#1 2021-09-08 00:09:31
durham
recommend a good email prgram
Before Devuan, I was using seamonkey for email. There is no seamonkey in Devuan repos, so what is everyone using as their email program?
Thank you.
A dangerous technology is one that is available only to an elite group  -- George M. Ewing, Analog, April 1977
#2 2021-09-08 01:41:48
snork
Re: recommend a good email prgram
There is no reason you can't continue to use SeaMonkey.  It is actively developed, available for download at seamonkey-project.org, a pretty capable email client, and should work fine on Devuan (as long as you are on an x86 or x64 machine).
PS: I guess to actually answer your question... I use Thunderbird v3.1.20, but that story is much more complicated than just downloading SeaMonkey. :-)
#3 2021-09-08 02:54:35
durham
I'd rather Getting Seamonkey Installed be its own thread, but I will say this much: I downloaded the binary and it had a nonsense error where it said a library that did exist did not exist.
Thank you for the reply.. One vote for Thunderbird, then.
#4 2021-09-08 09:08:02
PedroReina
It may not be as silly as it sounds; they are usually different versions, names o links of what seems the same library. Have you tried ldd yourbinary?
#5 2021-09-08 16:11:47
Quoting the full text of the error message would be likely to get you a better response.
#6 2021-09-09 05:14:39
Claws on my XFCE netbook, Kmail on my KDE desktop, and roundcube webmail if I'm working remotely. All talking to my self-hosted (devuan, obviously wink) imap server.
#7 2021-09-09 08:56:09
mutt
#8 2021-09-09 10:20:29
Geoff 42
I use Claws and have the Dillo HTML viewer plugin in Beowulf. If you have Chimaera, then you can also install the LiteHTML viewer plugin, which probably displays the message more as the  sender intended. I usually display messages as plain text, but sometimes use the Dillo plugin to check what was in the HTML version of the message.
I also installed Evolution and Thunderbird when I was checking for the one I liked the best and still have them available.
Geoff
#9 2021-09-09 11:28:33
durham wrote:
... what is everyone using as their email program?
Everyone?
Nope, probably just me. 8^)
In my previous life as a MS OS user (DOS5.5 / W3.11 -> XPSP3), after a short run with the free version of Eudora, I switched to Pegasus Mail in early 1996.
Many years later, being able to use Pegasus Mail under Linux (via Wine) was one of the two deal-breaking programmes that made it possible to make a seamless switch to Linux and leave the MS OS environment for good, the other was Judd Montgomery's JPilot.
Once comfortably settled within Linux, I tried out most if not all the available options but none were good enough, Claws-Mail coming close.
But it simply did not have the same functionality I have come to appreciate in David Harris' free albeit not open source programme.
This year marks the 25th. I have been using Pegasus Mail and can only say it is quite solid and reliable, has never let me down.
Just my $0.02.
#10 2021-09-09 13:32:09
Evolution
#11 2021-09-09 16:21:59
andyprough
I hate it and it's not good and I don't recommend it - but Thunderbird. I agree with the Mutt slogan - "All mail clients suck. This one just sucks less."
Thunderbird does not suck less, but if you beat it hard enough with a tire iron, you can get it to send and receive a few emails for you. All other email programs besides Thunderbird are so horrendously bad that they will reduce your life expectancy by at least 10 years. Thunderbird will only reduce your life expectancy by 7 years. So it has that going for it.
#12 2021-09-10 17:26:31
James1138
You can install SeaMonkey browser using UbuntuZilla APT repository. This package will be updated on every apt upgrade.
You need to execute the following commands to add repository, its key and package installation:
cat <<EOF | sudo tee /etc/apt/sources.list.d/mozilla.list
deb http://downloads.sourceforge.net/projec … ozilla/apt all main
EOF
sudo apt-key adv --recv-keys --keyserver keyserver.ubuntu.com 2667CA5C
sudo apt-get update
sudo apt-get install seamonkey-mozilla-build
#13 2021-09-10 17:43:48
EOF
Leave that poor cat alone!
sudo tee /etc/apt/sources.list.d/mozilla.list <<!
deb http://downloads.sourceforge.net/project/ubuntuzilla/mozilla/apt all main
And are you sure the UbuntuZilla repository is compatible with Devuan? Most PPAs aren't.
#14 2021-09-10 19:24:51
andyprough
The tar download is right on the Seamonkey download page.
wget https://archive.mozilla.org/pub/seamonkey/releases/2.53.9/linux-x86_64/en-US/seamonkey-2.53.9.en-US.linux-x86_64.tar.bz2
tar -jvxf seamonkey-2.53.9.en-US.linux-x86_64.tar.bz2
cd seamonkey/
./seamonkey
Now you've got a working version of Seamonkey.
sudo ln -sf /home/[USER_NAME_GOES_HERE]/seamonkey/seamonkey /usr/local/bin/seamonkey
Now you've got Seamonkey on your PATH systemwide.
Make a .desktop file
sudo mousepad /usr/share/applications/seamonkey.desktop
Insert this text:
[Desktop Entry]
Version=1.0
Name=Seamonkey Web Browser
GenericName=Web Browser
Comment=Access the Internet
Exec=/usr/local/bin/seamonkey %U
StartupNotify=true
Terminal=false
Icon=/home/[USER_NAME_GOES_HERE]/seamonkey/chrome/icons/default/default32.png
Type=Application
Categories=Network;WebBrowser;
MimeType=application/pdf;application/rdf+xml;application/rss+xml;application/xhtml+xml;application/xhtml_xml;application/xml;image/gif;image/jpeg;image/png;image/webp;text/html;text/xml;x-scheme-handler/http;x-scheme-handler/https;x-scheme-handler/ipfs;x-scheme-handler/ipns;
Save and quit. Now you can put Seamonkey in your menus.
Easy.
