21b4859b4f5  splash=silent quiet mitigations=auto
		initrd	/boot/initrd-5.3.18-8.10-rt
	menuentry 'openSUSE Leap 15.3, with Linux 5.3.18-8.10-rt (recovery mode)' --hotkey=1 --class opensuse --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.3.18-8.10-rt-recovery-043b32d4-9cea-4bf2-9a86-a21b4859b4f5' {
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt4'
		else
		fi
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry 'openSUSE Leap 15.3 Memtest' --class opensuse --class memtest86 --class gnu --class tools $menuentry_id_option 'memtest-043b32d4-9cea-4bf2-9a86-a21b4859b4f5' {
	insmod part_gpt
	insmod ext2
	set root='hd0,gpt4'
	else
	fi
	echo	'Loading memtest ...'
	linux16	/boot/memtest.bin
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Artix Linux (rolling) (on /dev/sda1)' --class artix --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-25568ecc-3f4c-410d-8cfb-bb45afc10051' {
	insmod part_gpt
	insmod ext2
	set root='hd0,gpt1'
	  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt1 --hint-efi=hd0,gpt1 --hint-baremetal=ahci0,gpt1 --hint='hd0,gpt1'  25568ecc-3f4c-410d-8cfb-bb45afc10051
	else
	  search --no-floppy --fs-uuid --set=root 25568ecc-3f4c-410d-8cfb-bb45afc10051
	fi
	linux /boot/vmlinuz-linux root=/dev/sda1
	initrd /boot/initramfs-linux.img
submenu 'Advanced options for Artix Linux (rolling) (on /dev/sda1)' $menuentry_id_option 'osprober-gnulinux-advanced-25568ecc-3f4c-410d-8cfb-bb45afc10051' {
	menuentry 'Artix Linux (rolling) (on /dev/sda1)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-linux--25568ecc-3f4c-410d-8cfb-bb45afc10051' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt1'
		else
		fi
menuentry 'Devuan GNU/Linux 4 (chimaera) (on /dev/sda2)' --class devuan --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-f203d9ec-a53c-4f33-ad2a-222cf8f8dbcd' {
	insmod part_gpt
	insmod ext2
	set root='hd0,gpt2'
	  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt2 --hint-efi=hd0,gpt2 --hint-baremetal=ahci0,gpt2 --hint='hd0,gpt2'  f203d9ec-a53c-4f33-ad2a-222cf8f8dbcd
	else
	  search --no-floppy --fs-uuid --set=root f203d9ec-a53c-4f33-ad2a-222cf8f8dbcd
	fi
	linux /vmlinuz root=/dev/sda2
	initrd /initrd.img
submenu 'Advanced options for Devuan GNU/Linux 4 (chimaera) (on /dev/sda2)' $menuentry_id_option 'osprober-gnulinux-advanced-f203d9ec-a53c-4f33-ad2a-222cf8f8dbcd' {
	menuentry 'Devuan GNU/Linux 4 (chimaera) (on /dev/sda2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz--f203d9ec-a53c-4f33-ad2a-222cf8f8dbcd' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
		initrd /initrd.img
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
		initrd /initrd.img
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
		initrd /initrd.img.old
	menuentry 'Devuan GNU/Linux 4 (chimaera) (on /dev/sda2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.19.0-12-amd64--f203d9ec-a53c-4f33-ad2a-222cf8f8dbcd' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
		linux /boot/vmlinuz-4.19.0-12-amd64 root=/dev/sda2
		initrd /boot/initrd.img-4.19.0-12-amd64
	menuentry 'Devuan GNU/Linux 4 (chimaera) (on /dev/sda2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.19.0-18-amd64--f203d9ec-a53c-4f33-ad2a-222cf8f8dbcd' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
		linux /boot/vmlinuz-4.19.0-18-amd64 root=/dev/sda2
		initrd /boot/initrd.img-4.19.0-18-amd64
	menuentry 'Devuan GNU/Linux 4 (chimaera) (on /dev/sda2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.19.0-9-amd64--f203d9ec-a53c-4f33-ad2a-222cf8f8dbcd' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
		linux /boot/vmlinuz-4.19.0-9-amd64 root=/dev/sda2
		initrd /boot/initrd.img-4.19.0-9-amd64
	menuentry 'Devuan GNU/Linux 4 (chimaera) (on /dev/sda2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.10.0-10-amd64--f203d9ec-a53c-4f33-ad2a-222cf8f8dbcd' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
		linux /boot/vmlinuz-5.10.0-10-amd64 root=/dev/sda2
		initrd /boot/initrd.img-5.10.0-10-amd64
	menuentry 'Devuan GNU/Linux 4 (chimaera) (on /dev/sda2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.10.0-11-amd64--f203d9ec-a53c-4f33-ad2a-222cf8f8dbcd' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
