#1 2022-02-01 17:45:22
bimon
No microphone sound in Librewolf and Firefox too
Hello,
I have sound working fine in Zoom (both Mic and Headphones), but unfortunately there is no microphone sound in Firefox.
On the other hand Firefox plays any sounds to the headphones fine.
It is a Chimaera installation.
dpkg -al | grep pulse
ii  libpulse-mainloop-glib0:amd64                               14.2-2                                                    amd64        PulseAudio client libraries (glib support)
ii  libpulse0:amd64
I have following asound.conf:
root@chimaera:/etc/alsa# cat asound.conf
##### Hardware Aliases #####
pcm.system_card {
        type hw;
        card 0;
ctl.system_card {
        type hw;
        card 0;
ctl.system_dm ctl.system_card;
####################### MIXERS ########################
# --- System
pcm.system_mixer {
        type dmix;
        ipc_key 1024;
        ipc_key_add_uid false; # let multiple users share
        ipc_perm 0777; # IPC permissions (octal, default 0600)
        slave {
                pcm system_card;
                period_time 0;
                period_size 2048;
                buffer_size 32768;
#               rate 48000;
                rate 44100;
        bindings {
                0 0;
                1 1;
pcm.system_dm {
        type plug;
        slave.pcm "system_mixer";
pcm.system_volume {
    type softvol
    slave {
#        pcm system_card;
        pcm "system_mixer"
    control {
        name "Pre-Amp";
        card 0;
    min_dB -10.0
    max_dB 25.0
    resolution 12
pcm.system_sv {
        type plug;
        slave.pcm "system_volume";
#ctl.system_sv ctl.system_card;
pcm.asymed {
        type asym
        playback.pcm "system_mixer"
        capture.pcm "hw:0,0"
ctl.asymed ctl.system_card;
##### Defaults #####
pcm.dsp0 {
    type plug
    slave.pcm "asymed"
pcm.!default {
        type plug
        slave.pcm "asymed"
pcm.default {
   type plug
   slave.pcm "asymed"
ctl.!default ctl.asymed
ctl.default ctl.asymed
#2 2022-02-01 19:01:05
bimon
Re: No microphone sound in Librewolf and Firefox too
I have found a workaround of executing browser by apulse command.
But then why headphones work even without apulse via ALSA while microphone works only via apulse for me ?
#3 2022-02-01 19:47:21
So I presume it works without apulse if you remove asound.conf?
#4 2022-02-01 21:30:33
bimon
Removing /etc/alsa/asound.conf still keeps sound in zoom working, but it does not influence firefox at all, so Mic still does not work anyway.
Is /etc/alsa/asound.conf file taken into account by the ALSA at all?
Can you please suggest an URL with modern guides for custom configuration of ALSA in Debian v11 or Chimaera without pulseAudio?
#5 2022-02-02 09:41:34
#6 2022-02-02 15:04:51
I don't think so.
From /usr/share/alsa/alsa.conf:
# pre-load the configuration files
@hooks [
      func load
      files [
         "/var/lib/alsa/conf.d"
         "/usr/etc/alsa/conf.d"
         "/etc/alsa/conf.d"
         "/etc/asound.conf|||/usr/etc/asound.conf"
         "~/.asoundrc"
            @func concat
            strings [
                  @func getenv
                  vars [
                     XDG_CONFIG_HOME
                  default "~/.config"
               "/alsa/asoundrc"
      errors false
https://www.alsa-project.org/wiki/Asoundrc
And there's also https://wiki.archlinux.org/title/Advanc … chitecture & https://wiki.gentoo.org/wiki/ALSA
All I have ever needed to do is set the default card from HDMI to analogue to get both speaker output and microphone input working with firefox-esr in my Debian systems, as per the link kindly supplied by Camtaf.
What exactly do want ALSA to do? What sort of customisation is required?
