#1 2021-07-14 21:35:28
swarfendor437
[SOLVED] No longer able to 'Extract here' in 3.1.1 when I could in 3.0 Beowulf
I am running KDE on this installation and in my previous install I was able to right-click a downloaded folder from Office365 as a .zip file, right-click the .zip file and select 'Extract here'. I know about using Ark which is what i always used to do and when 'Extract here' became available things moved more quickly. Strangely about a week ago it appeared to be working again but not anymore. Any ideas anyone?
Thanks for reading.
#2 2021-07-15 04:09:10
Re: [SOLVED] No longer able to 'Extract here' in 3.1.1 when I could in 3.0 Beowulf
be sure you have "Dolphin Preferences - Services - extract service menu" checked
I can right click on a zip file to get those extract options.
#3 2022-03-01 22:02:41
swarfendor437
No longer an issue as now using Devuan 4.0
