#1 2021-09-27 07:41:39
xinomilo
Unknown
[SOLVED] repos not syncing
morning @ll,
seems like devuan repos are stuck for a few(?) days now. no new updates coming in, even though debian repos have lots of updated packages.. maybe something's "stuck" ? using testing/ceres.
thx,
#2 2021-09-27 14:49:16
xinomilo
Unknown
Re: [SOLVED] repos not syncing
seems unstuck now, upgraded 129 packages for ceres.
#3 2021-09-27 22:29:34
Yes. Basically amprolla's package update process had locked up; most likely due to the network traffic shaping I had set up which ignored the one "brittleness" in the tcp protocol, that packet drop during its tear-down handshake might cause the client end to hang.
