#1 2021-09-30 15:28:38
alphalpha
How does devuan choose which video drivers it uses?
So i always have a multiple drivers installed on my system, because i use the iso on multiple machines
vesa, intel, nouveau, radeon etc
Since there is no config file in /etc/X11 that specifically states what to use, i am actually not sure which one of those i might be using at the moment
It has always worked fine for me until last week when i had a new machine (old hardware) and i had to specifically tell it to use the intel driver
So i am asking myself, how does the system decide what to use when there is no config file?
#2 2021-10-09 13:04:38
hevidevi
Re: How does devuan choose which video drivers it uses?
#3 2021-10-09 14:41:57
For the kernel drivers udev will (hopefully) detect the hardware and load the appropriate driver.
X also probes the hardware to determine the correct DDX & Mesa drivers. Don't use Xorg --configure, it's useless. Just write your own configuration snippets if you need to change any of the autodetected options.
EDIT: for Intel hardware you should be using the modesetting DDX driver because it's far less buggy than Intel's option. That's why you had to force the Intel driver wink
#4 2021-10-09 15:08:52
hevidevi
xorg -configure is not useless. You can use it to further tweak your X settings.
If it was useless then why is it a part of the Debian wikipedia.
If xorg.conf is missing for some reason, Xorg will probe your hardware on every startup. Though this works fine in most cases, some settings remain inaccessible. To create a starting point for customization, do the following.
Switch to a console as root (not a terminal emulator in X), then run:
# /etc/init.d/gdm stop || /etc/init.d/gdm3 stop || /etc/init.d/kdm stop || /etc/init.d/xdm stop || /etc/init.d/lightdm stop
$ cd /etc/X11/
# Xorg -configure
#5 2021-10-09 15:14:17
Because the advice on that page is ancient and hasn't been updated to reflect the current situation.
All of the (DDX) video drivers supply their own configuration snippets that can be copied and modified as needed so there really is no need fot the --configure option at all.
EDIT:
empty@P14s:~ $ ls /usr/share/X11/xorg.conf.d/
10-amdgpu.conf  10-quirks.conf  10-radeon.conf  40-libinput.conf  70-wacom.conf
empty@P14s:~ $
^ Copy any of those files to /etc/X11/xorg.conf.d/ and modify them as needed.
#6 2021-10-09 15:16:58
hevidevi
But it successfully describes the usage of X on my system.
#7 2021-10-09 15:19:21
hevidevi
EDIT:
empty@P14s:~ $
Okay and if some of those files are not present?
~ > ls /usr/share/X11/xorg.conf.d/
10-quirks.conf  40-libinput.conf  70-synaptics.conf
#8 2021-10-09 15:21:50
Write your own configuration snippet. It's not difficult.
EDIT: let's just agree to disagree about this and let the OP make their own mind up. I don't have the energy to argue.
#9 2021-10-09 15:22:51
hevidevi
So you are saying Xorg -configure is useless in my situation?
#10 2021-10-09 15:27:49
What do you actually want to change?
#11 2021-10-09 15:30:36
hevidevi
well that is not what the OP was asking, i dont want to change anything but Xorg -configure will give a conf file to see what is configured.
example:
Section "ServerLayout"
	Identifier     "X.org Configured"
	Screen      0  "Screen0" 0 0
	InputDevice    "Mouse0" "CorePointer"
	InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
	ModulePath   "/usr/lib/xorg/modules"
	FontPath     "/usr/share/fonts/X11/misc"
	FontPath     "/usr/share/fonts/X11/cyrillic"
	FontPath     "/usr/share/fonts/X11/100dpi/:unscaled"
	FontPath     "/usr/share/fonts/X11/75dpi/:unscaled"
	FontPath     "/usr/share/fonts/X11/Type1"
	FontPath     "/usr/share/fonts/X11/100dpi"
	FontPath     "/usr/share/fonts/X11/75dpi"
	FontPath     "built-ins"
EndSection
Section "Module"
	Load  "glx"
EndSection
Section "InputDevice"
	Identifier  "Keyboard0"
	Driver      "kbd"
EndSection
	Identifier  "Mouse0"
	Driver      "mouse"
	Option	    "Protocol" "auto"
	Option	    "Device" "/dev/input/mice"
	Option	    "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
	Identifier   "Monitor0"
	VendorName   "Monitor Vendor"
	ModelName    "Monitor Model"
EndSection
Section "Device"
        ### Available Driver options are:-
        ### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
        ### <string>: "String", <freq>: "<f> Hz/kHz/MHz",
        ### <percent>: "<f>%"
        ### [arg]: arg optional
        #Option     "SWcursor"           	# [<bool>]
        #Option     "HWcursor"           	# [<bool>]
        #Option     "NoAccel"            	# [<bool>]
        #Option     "ShadowFB"           	# [<bool>]
        #Option     "VideoKey"           	# <i>
        #Option     "WrappedFB"          	# [<bool>]
        #Option     "GLXVBlank"          	# [<bool>]
        #Option     "ZaphodHeads"        	# <str>
        #Option     "PageFlip"           	# [<bool>]
        #Option     "SwapLimit"          	# <i>
        #Option     "AsyncUTSDFS"        	# [<bool>]
        #Option     "AccelMethod"        	# <str>
        #Option     "DRI"                	# <i>
	Identifier  "Card0"
	Driver      "nouveau"
	BusID       "PCI:1:0:0"
EndSection
Section "Screen"
	Identifier "Screen0"
	Device     "Card0"
	Monitor    "Monitor0"
	SubSection "Display"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
#12 2021-10-09 15:37:44
From the man page (added emphasis):
-configure
               When this option is specified, the Xorg server loads all  video
               drive  modules, probes for available hardware, and writes out
               an initial xorg.conf(5) file based on what was detected. This
               option currently has some problems on some platforms, but in
               most cases it is a good way to bootstrap the configuration
               process.
So watch out for that wink
#13 2021-10-09 15:42:48
hevidevi
-configure
               process.
Pays to read the documentation, what platforms?
#14 2021-10-09 15:46:59
Doesn't say.
I don't like the -configure option for the same reason I don't like most abstractions — they introduce the possibility of new bugs and vulnerabilities whilst adding no new features. Why would anybody want that? hmm
#15 2021-10-09 15:55:38
hevidevi
Doesn't say.
Ive never had an issue with it, maybe newer hardware might.
