#1 2022-01-15 01:37:35
Micronaut
Game Managers
Looking into running games in Linux, I have found some problems with some of the major options.
First, Play-on-Linux seems to have not updated for the current version of Debian. Their download page only describes how to install in Jessie and Stretch, not Buster even though that has been out for years. Has this project fallen into neglect?
Since there wasn't a good option for PlayOnLinux, I tried Lutris. This at least is up-to-date enough to have Buster support, and by inheritance Beowulf support. After some struggles to get all the components it expects installed (mostly Vulkan-related libraries), I tried to install a game and it complained that the location I wanted to use (the /opt partition) was not writable by the (normal) user I was logged into. Is it typical for these game managers to put everything into the /home directory?
So, if I prefer to keep the games in a separate partition, can I change the mount permissions for the /opt partition (it is a completely separate isolated partition) or is that considered a bad thing to do? I deliberately created it as a separate partition when setting up this install to make the game collection easier to manage.
How does Proton handle games that aren't packaged specifically for the OS, like most Windows titles would not be. Does it also put everything in /home?
#2 2022-01-15 02:11:41
Re: Game Managers
I would consider making the /opt/(game-name) folder part of the games group and then make the user a part of the games group.
#3 2022-01-15 02:14:57
Re: Game Managers
The current incarnation of PlayonLinux has been pretty much abandoned, AFAIK. Apparently there's a big 5.0 release in the works, but we've been waiting a while... Of course, If you want to contribute to that project, go nuts.
Well yeah, obviously. Like pretty much every other end-user application, Lutris inherits the permissions of the user launching it.
Either change permissions on /opt, or install your games somewhere that is writeable to your user.
It is typical for anything belonging to an unprivileged user to be in /home/$user/. That's how multi-user *nix operates, and has been since the '70s.
Windows games often put save files and configuration in their install directory, so unless you want to elevate to root every time you try to save... Yeah, put your user-writeable stuff in /home. That's what it's for.
You can do whatever you like, you have (g)root.
Yes. Specifically, games managed by steam land in /home/$user/.steam/steam/steamapps/common/.
Aside, if you do use steam, you might want to symlink that directory somewhere else. .steam is hidden, so it might save the irritation of trying to figure out what's eating space in /home in the future.
That's not a bad idea at all, the games group should already exist... Though its original purpose is to restrict who can play games, not install them. big_smile
#4 2022-01-16 20:33:22
Micronaut
Re: Game Managers
Hey, great idea! It should have occurred to me. I am familiar with basic *ix security controls. This way, it would be possible to have multiple users on a single machine able to play the installed games without needing multiple installs, too. (Not needed on my personal gaming machine, but still a cool thing...)
#5 2022-01-16 21:17:20
Micronaut
Re: Game Managers
One other thing I thought of. Having to download some of these large MMOs over my DSL connection would be too time-consuming. Is it possible to copy the game into a folder on the Linux install and get it recognized by the game manager? Or does the installer have to run to create the virtual Windows settings? -- Directories, registry, or whatever.
#6 2022-01-17 02:02:54
Re: Game Managers
Lutris allows you to manually add games.
If the game can be moved around like this and run without whatever registry stuff the installer does on Windows, the same is likely true for wine.
You will need to initialise the wine prefix of course (running winecfg or similar with $WINEPREFIX correctly set should do it), and if you want to use install scripts that set up dependencies and whatnot for you you'll probably have to fool them into thinking they've run some kind of installer.
I find that downloading and modifying the lutris install script to remove the installer reference usually works, and it's easier still if said script allows you to specify your choice of executable - just point it at something irrelevant and harmless so the install can proceed to set up the prefix, then copy your game files in.
None of this is officially supported of course, so YMMV. If you're not familiar with setting up and troubleshooting wine, it's probably best to stick with somebody else's install scripts.
#7 2022-01-21 23:33:47
Micronaut
Re: Game Managers
Just putting the directly in the 'games' group was not enough. Something in Lutris checks the ownership of the directory and refuses to proceed, so I had to actually chown the directory to the ordinary user. After that it would at least proceed and try to install. But there were more obstacles. sad First, it wanted something called Esync, which seems to be related to systemD, but there is an alternative to manually edit a config file to create a huge limit on number of file handles you can have open at once. Then it wanted something called wine-mono which the Debian wiki says is not included in Debian, deliberately. Why not? It had to be downloaded from the Lutris site.