		linux /boot/vmlinuz-5.10.0-11-amd64 root=/dev/sda2
		initrd /boot/initrd.img-5.10.0-11-amd64
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
		initrd /initrd.img
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
		initrd /initrd.img
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
	menuentry 'Devuan GNU/Linux 4 (chimaera) (on /dev/sda2)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/vmlinuz.old--f203d9ec-a53c-4f33-ad2a-222cf8f8dbcd' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt2'
		else
		fi
		linux /vmlinuz.old root=/dev/sda2
menuentry 'Slackware 15.0 x86_64 (on /dev/sda3)' --class slackware --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-898752b9-52fc-4814-a5a6-67c7c4574b7e' {
	insmod part_gpt
	insmod ext2
	set root='hd0,gpt3'
	  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt3 --hint-efi=hd0,gpt3 --hint-baremetal=ahci0,gpt3 --hint='hd0,gpt3'  898752b9-52fc-4814-a5a6-67c7c4574b7e
	else
	  search --no-floppy --fs-uuid --set=root 898752b9-52fc-4814-a5a6-67c7c4574b7e
	fi
	initrd /boot/initrd.gz
submenu 'Advanced options for Slackware 15.0 x86_64 (on /dev/sda3)' $menuentry_id_option 'osprober-gnulinux-advanced-898752b9-52fc-4814-a5a6-67c7c4574b7e' {
	menuentry 'Slackware 15.0 x86_64 (on /dev/sda3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz--898752b9-52fc-4814-a5a6-67c7c4574b7e' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt3'
		else
		fi
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt3'
		else
		fi
	menuentry 'Slackware 15.0 x86_64 (on /dev/sda3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-generic--898752b9-52fc-4814-a5a6-67c7c4574b7e' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt3'
		else
		fi
		linux /boot/vmlinuz-generic root=/dev/sda3
	menuentry 'Slackware 15.0 x86_64 (on /dev/sda3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-generic-5.15.19--898752b9-52fc-4814-a5a6-67c7c4574b7e' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt3'
		else
		fi
		linux /boot/vmlinuz-generic-5.15.19 root=/dev/sda3
	menuentry 'Slackware 15.0 x86_64 (on /dev/sda3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-huge--898752b9-52fc-4814-a5a6-67c7c4574b7e' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt3'
		else
		fi
		linux /boot/vmlinuz-huge root=/dev/sda3
	menuentry 'Slackware 15.0 x86_64 (on /dev/sda3)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-huge-5.15.19--898752b9-52fc-4814-a5a6-67c7c4574b7e' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt3'
		else
		fi
		linux /boot/vmlinuz-huge-5.15.19 root=/dev/sda3
menuentry 'openSUSE Tumbleweed (on /dev/sda5)' --class opensuse --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-a49723a1-bc42-4b71-988c-5b50c7c8c7bc' {
	insmod part_gpt
	insmod ext2
	set root='hd0,gpt5'
	  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt5 --hint-efi=hd0,gpt5 --hint-baremetal=ahci0,gpt5 --hint='hd0,gpt5'  a49723a1-bc42-4b71-988c-5b50c7c8c7bc
	else
	  search --no-floppy --fs-uuid --set=root a49723a1-bc42-4b71-988c-5b50c7c8c7bc
	fi
	linux /boot/vmlinuz-5.16.2-1-default root=UUID=a49723a1-bc42-4b71-988c-5b50c7c8c7bc splash=silent quiet mitigations=auto
	initrd /boot/initrd-5.16.2-1-default
submenu 'Advanced options for openSUSE Tumbleweed (on /dev/sda5)' $menuentry_id_option 'osprober-gnulinux-advanced-a49723a1-bc42-4b71-988c-5b50c7c8c7bc' {
	menuentry 'openSUSE Tumbleweed (on /dev/sda5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.16.2-1-default--a49723a1-bc42-4b71-988c-5b50c7c8c7bc' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt5'
		else
		fi
	menuentry 'openSUSE Tumbleweed, with Linux 5.16.2-1-default (on /dev/sda5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.16.2-1-default--a49723a1-bc42-4b71-988c-5b50c7c8c7bc' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt5'
		else
		fi
	menuentry 'openSUSE Tumbleweed, with Linux 5.16.1-1-default (on /dev/sda5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.16.1-1-default--a49723a1-bc42-4b71-988c-5b50c7c8c7bc' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt5'
		else
		fi
