#1 2021-12-24 12:56:08
devian
KDE Discover does not allow software update checking to be disabled
I would like to disable automatic checking for updates which KDE does through the Discover application and presents a pop up tray icon when updates are available. I want to do this manually.
There is an apparent bug in that if I do Alt-F2 and run Discover, I find that clicking on "Software Sources" and entering my password, does absolutely nothing. Please see image below:
The final answer on this page describes what I should see:
https://superuser.com/questions/267302/ … kde-debian
Namely:
"Once you have entered your administrator password, Discover's software sources and settings window will open. This window has a tab called Updates."
Anyone know another way to disable update checking in KDE? Thanks.