Then it was able to get the installer for Star Trek Online on the desktop. But when I click it, it just dies. The error log is this:
info:  Game: Star Trek Online.exe
info:  DXVK: v1.9.2-21-g2e66f45a
info:  Built-in extension providers:
info:    Win32 WSI
info:    OpenVR
info:    OpenXR
info:  OpenVR: could not open registry key, status 2
info:  OpenVR: Failed to locate module
info:  Required Vulkan extension VK_KHR_surface not supported
err:   DxvkInstance: Failed to create instance
info:    Win32 WSI
info:    OpenVR
info:    OpenXR
All I have been able to learn about these error messages is that it's related some something missing. There still isn't enough stuff installed. But I can't find anything else related to Vulkan to install. Is there something else missing in Debian/Devuan?
#aptitude search vulkan
p   libvulkan-dev                   - Vulkan loader library -- development files
p   libvulkan-dev:i386              - Vulkan loader library -- development files
i A libvulkan1                      - Vulkan loader library
i   libvulkan1:i386                 - Vulkan loader library
i   mesa-vulkan-drivers             - Mesa Vulkan graphics drivers
i   mesa-vulkan-drivers:i386        - Mesa Vulkan graphics drivers
p   nvidia-legacy-390xx-nonglvnd-vu - NVIDIA Vulkan ICD (non-GLVND variant) (390
p   nvidia-legacy-390xx-vulkan-icd  - NVIDIA Vulkan installable client driver (I
p   nvidia-legacy-390xx-vulkan-icd: - NVIDIA Vulkan installable client driver (I
p   nvidia-nonglvnd-vulkan-common   - NVIDIA Vulkan driver - common files (non-G
p   nvidia-nonglvnd-vulkan-common:i - NVIDIA Vulkan driver - common files (non-G
p   nvidia-nonglvnd-vulkan-icd      - NVIDIA Vulkan ICD (non-GLVND variant)
p   nvidia-nonglvnd-vulkan-icd:i386 - NVIDIA Vulkan ICD (non-GLVND variant)
i A nvidia-vulkan-common            - NVIDIA Vulkan driver - common files
p   nvidia-vulkan-common:i386       - NVIDIA Vulkan driver - common files
i A nvidia-vulkan-icd               - NVIDIA Vulkan installable client driver (I
i   nvidia-vulkan-icd:i386          - NVIDIA Vulkan installable client driver (I
v   nvidia-vulkan-icd-any           -
v   nvidia-vulkan-icd-any:i386      -
v   vulkan-icd                      -
v   vulkan-icd:i386                 -
i   vulkan-tools                    - Miscellaneous Vulkan utilities
p   vulkan-tools:i386               - Miscellaneous Vulkan utilities
p   vulkan-utils                    - transitional package
v   vulkan-utils:i386               -
p   vulkan-validationlayers         - Vulkan validation layers
p   vulkan-validationlayers:i386    - Vulkan validation layers
p   vulkan-validationlayers-dev     - Vulkan validation layers -- development fi
p   vulkan-validationlayers-dev:i38 - Vulkan validation layers -- development fi
#8 2022-01-21 23:50:59
Micronaut
Re: Game Managers
Just for giggles I tried to install Grand Theft Auto 5, meaning I tried to install the Epic Games installer, which could then (hopefully) install it. Got a wild string of error messages and this also crashed:
Wine cannot find the FreeType font library.  To enable Wine to
use TrueType fonts please install a version of FreeType greater than
or equal to 2.0.5.
http://www.freetype.org
0144:err:unwind:check_bpf_jit_enable BPF JIT is not enabled in the kernel, enable it to reduce syscall emulation overhead.
013c:err:user:load_desktop_driver failed to load L"winex11.drv"
or equal to 2.0.5.
