#1 2021-06-25 13:49:43
quilt diff fails
I'm trying to make a quilt patch to correct (replace) a couple of files in clearlooks-phenix-cinnabar-theme, following this guide: https://wiki.debian.org/UsingQuilt
I've used that guide successfully on the deepsea theme, but this patch is failing. Here's my command history with relevant output:
### Clone the repo and checkout the working branch
git clone git@git.devuan.org:devuan/clearlooks-phenix-cinnabar-theme.git
cd clearlooks-phenix-cinnabar-theme/
git checkout suites/unstable
### apply existing patches (there's one active in the series file)
$ quilt push -a
Applying patch color-change
patching file gtk-2.0/gtkrc
Now at patch color-change
### Create new patch
$ quilt new top-left-active-fix
Patch top-left-active-fix is now on top
### Start making the changes
$ quilt add xfwm4/top-left-active.xpm
File xfwm4/top-left-active.xpm added to patch top-left-active-fix
$ cp ../top-left-active.xpm xfwm4/
$ quilt refresh
Refreshed patch top-left-active-fix
$ quilt add xfwm4/top-left-active.png
File xfwm4/top-left-active.png added to patch top-left-active-fix
$ cp ../top-left-active.png xfwm4/
$ quilt refresh
Diff failed on file 'xfwm4/top-left-active.png', aborting
$ quilt add xfwm4/png/top-left-active.png
File xfwm4/png/top-left-active.png added to patch top-left-active-fix
$ cp ../top-left-active.png xfwm4/png/
$ quilt refresh
Diff failed on file 'xfwm4/png/top-left-active.png', aborting
### Get rid of the failed patch and remove all the applied patches.
quilt delete top-left-active-fix
quilt pop -a
The .xpm file is a text file, and that works. The .png is a binary file, and I don't know if there's a different way to handle that. Other than that, I have no ideas about what's wrong. Suggestions are welcome.
Here's a link to the unstable branch, for reference: https://git.devuan.org/devuan/clearlook … s/unstable
#2 2021-06-26 00:07:29
Re: quilt diff fails
There's some additional notes about quilt for debian packages in man dpkg-source, line 440++. Esp:
Any change on a binary file is not representable in a diff and will thus  lead to a failure unless the maintainer deliberately decided to include that modified binary file in the debian tarball (by listing it in debian/source/include-binaries).  The build will also fail if it finds binary files in the debian sub-directory unless they have been whitelisted through debian/source/include-binaries.
Perhaps that means both that the relative pathname for png file (probably relative the directory containing the debian sub directory) must be mentioned in that included-binaries file, and then that the included-binaries file is maintained via quilt patching.
EDIT: or that the included-binaries file is just updated (without quilt-ing).
#3 2021-06-26 16:57:35
Quilt was incorporated into dpkg some time ago so perhaps try the dpkg-source --commit abstraction:
https://www.debian.org/doc/manuals/debm … rce-commit
#4 2021-06-27 11:56:26
Thanks, guys. I added the .png files to include-binaries instead of putting them in the patch.  Just the .xpm is in the patch. Looks like it all works and builds now.
