#1 2021-09-15 20:30:01
torquebar
[SOLVED] jack server no start: "hw:II" (No such dev)
I can't tell if this is a hardware recon issue or what.
This is on an asus g73 ROG laptop, haven''t tried
it on my desktop yet.
The complete error message when attempting to
start qjackctl is:
________________________________________
16:27:31.238 Statistics reset.
16:27:31.244 ALSA connection change.
16:27:31.252 JACK is starting...
16:27:31.253 /usr/bin/jackd -dalsa -r48000 -p1024 -n2 -D -Chw:II -Phw:II,0
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
16:27:31.273 ALSA connection graph change.
Cannot create RT messagebuffer thread: Operation not permitted (1)
Retrying messagebuffer thread without RT scheduling
Messagebuffer not realtime; consider enabling RT scheduling for user
no message buffer overruns
16:27:31.280 JACK was started with PID=4603.
jackdmp 1.9.12
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2016 Grame.
Copyright 2016-2017 Filipe Coelho.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK server starting in realtime mode with priority 10
self-connect-mode is "Don't restrict self connect requests"
Cannot lock down 82280346 byte memory area (Cannot allocate memory)
control open "hw:II" (No such device)
creating alsa driver ... hw:II,0|hw:II|1024|2|48000|0|0|nomon|swmeter|-|32bit
ALSA lib pcm_hw.c:1822:(_snd_pcm_hw_open) Invalid value for card
ALSA: Cannot open PCM device alsa_pcm for playback. Falling back to capture-only mode
Cannot initialize driver
JackServer::Open failed with -1
Failed to open server
16:27:31.319 JACK was stopped
16:27:33.471 Could not connect to JACK server as client. - Overall operation failed. - Unable to connect to server. Please check the messages window for more info.
______________________________________________________________________
Who, has loved us more?
#2 2021-09-17 03:59:05
torquebar
Re: [SOLVED] jack server no start: "hw:II" (No such dev)
_
desktop is good (different hardware)
#3 2021-09-18 18:00:56
What is the output from the following commands?
cat /proc/asound/cards
aplay -l
aplay -L
lspci
#4 2021-09-18 18:44:57
torquebar
I put it up here (1 week) where it doesn't get scrambled (didn't try here):
https://paste.opensuse.org/2213c656
the top half is Devuan, the bottom half Suse Leap-15.3
Not likely to be a factor but under Leap I have qjackCtl set
up to run  *pajackconnect.bsh* at start and stop.
#5 2021-09-18 21:19:55
You only have two audio interfaces, so I would expect them to be labeled hw:0 and hw:1
Do you want to use the on-board audio or the nvidia?
#6 2021-09-18 22:16:08
torquebar
I think one of them is HDMI, beyond that it's chinese 2 me
I went to the Leap install and took pictures of the setup pages,
comparing them I saw that on the Devuan install it showed
Output Device: hw:II,0
Imput Device: hw:II
Changing both to (default) fixed the prob.
I haven't done the Leap setup for ages (probably
just copied the home folder with each upgrade) so
I don't know where those '(default)' settings came from.
Thanks for giving me a hunch...