#7 2022-12-09 13:30:06
bai4Iej2need
The same applies to my installation
playback works
arecord works to file
jitsi meet and vlc can access the microphone (front jack), working
firefox with various apps (clickmeeting.com, zoom , webex, maybe others)  have negative results.
chimaera , no backports,
firefox is 102.5.0-esr from distribution
output alsa-info:
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.65
!!Script ran on: Fri Dec  9 10:54:49 UTC 2022
!!Linux Distribution
ID_LIKE=debian
!!DMI Information
Manufacturer:      LENOVO
Product Name:      2714A9G
Product Version:   ThinkPad R500
Firmware Version:  7YET79WW (3.09 )
System SKU:
Board Vendor:      LENOVO
Board Name:        2714A9G
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 	 15
/sys/bus/acpi/devices/IBM0068:00/status 	 15
/sys/bus/acpi/devices/IBM0079:00/status 	 15
/sys/bus/acpi/devices/INTC0102:00/status 	 15
/sys/bus/acpi/devices/LNXIOBAY:00/status 	 15
/sys/bus/acpi/devices/LNXPOWER:00/status 	 1
/sys/bus/acpi/devices/PNP0103:00/status 	 15
/sys/bus/acpi/devices/PNP0400:00/status 	 15
/sys/bus/acpi/devices/PNP0501:00/status 	 15
/sys/bus/acpi/devices/PNP0C0A:00/status 	 31
/sys/bus/acpi/devices/PNP0C0F:00/status 	 9
/sys/bus/acpi/devices/PNP0C0F:01/status 	 9
/sys/bus/acpi/devices/PNP0C0F:02/status 	 9
/sys/bus/acpi/devices/PNP0C0F:03/status 	 9
/sys/bus/acpi/devices/PNP0C0F:04/status 	 9
/sys/bus/acpi/devices/PNP0C0F:05/status 	 9
/sys/bus/acpi/devices/PNP0C0F:06/status 	 9
/sys/bus/acpi/devices/PNP0C0F:07/status 	 9
!!Kernel Information
Kernel release:    5.10.0-18-amd64
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k5.10.0-18-amd64
Library version:    1.2.4
Utilities version:  1.2.4
!!Loaded ALSA modules
snd_hda_intel
!!Sound Servers on this system
No sound servers found.
!!Soundcards recognised by ALSA
 0 [Intel          ]: HDA-Intel - HDA Intel
                      HDA Intel at 0xfc000000 irq 35
!!PCI Soundcards installed in the system
00:1b.0 Audio device [0403]: Intel Corporation 82801I (ICH9 Family) HD Audio Controller [8086:293e] (rev 03)
	Subsystem: Lenovo ThinkPad T400 [17aa:20f2]
!!Modprobe options (Sound related)
snd_pcsp: index=-2
snd_usb_audio: index=-2
snd_atiixp_modem: index=-2
snd_intel8x0m: index=-2
snd_via82xx_modem: index=-2
!!Loaded sound module options
!!Module: snd_hda_intel
	align_buffer_size : -1
	bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	dmic_detect : Y
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_msi : -1
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	pm_blacklist : Y
	position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	power_save : 0
	power_save_controller : Y
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	single_cmd : -1
	snoop : -1
!!HDA-Intel Codec information
--startcollapse--
Codec: Conexant CX20561 (Hermosa)
Address: 0
AFG Function Id: 0x1 (unsol 1)
MFG Function Id: 0x2 (unsol 1)
Vendor Id: 0x14f15051
Subsystem Id: 0x17aa20fd
Revision Id: 0x100000
Modem Function Group: 0x2
Default PCM:
    rates [0x160]: 44100 48000 96000
    bits [0xe]: 16 20 24
    formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
  Power states:  D0 D1 D2 D3 CLKSTOP
  Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=4, o=0, i=0, unsolicited=1, wake=0
  IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[3]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x10 [Audio Output] wcaps 0xc1d: Stereo Amp-Out R/L
  Control: name="Speaker Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=Out, idx=0, ofs=0
  Control: name="Speaker Playback Switch", index=0, device=0
