Hi, I am trying to install the latest version of Bralleblaster stable. This now comes as a .deb package but when running gdebi it comes back with a dependency error. It needs
libgcc-s1
This is not in the repos and only available using Debian Sid repo - would I break my system if I added that repository?
Currently running Devuan 3.1.1
KDE Plasma: 5.14.5
KDE Frameworks: 5,54.0
Qt Version: 5.11.3
Kernel Version: 4.19.0-17-amd4
Thanks in advance!
... trying to install the latest version of Bralleblaster stable.
Is this application in the stable Debian repository?
If it is, it should (unless for some reason blacklisted) also be in the stable Devuan repository.
But ...
Check this thread from 11/2017 at lists.debian.org:
https://lists.debian.org/debian-accessi … 00047.html
It is mid-2021 and I could not find it in the Debian package repository search:
https://packages.debian.org/search?keyw … ection=all
Have you asked the developers about the dependency and the reason it is not included in the package?
Edit:
Check this page: https://www.brailleblaster.org/docs/sys … ements.php
BrailleBlaster System Requirements
Software RequirementsWhen using one of the BrailleBlaster installer packages you will need a computer running one of the below operating systems.
Windows 10 or Newer
Mac OS X or Newer
Ubuntu Linux 20.04 or later <-------------- Bear in mind that Ubuntu Linux ≠ Debian/Devuan Linux.
ie: it does not mean that it will run on them and that there's probably
a reason Ubuntu is mentioned but not Debian/Devuan.Only if using the universal zip archive distribution of BrailleBlaster you will also need Java15 or higher installed on your computer.
Hi Altoid,
I think because I was in a rush working from home I had not spotted that element on the site. Many thanks. On earlier iterations on a different OS before I moved to Devuan I had to splatter the desktop with all the gubbins, remove Java 11 and install Java 8. The fact they now have it properly packaged I was hoping it would have worked - hey ho, no matter. I retire at end of August so no sweat but much appreciated that you took all that trouble to attempt to resolve the issue.
Warm regards,
swarf'
... not spotted that element on the site.
Many thanks.
You're welcome.
... before I moved to Devuan I had to splatter the desktop ...
... remove Java 11 and install Java 8.
The type of thing that frequently happens with packages from outside the repositories.
... hoping it would have worked ...
You may want to consider sending them an email to let them know about your issue.
There's probably other users affected, some may run on Devuan.
... appreciated that you took all that trouble ...
No trouble at all.
That's how the Pay It Forward system works.
Others here at Dev1 have done the same for me many times, so I try to do it for someone if I have the chance.
Usually works => everyone wins. 8^)
