#1 2022-01-21 12:44:57
MiyoLinux
Chimaera sources.list
Okay...at the worst, I'm an idiot, because I haven't been able to find anything about this. At the best, I'm still an idiot, because I haven't been able to find anything about this. tongue
I'm working on the latest MiyoLinux release based on Chimaera. I saw (and read) the Chimaera release notes. As such, I saw what the release notes noted in regard to the sources.list.
My conundrum is in regard to said sources.list...
The net installer places security updates as this in the sources.list...
deb http://pkgmaster.devuan.org/merged chimaera-security main
However, the release notes say to use...
deb http://deb.devuan.org/merged chimaera-security main
I realize the Release Notes should most likely be followed; however, I just wanted to double-check before I release something that may give users a nervous-jerkdown. tongue big_smile
So, my question is...which is correct to use in the sources.list?
EDIT: I used the "Expert Install" option of the netinstall...'cause I'm an expert n'stuff. smile
#2 2022-01-21 14:47:31
Re: Chimaera sources.list
Please use deb.devuan.org so that the load gets spread out over all the mirrors in the round-robin.
#3 2022-01-21 15:35:14
MiyoLinux
That's what I figured, but thank you for the confirmation sir. smile
#4 2022-01-22 11:54:35
My VM also had that line. Perhaps the netinstall ISO needs a preseed line to correct the source.
Something like
d-i preseed/late_command string in-target sed -i 's|//pkgmaster.|//deb.|' /etc/apt/sources.list