  Device: name="CX20561 Analog", type="Audio", device=0
  Amp-Out caps: ofs=0x4a, nsteps=0x4a, stepsize=0x03, mute=0
  Amp-Out vals:  [0x4a 0x4a]
  Converter: stream=0, channel=0
  PCM:
    rates [0x560]: 44100 48000 96000 192000
    formats [0x1]: PCM
Node 0x11 [Audio Output] wcaps 0xc1d: Stereo Amp-Out R/L
  Control: name="Headphone Playback Volume", index=0, device=0
  Control: name="Headphone Playback Switch", index=0, device=0
  PCM:
    formats [0x1]: PCM
Node 0x12 [Audio Output] wcaps 0x211: Stereo Digital
  Control: name="IEC958 Playback Con Mask", index=0, device=0
  Control: name="IEC958 Playback Pro Mask", index=0, device=0
  Control: name="IEC958 Playback Default", index=0, device=0
  Control: name="IEC958 Playback Switch", index=0, device=0
  Control: name="IEC958 Default PCM Playback Switch", index=0, device=0
  Device: name="CX20561 Digital", type="SPDIF", device=1
  Digital: Enabled
  Digital category: 0x0
  IEC Coding Type: 0x0
  PCM:
    formats [0x5]: PCM AC3
Node 0x13 [Beep Generator Widget] wcaps 0x70000c: Mono Amp-Out
  Control: name="Beep Playback Volume", index=0, device=0
    ControlAmp: chs=1, dir=Out, idx=0, ofs=0
  Control: name="Beep Playback Switch", index=0, device=0
  Amp-Out caps: ofs=0x03, nsteps=0x03, stepsize=0x17, mute=0
  Amp-Out vals:  [0x00]
Node 0x14 [Audio Input] wcaps 0x100d1b: Stereo Amp-In R/L
  Amp-In caps: ofs=0x4a, nsteps=0x50, stepsize=0x03, mute=0
  Amp-In vals:  [0x38 0x38] [0x38 0x38]
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 2
     0x1d* 0x17
Node 0x15 [Audio Input] wcaps 0x100d1b: Stereo Amp-In R/L
  Control: name="Capture Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=1, ofs=0
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x18
Node 0x16 [Pin Complex] wcaps 0x400581: Stereo
  Pincap 0x0000001c: OUT HP Detect
  Pin Default 0x022140f0: [Jack] HP Out at Ext Front
    Conn = 1/8, Color = Green
    DefAssociation = 0xf, Sequence = 0x0
  Pin-ctls: 0xc0: OUT HP
  Unsolicited: tag=02, enabled=1
  Connection: 2
     0x10 0x11*
Node 0x17 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
  Control: name="Dock Mic Boost Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=0, ofs=0
  Amp-In caps: ofs=0x00, nsteps=0x04, stepsize=0x27, mute=0
  Amp-In vals:  [0x03 0x03]
  Pincap 0x00001224: IN Detect
    Vref caps: 50 80
  Pin Default 0x61a190f0: [N/A] Mic at Sep Rear
    Conn = 1/8, Color = Pink
  Pin-ctls: 0x24: IN VREF_80
  Unsolicited: tag=03, enabled=1
Node 0x18 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
  Control: name="Mic Boost Volume", index=0, device=0
    Vref caps: 50 80
  Pin Default 0x02a190f0: [Jack] Mic at Ext Front
  Unsolicited: tag=04, enabled=1
Node 0x19 [Pin Complex] wcaps 0x400581: Stereo
  Pincap 0x00000014: OUT Detect
  Pin Default 0x40f000f0: [N/A] Other at Ext N/A
    Conn = Unknown, Color = Unknown
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=01, enabled=1
  Connection: 2
     0x10 0x11*
Node 0x1a [Pin Complex] wcaps 0x400501: Stereo
  Pincap 0x00010010: OUT EAPD
  EAPD 0x2: EAPD
  Pin Default 0x901701f0: [Fixed] Speaker at Int N/A
    Conn = Analog, Color = Unknown
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 2
     0x10* 0x11
Node 0x1b [Pin Complex] wcaps 0x400500: Mono
  EAPD 0x2: EAPD
  Pin Default 0x40f001f0: [N/A] Other at Ext N/A
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 2
     0x10* 0x11
Node 0x1c [Pin Complex] wcaps 0x400701: Stereo Digital
  Pincap 0x00000010: OUT
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x12
Node 0x1d [Pin Complex] wcaps 0x40040b: Stereo Amp-In
