Hi! im using devuan with the runit init system and everything went smooth, but i cannot figure out how to manage the bevaviour of the 'lid close' suspend, because i want the computer to remain active if i don't tell it to suspend, so the default behaviour of suspend-on-close is not what i want. How can i manage that using runit? i found how to make it in sysvinit but not for runit. Thanks!
EDIT: Solved it, found solution here https://dev1galaxy.org/viewtopic.php?id=2021
I think the simplest fix would be to completely disable the laptop lid detection. Here is what I already did:
1. HandleLidSwitch=ignore in /etc/elogind/logind.conf
2. IgnoreLid=true in /etc/UPower/UPower.conf
3. delete /etc/acpi/events/lid-acpi-support
4. reboot