0158:err:user:load_desktop_driver failed to load L"winex11.drv"
0158:fixme:sfc:SRSetRestorePointA 0032FB30 0181E6C4
0158:err:winediag:gnutls_process_attach failed to load libgnutls, no support for encryption
0158:err:winediag:process_attach failed to load libgnutls, no support for pfx import/export
0158:fixme:cryptasn:CRYPT_GetBuiltinDecoder Unsupported decoder for lpszStructType 1.3.6.1.4.1.311.2.1.4
0158:fixme:wintrust:SOFTPUB_VerifyImageHash Cannot verify hash for pszObjId="1.3.6.1.4.1.311.2.1.25"
0158:err:bcrypt:key_asymmetric_create no encryption support
0160:err:unwind:check_bpf_jit_enable BPF JIT is not enabled in the kernel, enable it to reduce syscall emulation overhead.
0168:err:unwind:check_bpf_jit_enable BPF JIT is not enabled in the kernel, enable it to reduce syscall emulation overhead.
0170:err:unwind:check_bpf_jit_enable BPF JIT is not enabled in the kernel, enable it to reduce syscall emulation overhead.
0178:err:unwind:check_bpf_jit_enable BPF JIT is not enabled in the kernel, enable it to reduce syscall emulation overhead.
0180:err:unwind:check_bpf_jit_enable BPF JIT is not enabled in the kernel, enable it to reduce syscall emulation overhead.
0188:err:unwind:check_bpf_jit_enable BPF JIT is not enabled in the kernel, enable it to reduce syscall emulation overhead.
0158:err:module:open_builtin_so_file failed to load .so lib "/home/quixote/.local/share/lutris/runners/wine/lutris-fshack-6.21-6-x86_64/lib/wine/i386-unix/xactengine2_0.dll.so"
Monitored process exited.
Initial process has exited (return code: 63232)
Exit with return code 63232
#9 2022-01-22 02:41:15
Re: Game Managers
It has nothing to do with systemd.
Many windows applications (especially games) like to use zillions of mutexes for synchronisation, this is not particularly well supported or performant on GNU/Linux, largely because native applications tend to use other methods.
Wine has three approaches for dealing with this: Internal emulation, which is slow, esync, which fakes it using filesystem calls but requires you to raise the maximum number of open file handles in /etc/security/limits.conf, or kernel futex support (fsync), which requires patches as I mentioned some posts back but provides near-native performance.
You don't strictly need esync or fsync, but IIRC lutris defaults to enabling esync for performance reasons. Failing to either turn this off in lutris or raise the open files limit will likely result in the kernel summarily killing your wine application.
Probably because it doesn't fit Debian's packaging requirements. It's documented in the wiki and readily available though. vOv
You have DXVK enabled for this game in lutris, but DXVK can't find the vulkan extensions it requires.
My guess (assuming you have GPU drivers installed and functioning correctly), is that the game you are trying to run is 32bit, your wine prefix is 32bit, and you are missing the 32bit vulkan libraries.
Maybe missing 32bit libgnutls, maybe missing .NET or other dependencies within wine...
Was this using the lutris install script?
I've never had any interest in the series in general, so I can't offer any specific advice for that game. The lutris script looks like it installs a bunch of stuff with winetricks to get the Epic Launcher (crapware I have no time for TBH) to run though.
In any case, you'd probably be better served by the lutris board and / or winehq for problems like this, they have far more to do with wine than Devuan. If this board had an "Unsupported Software" sub (kinda surprised it doesn't TBH), that's where Windows applications would belong.
Personally, I make a point of checking winehq and the lutris script repo to see if anyone has managed to get a particular game working before spending (and potentially wasting) any time on it.
#10 2022-01-22 12:03:53
Re: Game Managers
The OP already has the 32-bit Vulkan packages installed and anyway I think the error is referring to the video driver rather than the Vulkan libraries.
@OP: check your Vulkan support with
vulkaninfo --summary
And check the actual loader with
ls /usr/share/vulkan/icd.d/
^ That should show both 32- & 64-bit NVIDIA .json files for the ICD loader.
It could be that the legacy NVIDIA drivers just don't support this.