  Control: name="Internal Mic Boost Volume", index=0, device=0
  Pincap 0x00000020: IN
  Pin Default 0x90a701f0: [Fixed] Mic at Int N/A
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
Node 0x1e [Vendor Defined Widget] wcaps 0xf00000: Mono
--endcollapse--
!!ALSA Device nodes
crw-rw----+ 1 root audio 116,  6 Dec  9 11:39 /dev/snd/controlC0
crw-rw----+ 1 root audio 116,  5 Dec  9 11:39 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116,  3 Dec  9 11:39 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116,  2 Dec  9 11:39 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116,  4 Dec  9 11:39 /dev/snd/pcmC0D1p
crw-rw----+ 1 root audio 116,  1 Dec  9 11:39 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Dec  9 11:39 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  60 Dec  9 11:39 .
drwxr-xr-x 3 root root 200 Dec  9 11:39 ..
lrwxrwxrwx 1 root root  12 Dec  9 11:39 pci-0000:00:1b.0 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: CX20561 Analog [CX20561 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 1: CX20561 Digital [CX20561 Digital]
  Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card Intel
Card hw:0 'Intel'/'HDA Intel at 0xfc000000 irq 35'
  Mixer name	: 'Conexant CX20561 (Hermosa)'
  Components	: 'HDA:14f15051,17aa20fd,00100000'
  Controls      : 30
  Simple ctrls  : 13
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 74
  Mono: Playback 74 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Playback channels: Front Left - Front Right
  Mono:
  Front Left: Playback 74 [100%] [0.00dB] [on]
  Front Right: Playback 74 [100%] [0.00dB] [on]
Simple mixer control 'Speaker',0
  Mono:
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic Boost',0
  Capabilities: volume
  Capture channels: Front Left - Front Right
  Limits: 0 - 4
  Front Left: 3 [75%] [30.00dB]
  Front Right: 3 [75%] [30.00dB]
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [on]
Simple mixer control 'IEC958 Default PCM',0
  Mono: Playback [on]
Simple mixer control 'Beep',0
  Limits: Playback 0 - 3
  Mono: Playback 0 [0%] [-18.00dB] [on]
Simple mixer control 'Capture',0
  Capabilities: cvolume
  Limits: Capture 0 - 80
  Front Left: Capture 56 [70%] [-18.00dB]
  Front Right: Capture 56 [70%] [-18.00dB]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Disabled'
Simple mixer control 'Digital',0
  Limits: Capture 0 - 120
  Front Left: Capture 95 [79%] [17.50dB]
  Front Right: Capture 95 [79%] [17.50dB]
Simple mixer control 'Dock Mic Boost',0
  Limits: 0 - 4
Simple mixer control 'Internal Mic Boost',0
  Limits: 0 - 4
!!Alsactl output
--startcollapse--
state.Intel {
	control.1 {
		iface MIXER
		name 'Beep Playback Volume'
		value 0
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 3'
			dbmin -1800
			dbmax 0
			dbvalue.0 -1800
	control.2 {
		iface MIXER
		name 'Beep Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.3 {
		iface MIXER
		name 'Speaker Playback Volume'
		value.0 74
		value.1 74
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 74'
			dbmin -9999999
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.4 {
		iface MIXER
		name 'Speaker Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.5 {
		iface MIXER
		name 'Headphone Playback Volume'
		value.0 74
		value.1 74
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 74'
			dbmin -9999999
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.6 {
		iface MIXER
		name 'Headphone Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.7 {
		iface MIXER
		name 'Auto-Mute Mode'
		value Disabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.8 {
