#1 2021-10-11 16:40:51
einpoklum
How should I open up another port / set up extra firewall rules?
I'm using Devuan Chimaera on a (physical) machine of mine.
I am running an app which needs to take incoming connections over some TCP port (say 5123). I had (mistakenly) assumed my ports would be open by default if I listened on them - since SSH to my machine to other, and I haven't done anything to open up port 22. However - that's not the case. It's not even the case for sshd itself: If I add a Port 5123 statement to /etc/sshd_config, I can ssh through port 5123 from localhost, but not from other machines.
So, I started looking into the Linux firewall business, which I haven't really touched for many years; and specifically to the situation on Devuan (without me having installed any special relevant packages).
It seems that there are some "legacy iptables" rules in effect; iptables-legacy-save yields:
*filter
:INPUT DROP [23:3096]
:FORWARD DROP [0:0]
:OUTPUT ACCEPT [21257:2268987]
-A INPUT -m state --state INVALID -j DROP
-A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
-A INPUT -i lo -j ACCEPT
-A INPUT -p icmp -j ACCEPT
-A INPUT -p udp -m udp --dport 500 -j ACCEPT
-A INPUT -p esp -j ACCEPT
-A INPUT -p ah -j ACCEPT
-A INPUT -p tcp -m tcp --dport 22 -j ACCEPT
-A FORWARD -m state --state INVALID -j DROP
-A FORWARD -m state --state RELATED,ESTABLISHED -j ACCEPT
-A OUTPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
COMMIT
but nothing with nft flush ruleset.
Now, I'm able to manually write an extra iptables rule for the port I want. But - I don't know where and when these rules are applied, so that I could add to them in a persistent manner. I'm also able (I think) to generate an /etc/nftables.conf to suit my needs - but that doesn't get loaded at all (AFAICT). I could ensure it's loaded with an /etc/init.d to load it, but - that would clash with whatever loads the iptables rules right now, wouldn't it?
So, bottom line: How should I add another persistent rule for opening additional ports?
#2 2021-10-12 11:09:30
kjpetrie
Re: How should I open up another port / set up extra firewall rules?
man iptables-legacy
for more information.
What do
ls /etc/*tables*
and
/etc/init.d/*tables*
show?
#3 2021-10-12 17:27:57
einpoklum
@kjpetrie: There's an /etc/nftables.conf , and nothing in /etc/init.d.
I had a look at the man page for iptables-legacy and it didn't tell me much; are you suggesting rules be added using this binary? Ok, that sounds reasonable; but it's only half the answer: Where/how are the existing rules added?
Edit: Oh, I think I've found a partial solution. Your grepping suggestion gave me the idea:
# grep -r iptables *
default/ferm:# use iptables-restore for fast firewall initialization?
multitail.conf:# linux iptables firewall
the second line is a dud, but the first is part of a package called ferm, and its /etc/ferm/ferm.conf has syntax which would translate into almost all of the rules on my system:
domain (ip ip6) {
    table filter {
        chain INPUT {
            policy DROP;
            # connection tracking
            mod state state INVALID DROP;
            mod state state (ESTABLISHED RELATED) ACCEPT;
            # allow local packet
            interface lo ACCEPT;
            # respond to ping
            proto icmp ACCEPT;
            # allow IPsec
            proto udp dport 500 ACCEPT;
	    @if @eq($DOMAIN, ip) {
	      proto (esp ah) ACCEPT;
	    } @else {
	      proto (esp) ACCEPT;
            # allow SSH connections
            proto tcp dport ssh ACCEPT;
        chain OUTPUT {
            policy ACCEPT;
            #mod state state INVALID DROP;
        chain FORWARD {
            policy DROP;
I think only the SSH port being open is unaccounted for in this file. Where could it be coming from?
#4 2021-10-12 21:57:09