		linux /boot/vmlinuz-5.16.1-1-default root=UUID=a49723a1-bc42-4b71-988c-5b50c7c8c7bc splash=silent quiet mitigations=auto
		initrd /boot/initrd-5.16.1-1-default
menuentry 'Slackware 14.2 (on /dev/sda7)' --class slackware --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-ca8a35da-fa8c-4d59-b2cf-c26c73c07e99' {
	insmod part_gpt
	insmod ext2
	set root='hd0,gpt7'
	  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt7 --hint-efi=hd0,gpt7 --hint-baremetal=ahci0,gpt7 --hint='hd0,gpt7'  ca8a35da-fa8c-4d59-b2cf-c26c73c07e99
	else
	  search --no-floppy --fs-uuid --set=root ca8a35da-fa8c-4d59-b2cf-c26c73c07e99
	fi
	linux /boot/vmlinuz root=/dev/sda7
submenu 'Advanced options for Slackware 14.2 (on /dev/sda7)' $menuentry_id_option 'osprober-gnulinux-advanced-ca8a35da-fa8c-4d59-b2cf-c26c73c07e99' {
	menuentry 'Slackware 14.2 (on /dev/sda7)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz--ca8a35da-fa8c-4d59-b2cf-c26c73c07e99' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt7'
		else
		fi
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt7'
		else
		fi
	menuentry 'Slackware 14.2 (on /dev/sda7)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-generic--ca8a35da-fa8c-4d59-b2cf-c26c73c07e99' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt7'
		else
		fi
		linux /boot/vmlinuz-generic root=/dev/sda7
	menuentry 'Slackware 14.2 (on /dev/sda7)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-generic-4.4.14--ca8a35da-fa8c-4d59-b2cf-c26c73c07e99' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt7'
		else
		fi
		linux /boot/vmlinuz-generic-4.4.14 root=/dev/sda7
	menuentry 'Slackware 14.2 (on /dev/sda7)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-generic-smp--ca8a35da-fa8c-4d59-b2cf-c26c73c07e99' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt7'
		else
		fi
		linux /boot/vmlinuz-generic-smp root=/dev/sda7
	menuentry 'Slackware 14.2 (on /dev/sda7)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-generic-smp-4.4.14-smp--ca8a35da-fa8c-4d59-b2cf-c26c73c07e99' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt7'
		else
		fi
		linux /boot/vmlinuz-generic-smp-4.4.14-smp root=/dev/sda7
	menuentry 'Slackware 14.2 (on /dev/sda7)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-huge--ca8a35da-fa8c-4d59-b2cf-c26c73c07e99' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt7'
		else
		fi
		linux /boot/vmlinuz-huge root=/dev/sda7
	menuentry 'Slackware 14.2 (on /dev/sda7)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-huge-4.4.14--ca8a35da-fa8c-4d59-b2cf-c26c73c07e99' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt7'
		else
		fi
		linux /boot/vmlinuz-huge-4.4.14 root=/dev/sda7
	menuentry 'Slackware 14.2 (on /dev/sda7)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-huge-smp--ca8a35da-fa8c-4d59-b2cf-c26c73c07e99' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt7'
		else
		fi
		linux /boot/vmlinuz-huge-smp root=/dev/sda7
	menuentry 'Slackware 14.2 (on /dev/sda7)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-huge-smp-4.4.14-smp--ca8a35da-fa8c-4d59-b2cf-c26c73c07e99' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt7'
		else
		fi
		linux /boot/vmlinuz-huge-smp-4.4.14-smp root=/dev/sda7
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f  ${config_directory}/custom.cfg ]; then
  source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f  $prefix/custom.cfg ]; then
  source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
### BEGIN /etc/grub.d/80_suse_btrfs_snapshot ###
### END /etc/grub.d/80_suse_btrfs_snapshot ###
### BEGIN /etc/grub.d/90_persistent ###
### END /etc/grub.d/90_persistent ###
### BEGIN /etc/grub.d/95_textmode ###
if [ "${grub_platform}" = "efi" ]; then
  # On EFI systems we can only have graphics *or* serial, so allow the user
  # to switch between the two
  hiddenentry 'Text mode' --hotkey 't' {
    set textmode=true
fi
### END /etc/grub.d/95_textmode ###
#6 2022-02-05 10:59:48
So the other distributions all have root=/dev/whatever instead of the UUID, which is why the boot breaks — the block device identifier has changed so the correct root can't be found.
