#1 2022-01-15 18:31:30
Looking for a supported document scanner
Well, I want to scan a lot of private documents. My flatbed LIDE220 is fine for a few pages, for more stuff it takes too much time to feed the paper and to turn it if its double sided.
So I am searching for a Linux supported document scanner, holding 20-50 pages, duplex unit, preferred USB3 interface, maybe with ultrasound sensor for a double pull detection.
Suggestions welcome,
#2 2022-01-16 10:13:16
PedroReina
Re: Looking for a supported document scanner
I bought a document scanner when the lockdown here is Spain. I couldn't find what I exactly wanted, but at the end this worked for me:
Brother ADS-1200
Main advantage: I use the scanner without conexion to the computer, through a USB stick.
Main problem: I cannot run any Linux program to access the configuration of the to USB scanning. I have to use other OS (proprietary).
I have used this device succesfully and extensively. YMMV.
I think that more expensive Brother models with operation panel can be fully used without proprietary OS, but I'm not sure.
#3 2022-01-16 12:57:28
PedroReina wrote:
... cannot run any Linux program to access the configuration ...
Why not?
https://support.brother.com/g/b/oslist. … ds1200_all
See here: https://support.brother.com/g/b/downloa … ds1200_all
Drivers available (*.deb and *.rpm packages) for both 32 and 64 bit Linux:
See here: https://support.brother.com/g/b/downloa … all&os=128
That should (?) get you set.
Please let us know if it worked.  =^)
#4 2022-01-16 17:53:49
PedroReina
Thanks for your hints. I've been already there. All your URL works, but none of them allows configuration of the "Scan to USB".
That should (?) get you set. Please let us know if it worked.  =^)
Yes they do, but...
This means that Linux is supported. Yes, it is.
This means that you can download a deb file with the SANE backend. It works.
But I can't find any utility, CLI, GUI, free or proprietary to do this under Linux:
http://pedroreina.net/hardware/brothera … racion.png
Anyway, I'm happy with the scanner. It is small, not expensive and reliable.
#5 2022-01-16 18:51:33
I'm sorry, I understood you did not have Linux drivers.
PedroReina wrote:
... can't find any utility, CLI, GUI ...
See here:
https://support.brother.com/g/b/downloa … dlang=true
Read before downloading wrote:
Only installation via the command line interface (terminal) is supported.
It would seem that there isn't one for Linux, but can't say I'm surprised.
I use simple-scan 3.30.1.1-1+b1 amd64 with my trusty ca.1995 Umax S-6E, which is still going strong.
Easy to use and can save scans/series of scans (as *.pdf or *.png) to anything I have available.
But besides cropping, that's about it.
And, quite obviously, my box is definitely required.
#6 2022-01-16 19:53:13
PedroReina
No problem smile
See here:
This is the SANE backed, it is installed in my system, but the configuration of "Scan to USB" is a different kind of thing.
We are very few users. But if we knew the protocol, we could write our own utility. It seems a very simple task.