+1
#11 2022-01-28 21:20:11
Micronaut
Re: Game Managers
Success! I found discussions on other boards about all the copious dependencies of the Vulkan libraries and got a list of things to install:
libgl1-mesa-dri:i386
mesa-vulkan-drivers
gstreamer1.0-gtk3:i386
libgtk-3-bin:i386
librsvg2-common:i386
libasound2-plugins:i386
libsdl2-2.0-0:i386
libdbus-1-3:i386
libsqlite3-0:i386
Yes, I already had the Vulkan-drivers packages installed. I just cut & paste the whole list and that worked. smile Obviously, it just skipped what I already had installed.
After this, the Star Trek Online installer did not barf and exit. It downloaded the launcher. I was then able to copy the game files I already had from the Windows install and after fiddling with some config settings to get the launcher to understand where the game files were, it was able to start and run the game. It plays fine so far, though I haven't gone into any large battles yet.
Next up: Lord of the Rings Online! The obstacle right now is installing fonts that Lutris thinks it needs. But if I can get that one to work, I think I can abandon Wind'ohs completely...
#12 2022-01-29 04:10:44
Micronaut
Re: Game Managers
Success again! It took some fiddling with winetricks but the installer finally ran. LOTRO now runs on the same system as STO, and there aren't any other serious games I am worried about. It's late so I'll have to wait till tomorrow to try the plugins, but I don't see why they wouldn't work if I just put them in the right place under the simulated Windows system directories.
The remaining issue is that it isn't simple to setup an equivalent of Afterburner in Linux. Or is it? Can you install Afterburner in Wine? smile I don't think the default settings on most cards keep them cool enough.
#13 2022-01-29 11:54:11
Re: Game Managers
Probably, but I doubt it will be very useful as it depends on the native Windows drivers to access the hardware.
If fan and clock controls are what you're after, IIRC (I don't have any nvidia cards any more) that stuff is available in the GNU/Linux native nvidia control panel after setting the appropriate "coolbits" values. Check the arch wiki and/or the documentation that comes with the driver for details.
#14 2022-01-30 02:29:53
Micronaut
Re: Game Managers
The default controls, I presume embedded in the video BIOS, don't work very well. The card regularly goes over 60 C and that's too high in my opinion. It is possible to enable manual control, but that's very crude. You have to set it to a very high level that will be needed when you are at maximum load (in heavy combat, basically) and let it whir along at that speed all the time you are playing the game. Rotating through open windows to check your video card temp is a bit too much extra multitasking while gaming.
Hopefully there is an Afterburner equivalent from a reliable source out there somewhere. It's odd that there is so much variability in the detection of video card temperature and fan sensors. I've had the same cards on different machines and sometimes the sensors can be found and sometimes not. But the info must be available, because the Noveau drivers can usually find the temp sensor.
#15 2022-01-30 10:46:40
Re: Game Managers
60c is fine for any modern GPU, most won't even downclock until they hit 90+. Hell, 60c is fine for my 1998 Banshee.
I can't speak to noveau, but IIRC the proprietary nvidia drivers expose temperature and fan speed info via nvidia-smi, and allow setting fan speeds with nvidia-settings.
This would be much easier if they just put stuff in /sys like every other GPU driver, but whatever. It's Nvidia, they don't believe in standards.
It shouldn't be particularly difficult to script a fan curve controller in shell, have a look at this and this for inspiration. Dunno if they actually work as I don't have an nvidia GPU to play with, but both look pretty legit to me.
Oh yeah, there's also this shiny thing. I've used it on Gentoo in the past, and it does what it says on the tin. Don't think it's packaged for Debian though, so you'd need to compile it yourself or (shudder) install it as a flatpak.
#16 2022-02-02 03:41:44
Micronaut
Re: Game Managers
Yeah, those scripts look quite a bit like a re-write of fancontrol. smile Right now I'm still learning many things and the BIOS controls are sufficient to keep it from melting down. Once I've settled some other questions, I'll definitely be trying those scripts out.
#17 2022-02-18 23:03:51
Micronaut
Re: Game Managers
As nicely as the games run most of the time, they do have problems. At least in the current install I am using. Using a different distro, MX Linux, and on a different system, I find that these problems don't seem to occur (yet). Maybe it was a mistake to use the install method recommended on the Lutris website? They give directions to import an Open SUSE repository even though there is a Lutris package in the Debian/Devuan repositories. I'll be making a new build to test the native Lutris package soon.