I think the best approach here would be to ditch os-prober completely and build your own multi-boot menu using /etc/grub.d/40_custom to call configfile (ie grub.cfg) in each of the distributions.
Here's an example for Devuan:
menuentry 'Devuan' {
   search.fs_uuid f203d9ec-a53c-4f33-ad2a-222cf8f8dbcd
   configfile /boot/grub/grub.cfg
Alternatively just build a complete menuentry, like this:
   linux /vmlinuz ro quiet root=UUID=f203d9ec-a53c-4f33-ad2a-222cf8f8dbcd
   initrd /initrd.img
^ That uses the /vmlinuz & /initrd.img symlinks that always point to the current kernel version so it doesn't need to be updated after kernel upgrades.
Slackware has similar symlinks in /boot/vmlinuz, /boot/vmlinuz-generic & /boot/vmlinuz-huge with /boot/initrd.gz remaining unchanged regardless of kernel version.
The kernel & initramfs images for Artix are unversioned so they can also be called directly with no need to edit after updates.
No idea about SUSE though, sorry.
And to be clear: this is not a problem with Devuan and there is nothing the Devuan developers can do about it.
EDIT: looking again at the documentation you should check /etc/default/grub in the controlling system and make sure this is set:
GRUB_DISABLE_LINUX_UUID=false
^ That should make GRUB use root=UUID= in the linux line. It should be set by default but perhaps you have changed it to true for some reason. Remember to update the configuration afterwards:
# grub-mkconfig -o /boot/grub/grub.cfg
#7 2022-02-06 01:37:04
torquebar
You mean changed from uuid to dev-name?
I would think that that would be handled on a partition-by-partition basis, more importantly what I don't understand is why on earth the "grub-run" initiated under Suse in this case should not use only the method used in fstab for each partition But I'm not going to get all riled up as I used to when grub2 first appeared :-)
Thanks for the effort and the insight, for now I'm not ready to get into it that deep.
Suse does it much the same, actually I used to wish that all distros would use exactly identical vmlinuz and initrd exactly in the same path i.e. /boot to make it easier for people having to boot manually but I gave up a long time ago. I just installed Slackware-15.0 and didn't even know that it has started using and initrd as well, I didn't cite it in the earlier manual boot but it booted anyway.
I didn't suggest it did, just plain didn't know.
The default Suse version uses #GRUB_DISABLE_LINUX_UUID=true so I'm not sure what that would do in real life but I have set it to false and will watch what comes loose over time. I thing Suse's Yast runs grub-mkconfig when doing the boot ritual.
Thanks again!  I'll mark the topic resolved seeing that I have a good idea where the problem might be.
#8 2022-02-06 12:04:59
No, I mean that what was /dev/sda when grub.cfg was created has been assigned to /dev/sdb (or another device node) for the failed boot.
But then it wouldn't be possible to keep old kernel versions installed in case of a problem with the new one. Arch attempts to solve that problem by offering both a mainline and LTS kernel package but it's not perfect and there has been some discussion on their mailing lists about moving to versioned kernel images.
Actually their setting must be false by default because the native entries use UUIDs to identify the root partition in the kernel command line. I think the problem must be with os-prober, there are a few old bug reports describing that and I seem to remember a recent post over at forums.debian.net with the same issue. I don't bother with os-prober myself though so I have no experience with it.
#9 2022-02-06 14:31:43
torquebar
I meant those to be links to the latest versions but the links should be uniform and uniformly placed in all distros. Think of someone with 10 distros aboard who wannts to boot manuallly
set root = (hd0,x)
linux /boot/vmlinuz
initrd /boot/initrd
boot
...end of story. If you're using for example initrd.img then it falls apart. Everyone knows which partition (x) they want to boot. Then IF you want some retro kernel you can just enter the numbered equivalents.