		iface MIXER
		name 'Capture Volume'
		value.0 56
		value.1 56
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 80'
			dbmin -7400
			dbmax 600
			dbvalue.0 -1800
			dbvalue.1 -1800
	control.9 {
		iface MIXER
		name 'Mic Boost Volume'
		value.0 3
		value.1 3
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 4'
			dbmin 0
			dbmax 4000
			dbvalue.0 3000
			dbvalue.1 3000
	control.10 {
		iface MIXER
		name 'Internal Mic Boost Volume'
		value.0 3
		value.1 3
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 4'
			dbmin 0
			dbmax 4000
			dbvalue.0 3000
			dbvalue.1 3000
	control.11 {
		iface MIXER
		name 'Dock Mic Boost Volume'
		value.0 3
		value.1 3
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 4'
			dbmin 0
			dbmax 4000
			dbvalue.0 3000
			dbvalue.1 3000
	control.12 {
		iface MIXER
		name 'IEC958 Playback Con Mask'
		value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.13 {
		iface MIXER
		name 'IEC958 Playback Pro Mask'
		value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.14 {
		iface MIXER
		name 'IEC958 Playback Default'
		value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.15 {
		iface MIXER
		name 'IEC958 Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.16 {
		iface MIXER
		name 'IEC958 Default PCM Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.17 {
		iface MIXER
		name 'Master Playback Volume'
		value 74
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 74'
			dbmin -9999999
			dbmax 0
			dbvalue.0 0
	control.18 {
		iface MIXER
		name 'Master Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.19 {
		iface CARD
		name 'Mic Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.20 {
		iface CARD
		name 'Internal Mic Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.21 {
		iface CARD
		name 'Dock Mic Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.22 {
		iface CARD
		name 'Speaker Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.23 {
		iface CARD
		name 'Dock Headphone Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.24 {
		iface CARD
		name 'Headphone Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.25 {
		iface CARD
		name 'SPDIF Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.26 {
		iface PCM
		name 'Playback Channel Map'
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		comment {
			access read
			type INTEGER
			count 4
			range '0 - 36'
	control.27 {
		iface PCM
		name 'Capture Channel Map'
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.28 {
		iface PCM
		device 1
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.29 {
		iface MIXER
		name 'PCM Playback Volume'
		value.0 255
		value.1 255
		comment {
			access 'read write user'
			type INTEGER
			count 2
			range '0 - 255'
			tlv '0000000100000008ffffec1400000014'
			dbmin -5100
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.30 {
		iface MIXER
		name 'Digital Capture Volume'
		value.0 95
		value.1 95
		comment {
			type INTEGER
			count 2
			range '0 - 120'
			tlv '0000000100000008fffff44800000032'
			dbmin -3000
			dbmax 3000
			dbvalue.0 1750
			dbvalue.1 1750
--endcollapse--
!!All Loaded Modules
ac
acpi_cpufreq
ahci
battery
bch
button
cdrom
cec
cfg80211
coretemp
cqhci
crc16
crc32c_generic
crc_itu_t
crc_t10dif
crct10dif_common
crct10dif_generic
drm
drm_kms_helper
ehci_hcd
ehci_pci
evdev
ext4
firewire_core
firewire_ohci
firewire_sbp2
fuse
hid
hid_generic
i2c_algo_bit
i2c_i801
i2c_smbus
i915
iTCO_vendor_support
iTCO_wdt
intel_pmc_bxt
irqbypass
iwldvm
iwlwifi
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libahci
libarc4
libata
libcrc32c
