#1 2021-09-05 22:22:02
minimal-live chimaera beta isos
minimal-live isos are here for testing:
https://files.devuan.org/devuan_chimaera/minimal-live/
i386 and amd64 (bios only)
Almost forgot to mention that the list of (faster) mirrors is now linked at the bottom of the page.
#2 2021-09-06 05:40:55
larsH
Re: minimal-live chimaera beta isos
Hi
What is fixed or chaged from 30/08
Have a nice day
Lars H
#3 2021-09-06 11:48:24
These isos replace the July 21 alpha isos that were there. Newer kernel, some newer software since then, added rfkill and ceni. setnet.sh is still there, but is also still the old version.
Also, I added a uefi-compatible minimal-live iso. It will actually work on bios or uefi, same as the desktop-live amd64 iso.
#4 2021-09-06 13:15:35
larsH
Hi
Thank you for the info, I appreciate that :-)
Have a nice day
Lars H
#5 2021-09-10 20:54:25
cafinux
I've been using these,although I haven't done one onto bios but suspect they are fine due to earlier release. All seems to work as expected. cool
Only point I found was LXQT had to manually setup background etc. I don't know who that effects.
#6 2021-09-11 11:48:10
cafinux, are you saying you did a uefi install with the minimal-live iso? (This one: https://files.devuan.org/devuan_chimaer … l-live.iso )
How did you install lxqt? If you just installed lxqt, you may not have installed desktop-base, which pulls in the theme and the desktop background (and a few other things). If you installed task-lxqt-desktop, then you should get the background. But you won't get the window theme. It's not set up for that.
