#1 2021-07-20 13:17:17
[SOLVED] (Problem) Trying to update package list...
What exactly do I need to do, please.
:~$ sudo apt-get update
Get:1 http://deb.devuan.org/merged beowulf-security InRelease [26.3 kB]
Get:2 http://deb.devuan.org/merged beowulf InRelease [33.8 kB]
Get:3 http://deb.devuan.org/merged beowulf-updates InRelease [26.7 kB]
E: Repository 'http://deb.devuan.org/merged beowulf-security InRelease' changed its 'Suite' value from 'testing-security' to 'stable-security'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
E: Repository 'http://deb.devuan.org/merged beowulf InRelease' changed its 'Suite' value from 'testing' to 'stable'
E: Repository 'http://deb.devuan.org/merged beowulf-updates InRelease' changed its 'Suite' value from 'testing-updates' to 'stable-updates'
~$ uname -a
Linux devuan 4.19.0-9-amd64 #1 SMP Debian 4.19.118-2 (2020-04-29) x86_64 GNU/Linux
#2 2021-07-20 13:31:34
Re: [SOLVED] (Problem) Trying to update package list...
Try
# apt update
^ That should ask.
EDIT: or
# apt-get update --allow-releaseinfo-change
#3 2021-07-20 15:26:19
Many thanks!
I was needing the extra parameter with apt-get, (my 'usual' way of package management).
