#1 2021-10-29 18:06:59
[SOLVED] apt and residual files
I run Devuan Beowulf on an Asus 1000HE netbook, used only for coffee roasting duty or to take along if I am out of town.
root@eee-dev3:~# uname -a
Linux eee-dev3 4.19.0-18-686-pae #1 SMP Debian 4.19.208-1 (2021-09-29) i686 GNU/Linux
root@eee-dev3:~#
Being rather limited (Atom 280+2Gb), I try to keep it thin and free of stuff I don't need/want.
Recently I cleaned up a lot of residual files but I have come across a couple of rather stubborn ones:
root@eee-dev3:~# apt list | grep residual
residualvm-data/oldstable 0.3.1+dfsg-1 all
residualvm/oldstable 0.3.1+dfsg-1 i386
root@eee-dev3:~#
I have no idea as to where these two came from as I have never installed anything related to them.
eg: 3D games, etc.
I cannot seem to get a reasonable answer to this:
oot@eee-dev3:~# apt remove --purge residualvm
Building dependency tree
Package 'residualvm' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
root@eee-dev3:~#
oot@eee-dev3:~# aptitude why residualvm
Not currently installed
The candidate version 0.3.1+dfsg-1 has priority optional
No dependencies require to install residualvm
root@eee-dev3:~#
Independently of how this file happened to be (?) in my system, how can I get rid of it?
Thanks in advance,
#2 2021-10-30 06:30:57
hevidevi
Re: [SOLVED] apt and residual files
Yeah i have this as well, the package is not installed but still comes up with your command
Mine says this using stable chimaera...
residualvm-data/stable 0.3.1+dfsg-2 all
residualvm/stable 0.3.1+dfsg-2 amd64
Quick debian package search and its a lucas arts game config or something??
Package: residualvm (0.3.1+dfsg-2)
interpreter to play LucasArts' Lua-based 3D adventures
https://packages.debian.org/bullseye/residualvm
weird!
edit: i think i understand why now, your command using apt list is picking up the repository contents, so when you grep any package you dont have it will come up, this just happens to be residualvm because you are using residual as a search term.
#3 2021-10-30 06:43:13
hevidevi
use dpkg -l like so to search for unneeded config files.
dpkg -l | grep ^rc
then remove them like this.
sudo apt purge '~c'
#4 2021-10-30 08:11:23
@Altoid, perhaps you where thinking
apt list --installed
#5 2021-10-30 11:45:44
hevidevi wrote:
... understand why now ...
Quite so ...
Result of not enough (or too much) coffee.  8^|
dpkg -l | grep ^rc
Came up empty, as it should.
sudo apt purge "~c"    <-- double quotes.
Nothing to purge.
Hmm ..
No, I was quite evidently not thinking, at least not coherently.
I started doing it right ie: with dpkg -l ...  but at some point wandered into apt list | grep residual ...  8^|
What else could have come up but a file named "residual"?
Thank you both for your input.
Have a good week-end.