libphy
lpc_ich
mac80211
mbcache
mc
mei
mei_me
memstick
mmc_block
mmc_core
mtd
nand
nand_ecc
nandcore
nf_tables
nfnetlink
nvram
parport
parport_pc
pcmcia
pcmcia_core
pcmcia_rsrc
pcspkr
ppdev
pps_core
psmouse
ptp
r592
r852
rfkill
rng_core
scsi_mod
sd_mod
sdhci
sdhci_pci
serio_raw
sg
sm_common
snd
snd_compress
snd_hda_codec
snd_hda_codec_conexant
snd_hda_codec_generic
snd_hda_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_soc_core
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sr_mod
t10_pi
tg3
thinkpad_acpi
tpm
tpm_tis
tpm_tis_core
uas
uhci_hcd
usb_common
usb_storage
usbcore
usbhid
uvcvideo
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
watchdog
wmi
wmi_bmof
yenta_socket
zram
zsmalloc
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x16 0x022140f0
0x17 0x61a190f0
0x18 0x02a190f0
0x19 0x40f000f0
0x1a 0x901701f0
0x1b 0x40f001f0
0x1c 0x40f001f0
0x1d 0x90a701f0
/sys/class/sound/hwC0D0/driver_pin_configs:
0x16 0x042140ff
0x17 0x21a11000
0x19 0x2121103f
0x1c 0x21440100
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
!!ALSA/HDA dmesg
[    0.644499] ACPI: Added _OSI(Linux-Dell-Video)
[    0.644499] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.644499] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    8.704155] r852: driver loaded successfully
[    8.956956] snd_hda_codec_conexant hdaudioC0D0: CX20561 (Hermosa): BIOS auto-probing.
[    8.957925] snd_hda_codec_conexant hdaudioC0D0: autoconfig for CX20561 (Hermosa): line_outs=1 (0x1a/0x0/0x0/0x0/0x0) type:speaker
[    8.957928] snd_hda_codec_conexant hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    8.957930] snd_hda_codec_conexant hdaudioC0D0:    hp_outs=2 (0x19/0x16/0x0/0x0/0x0)
[    8.957932] snd_hda_codec_conexant hdaudioC0D0:    mono: mono_out=0x0
[    8.957933] snd_hda_codec_conexant hdaudioC0D0:    dig-out=0x1c/0x0
[    8.957935] snd_hda_codec_conexant hdaudioC0D0:    inputs:
[    8.957937] snd_hda_codec_conexant hdaudioC0D0:      Mic=0x18
[    8.957939] snd_hda_codec_conexant hdaudioC0D0:      Internal Mic=0x1d
[    8.957941] snd_hda_codec_conexant hdaudioC0D0:      Dock Mic=0x17
[    8.972644] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[    8.972727] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[    8.972795] input: HDA Intel Dock Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[    8.972862] input: HDA Intel Dock Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[    8.972925] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
[    9.234275] ppdev: user-space parallel port driver
!!Packages installed
ii  alsa-oss                              1.1.8-1                            amd64        ALSA wrapper for OSS applications
ii  alsa-tools                            1.2.2-1                            amd64        Console based ALSA utilities for specific hardware
ii  alsa-topology-conf                    1.2.4-1                            all          ALSA topology configuration files
ii  alsa-utils                            1.2.4-1                            amd64        Utilities for configuring and using ALSA
Any Ideas how to switch to one of the three Mic inputs ?
What do i miss ?
broken by design :
#8 2023-01-23 21:22:52
bai4Iej2need
It seems that after changes of the X user  (#1 logout, s/o else logs in,  s/o logs out, #1 login back  ) settings might be confused
run in *terminal as user
/usr/sbin/alsactl init
in cli
alsamixer
check all volume settings
check all mute positions
set "digital" other than 0 zero , to make microphone work.
This seems to have it fixed for me.
broken by design :
