#1 2021-06-21 11:17:21
menuhin
[SOLVED] man display nothing with "line ?/?" after recent updates
I am running Devuan GNU/Linux 3 (beowulf) x86_64 with the followings:
Kernel: 4.9.0-6-amd64
Shell: bash 5.0.3
DE: Xfce
WM: bspwm
Terminal: terminator
And every package has been recently updated but today I found out that the manual page command "man" has some problem, i.e. no content of manual is displayed with just blank content and a status line saying, e.g. for the ls command:
Manual page ls(1) line ?/? (END) (press h for help or q to quit)
for a
man man | wc
, the result is:
man: can't execute preconv: Operation not permitted
man: can't execute tbl: Operation not permitted
man: can't execute col: Operation not permitted
groff: couldn't exec troff: Operation not permitted
man: command exited with status 4: (cd /usr/share/man && /usr/lib/man-db/zsoelim) | (cd /usr/share/man && /usr/lib/man-db/manconv -f UTF-8:ISO-8859-1 -t UTF-8//IGNORE) | (cd /usr/share/man && preconv -e UTF-8) | (cd /usr/share/man && tbl) | (cd /usr/share/man && nroff -mandoc -rLL=80n -rLT=80n -Tutf8)
      0       0       0
I found a similar bug for man-db package on a Ubuntu 2018 bug report page:
https://bugs.launchpad.net/ubuntu/+sour … ug/1778684
$>strace -f -o man.trace -s 1024 man man
results in:
I can attach the output file of the above strace command if need.
P.s. What I have amended in my system is also adding /etc/default/grub.d/apparmor.cfg which eliminated the startup error message of apparmor daemon (content of apparmor.cfg:
GRUB_CMDLINE_LINUX_DEFAULT="$GRUB_CMDLINE_LINUX_DEFAULT apparmor=1 security=apparmor"
And I also installed 3 apparmor packages: apparmor-utils apparmor-profiles apparmor-profiles-extra
#2 2021-06-21 12:07:06
menuhin
Re: [SOLVED] man display nothing with "line ?/?" after recent updates
I probably encountered a bug in 2018 (eg: Debian, bug #890861) https://unix.stackexchange.com/a/426204/195770
The temporary solution is to add
export MAN_DISABLE_SECCOMP=1
to my .profile
It can possibly be related to apparmor as there are people reporting apparmor breaking man, e.g.
https://darrengoossens.wordpress.com/20 … er-things/
#3 2021-06-21 14:36:57
In my fully updated beowulf without apparmor, man is working fine.
I notice you're using an older kernel. It's probably not related to the problem, but current kernel package in beowulf is 4.19.0-17.
#4 2021-06-21 14:43:43
Meta package linux-image-amd64 not installed?
#5 2021-06-22 11:47:22
Marjorie
Kernel: 4.9.0-17-amd64
Shell: bash 5.0.3
DE: Cinnamon
WM: Mutter
Terminal: gnome-terminal
Apparmor: 2:13.2-10
Man working fine:
marjorie@grendel:~$ man ls
LS(1)                                                     User Commands                                                    LS(1)
NAME
       ls - list directory contents
SYNOPSIS
       ls [OPTION]... [FILE]...
..etc.