I made the edit but yes, probably for nothing. With absolutely no time or inclination to become a grub2 expert I think I will just start booting manually, or maybe explore partition-labels which I hate no less than grub2 because they too are just another form of virtualisation, or maybe study your suggestions  ..but not before September or so :-)
Too bad the grub devs sacrificed the user editable single menu file, it would be too simple (humanized front part  meaning nothing to grub, it's by and for the user; bracketed uuid does not appear in the menu unless user wants it too):
Disk-1_Part-1  Devuan   (uuid=....)
Disk-1_Part-6  Artix    (uuid=....)
Disk-2_Part-3  Slack    (uuid=....)
Disk-2_Part-4  Suse-TW  (uuid=....)
...etc.
#10 2022-02-09 13:46:58
torquebar
I've raised the topic on the Suse list, but I remain curious why
this particular problem hit only my Devuan installation. The boot
is set up under Suse, the utility is grub2, the victim partition is
#2, Devuan. That's all I really know :-)
#11 2022-02-09 21:57:57
torquebar
installation.
https://imgur.com/ygZ4NMp.png
.....snip
cheers
I just had the first ever successive instances of this on my asus-g73
laptop so I can expand on the issue somewhat.
The missing dev-name was /dev/sda on the first one, but /dev/sdb
on another.  My hunch is that if at boot-time the drive is recognised
NOT as the same device-name that it was when Suse deployed the
boot code to disk root THAT when the proverbial stuff hits the fan. As I
mention elsewhere this instability I have seen only with Suse, the
disk always shows up as /dev/sda under Artix, Devuan and Slackware.
So maybe I should get one of these to do the honors?  Like I said
I'm just a mortal user... I have no other ideas.
Disk /dev/sda: 238.47 GiB, 256060514304 bytes, 500118192 sectors
Disk model: Samsung SSD 850
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 3C896711-604F-4E75-8970-396FF8553F89
/dev/sda1       2048  83888127  83886080   40G Linux filesystem
/dev/sda2   83888128 167774207  83886080   40G Linux filesystem
/dev/sda3  167774208 230688767  62914560   30G Linux filesystem
/dev/sda4  230688768 356517887 125829120   60G Linux filesystem
/dev/sda5  356517888 482347007 125829120   60G Linux filesystem
/dev/sda6  482347008 488638463   6291456    3G Linux filesystem
/dev/sda7  488638464 497027071   8388608    4G Linux swap
/dev/sda8  497027072 498051071   1024000  500M BIOS boot
#12 2023-10-22 07:43:30
czeekaj
   initrd /initrd.img
Hi, how would I generate a menu entry or a grub config for an encrypted boot partition? Also when I make a custom ISO how can i change the boot menu for that said USB? I'd like to optimize grub.
Possible to use variables in the grub menu? Like for UUID and the like?
set root = (hd0,$root)
linux /boot/vmlinuz
initrd /boot/initrd
boot
(can initrd be an initramfs?) Can i customize this?
   search.fs_uuid $bootuuid
What if I am using an MBR with encrypted boot. What can I do to make it direct menu entry?
#13 2023-10-22 09:29:59
torquebar
I had just about forgotten about this post made 2 years ago when an email chimed-in. Nothing has changed, I still get the problem maybe once a month on one system or another. I now use only Suse Leap as the go2 where I do the grub ritual, no longer use Tumbleweed as well for this). A single reboot just about always fixes.
#14 2023-10-22 13:19:18
@czeekaj Any particular reason for necrobumping a 1.5 year old solved question with something almost entirely unrelated?
@torquebar As HoaS already commented, this is almost certainly due to os-prober using the unstable /dev/sdx names rather than UUIDs.
There are bug reports about it going back over a decade, with the conclusion that UUID support in the kernel can't be assumed, so os-prober shouldn't use it.
Then again os-prober is really just a bunch of shell scripts, so it shouldn't be particularly hard to change if it annoys you enough to do so.
#15 2023-10-22 20:59:41
torquebar
It's not a problem at all, in fact  I have very few problems with Devuan, use it once a week on Tuesdays, Sundays are AvLinux days. Devuan  hasn't packed up since I started using it and I don't see how it would run any better with systemd :-)
