#1 2021-10-19 22:35:18
supusr
[SOLVED] Correct Distribution Name in Conky
I have come over from Debian.  Using my old Debian conky config works except for the line to show the distribution:
Distro: ${alignr}${distribution}
This yields Debian, not Devuan.  Is there a way to have it display Devuan GNU/Linux 4 (chimaera)?  If it helps, the info I want to display (the pretty name} is in the 1st line of the output of: cat /etc/os-release
Thanks, in advance.
Non-technical user, but Linux only since 2012.  Retired union business agent.  Avid reader.  Leftie.  English-Spanish.
#2 2021-10-20 05:07:48
Re: [SOLVED] Correct Distribution Name in Conky
Distro: Devuan
Or you could file a bug report for this against conky (upstream would be best, remember to test the latest release first to see if it's already fixed) or cut the information out of /etc/os-release but I really don't see the point of using a dynamic status indicator to display static information.
#3 2021-10-20 19:04:33
supusr
Head_on_a_Stick, thanks very much for the reply and the opinion.  To be more clear, my question should have been: Can someone tell me how to generate the cut information from /etc/os-release?  I am sorry I was not precise enough the first time.
#4 2021-10-20 20:08:20
Try
awk -F'=|"' '/PRETTY/{print $3}' /etc/os-release
But I can't test that 'cos I'm posting this from Windows.
EDIT: remove quotation marks from output. Hopefully :-)
EDIT2: fixed command, thanks Ralph.
#5 2021-10-20 22:16:47
Works with $3 rather than $2.
Another way could be:
echo '. /etc/os-release ; echo $PRETTY_NAME' | sh
#6 2021-10-21 14:17:02
supusr
Thanks very much Head_on_a_Stick and ralph.ronnquist.  I'm back on Debian for the moment for other reasons, but I'm sure these replies will help me resolve my conky issue when I return to Devuan.  I really like the idea of Devuan.
