#1 2021-11-13 02:16:38
Job
[SOLVED] What is wrong with chimaera and network
Hello forum.
Since moving to chimaera, I only have problems with the network interface.
At some point I only had
iface eth0 inet dhcp
in /etc/network/interfaces. After about two days, the network died again. Since then no matter what I tried I can't get the internet going.
I will appreciate some pointers.
#2 2021-11-13 03:18:47
Re: [SOLVED] What is wrong with chimaera and network
It sounds like you should make sure all "network manager" software except ifupdown is purged, and then edit your /etc/network/interfaces to be (exactly):
iface lo inet loopback
auto lo eth0
#3 2021-11-13 13:11:09
If Ralph's suggestion doesn't fix things for you then please post the output of
# ifup --verbose eth0
#4 2021-11-13 20:05:47
Job
I powered that box to try your suggestions and it went online right away. Here is the setup I have now. Strange stuff, this same setup did not work last night.
auto lo
#the primary network interface
auto eth0
allow-hotplug eth0
Anyway:
Ralph, do you mind expanding on what you meant by purging "all "network manager" software except ifupdown? Do you mean manually removing everything in /etc/network and leaving the ifupdown folder?
HoaS,
root@luna:~# ifup --verbose eth0
ifup: interface eth0 already configured
I am guessing because the device is already busy.
#5 2021-11-13 20:18:42
I think Ralph wanted you to check for any other enabled networking services. The easiest way to do this is
# apt install sysv-rc-conf
# sysv-rc-conf
^ The second command will list all services and their state.
I'm pretty sure that NetworkManager, connman & wicd all check /etc/network/interfaces{,.d/*} and will ignore any interfaces listed there but it doesn't hurt to check and disable the services.
Your networking problem could have been caused by rfkill (is there a wireless button on your machine?) or possibly an over-zealous power saving mode for the wireless driver. The logs should show exactly what happened.
#6 2021-11-13 20:48:24
Job
The machine is a desktop with no wireless hardware or button. I have to say the trouble started after I woke up the machine from hibernation. I am not sure if hibernating the desktop could be a problem. I did not have that issue with Beowulf tho.
#7 2021-11-13 20:52:26
Oops, sorry. I will learn to read one day...
Is that reproducible? If so what do the logs say?
#8 2021-11-13 22:18:00
.. my longer story is something like the following.
Networking in chimaera is really the same as in all prior system versions; it's a kernel function to operate the interfaces that dynamically rely on their configurations, and there are some forms of user software available for the administration of those configurations.
The first and oldest unit of such software is nowadays called ifupdown in Devuan (Debian).
ifupdown implements an administration principle where the administrator documents their desired configurations using a special purpose scripting language written into one or more plain text files starting with /etc/network/interfaces. The software is modular with a core bit that offers the adminstration programs ifup, ifdown and ifstate as well as the hook-in to the boot process and the hotplug event handling. ifupdown also provides a well-documented API for extensions that allows for other software packages to be seamlessly incorporated into the networking operations as if belonging to ifupdown; e.g., handling DHCP, handling wireless connectivity, VPN setup and whatnot.
On the side of that we find a couple of network management software packages (package groups), where chimaera in particular includes the two named connman and network-manager. These implement their own ideas of the network configuration task, with a common aim to make networking configuration be administrated "more easily" than by using the special purpose scripting language and programs of ifupdown, and most importantly to provide a "security bypass" that empowers non-root users with network administration abilities.
A side effect of that is that the network management software "wants to rule the city". Then "traditional" administration via ifupdown might be in conflict with it, unless one knows enough about the management software to avoid such conflicts. The easiest way for a root administrator to avoid such conflicts  is to get rid of all and any such management software.
#9 2021-11-13 22:47:42
Job
I let the box hibernate to see if I can reproduce the same scenario but the box and the interface came back on right way.
#10 2021-11-13 22:49:26
Job
Noted. Thank you,
