#1 2021-09-28 19:33:47
Lovuan
[SOLVED] Chimaera Mate OpenRC - time settings GUI
Dear all,
when I open control center and go to Time and Date settings, I get this error:
The name org.freedesktop.timedate1 was not provided by any .service files
I found a similar thread in the Artix forum here:
https://forum.artixlinux.org/index.php/topic,465.0.html
The solution seems to be to install the package
openrc-settingsd
but I cannot find it in the Chimaera repos, nor in the Ceres repos. Is there any way to install it in Devuan? I even wouldn't mind compiling it from source if someone could give me a brief heads-up on how to do this (and where to download).
Best
Lovuan
#2 2021-09-28 20:10:00
Re: [SOLVED] Chimaera Mate OpenRC - time settings GUI
Probably no Debian package?
I get the same error on my wife's PC (Chimaera, openrc, MATE). When I klick ok, I get the dialogue.
No issue on my PC with Chimaera, openrc, Cinnamon.
#3 2021-09-28 20:24:56
Lovuan
Thanks rolfie for your reply!
After some fiddling I managed to get it working. I found a download source:
https://gitlab.com/postmarketOS/openrc- … .0.tar.bz2
and compiled it following the explanation in this forum entry:
https://unix.stackexchange.com/question … rom-source
(had to fix some missing build dependencies though) - and lo and behold, after a reboot it works as expected.
I'm aware that this is not an official way as it bypasses the Devuan repos, but for the time being it fixed the issue.
Lovuan
Edit: You were right rolfie, there is no Debian package available, only for Arch/Artix, Gentoo, Alpine and some others:
https://repology.org/project/openrc-settingsd/versions
