#1 2021-05-05 18:22:07
pcalvert
[SOLVED] Security update delays (again)
I received this notification more than 24 hours ago:
Debian Security Advisory DSA-4912-1                   security@debian.org
https://www.debian.org/security/                     Salvatore Bonaccorso
May 04, 2021                          https://www.debian.org/security/faq
Package        : exim4
CVE ID         : CVE-2020-28007 CVE-2020-28008 CVE-2020-28009 CVE-2020-28010
                 CVE-2020-28011 CVE-2020-28012 CVE-2020-28013 CVE-2020-28014
                 CVE-2020-28015 CVE-2020-28017 CVE-2020-28019 CVE-2020-28021
                 CVE-2020-28022 CVE-2020-28023 CVE-2020-28024 CVE-2020-28025
                 CVE-2020-28026
The Qualys Research Labs reported several vulnerabilities in Exim, a
mail transport agent, which could result in local privilege escalation
and remote code execution.
Details can be found in the Qualys advisory at
https://www.qualys.com/2021/05/04/21nails/21nails.txt
For the stable distribution (buster), these problems have been fixed in
version 4.92-8+deb10u6.
We recommend that you upgrade your exim4 packages.
For the detailed security status of exim4 please refer to its security
tracker page at:
https://security-tracker.debian.org/tracker/exim4
Further information about Debian Security Advisories, how to apply
these updates to your system and frequently asked questions can be
found at: https://www.debian.org/security/
Reference:
https://www.debian.org/security/2021/dsa-4912
I've run apt update multiple times since then, and it hasn't shown up yet.
$ apt policy exim4
exim4:
  Installed: 4.92-8+deb10u5
  Candidate: 4.92-8+deb10u5
  Version table:
 *** 4.92-8+deb10u5 500
        500 http://deb.devuan.org/merged beowulf/main amd64 Packages
        100 /var/lib/dpkg/status
     4.92-8+deb10u4 500
        500 http://deb.devuan.org/merged beowulf-security/main amd64 Packages
Although I could be mistaken, this does not seem like normal behavior to me.
Another one is called Luxxle.
#2 2021-05-05 18:54:15
Re: [SOLVED] Security update delays (again)
pcalvert wrote:
... received this notification more than 24 hours ago ...
... problems have been fixed in version 4.92-8+deb10u6.
See this article from The Register.
https://www.theregister.com/2021/05/05/ … exim_mail/
Tim Anderson @TheRegister wrote:
At the time of writing*, the packages for Debian 9 (Stretch), which is end of life but in long term support, had not yet been updated.
* Wed 5 May 2021 // 17:20 UTC
It may shed some light on the reasons for the apparent delay.
It's probably on its way.
groucho@devuan:~$ apt policy exim4
exim4:
  Installed: (none)
  Version table:
     4.94.2-1~bpo10+1 100
        100 http://deb.devuan.org/merged beowulf-backports/main amd64 Packages
        100 http://deb.devuan.org/merged beowulf-backports/main i386 Packages
     4.92-8+deb10u5 500
        500 http://deb.devuan.org/merged beowulf/main i386 Packages
     4.92-8+deb10u4 500
        500 http://deb.devuan.org/merged beowulf-security/main i386 Packages
groucho@devuan:~$
#3 2021-05-05 18:58:53
That would be valid for ASCII, not for Beowulf/Buster.
#4 2021-05-08 14:04:45
pcalvert
It has now been over 96 hours, and there is still no sign of the update.
$ apt policy exim4
exim4:
  Version table:
     4.92-8+deb10u4 500
By the way, in case it matters, I am using Refracta based on Devuan Beowulf. I forgot to mention that in my original post.
#5 2021-05-08 14:29:26
Using Refracta won't matter because it only has devuan repos. I was told a full merge is scheduled for Sunday, but I really have no idea what the schedule is or why. It seemed like we had this problem fixed with the last set of patches to amprolla. Guess not.
#6 2021-05-09 19:06:52
pcalvert
In case it helps, this is the last security update that came through in a timely manner:
Debian Security Advisory DSA-4911-1                   security@debian.org
https://www.debian.org/security/                          Michael Gilbert
May 03, 2021                          https://www.debian.org/security/faq
Package        : chromium
CVE ID         : CVE-2021-21227 CVE-2021-21228 CVE-2021-21229 CVE-2021-21230
                 CVE-2021-21231 CVE-2021-21232 CVE-2021-21233
Several vulnerabilities have been discovered in the chromium web browser.
CVE-2021-21227
    Gengming Liu discovered a data validation issue in the v8 javascript
    library.
CVE-2021-21228
    Rob Wu discovered a policy enforcement error.
CVE-2021-21229
    Mohit Raj discovered a user interface error in the file downloader.
CVE-2021-21230
    Manfred Paul discovered use of an incorrect type.
CVE-2021-21231
    Sergei Glazunov discovered a data validation issue in the v8 javascript
    library.
CVE-2021-21232
    Abdulrahman Alqabandi discovered a use-after-free issue in the developer
    tools.
CVE-2021-21233
    Omair discovered a buffer overflow issue in the ANGLE library.
version 90.0.4430.93-1~deb10u1.
We recommend that you upgrade your chromium packages.
For the detailed security status of chromium please refer to
its security tracker page at:
https://security-tracker.debian.org/tracker/chromium
Mailing list: debian-security-announce@lists.debian.org
From aptitude's log file:
Aptitude 0.8.11: log report
Tue, May  4 2021 10:27:13 -0400
  IMPORTANT: this log only lists intended actions; actions which fail
  due to dpkg problems may not be completed.
Will install 3 packages, and remove 0 packages.
4096 B of disk space will be used
[UPGRADE] chromium:amd64 90.0.4430.85-1~deb10u1 -> 90.0.4430.93-1~deb10u1
[UPGRADE] chromium-common:amd64 90.0.4430.85-1~deb10u1 -> 90.0.4430.93-1~deb10u1
[UPGRADE] chromium-sandbox:amd64 90.0.4430.85-1~deb10u1 -> 90.0.4430.93-1~deb10u1
Log complete.
#7 2021-05-10 17:09:22
pcalvert
It finally came through some time earlier today.
$ apt policy exim4
exim4:
  Candidate: 4.92-8+deb10u6
  Version table:
     4.92-8+deb10u6 500
#8 2021-05-16 00:11:30
pcalvert
I received this notification more than 48 hours ago:
Debian Security Advisory DSA-4915-1                   security@debian.org
https://www.debian.org/security/                       Moritz Muehlenhoff
May 13, 2021                          https://www.debian.org/security/faq
Package        : postgresql-11
CVE ID         : CVE-2021-32027 CVE-2021-32028 CVE-2021-32029
Multiple security issues have been discovered in the PostgreSQL database
system, which could result in the execution of arbitrary code or
disclosure of memory content.
version 11.12-0+deb10u1.
We recommend that you upgrade your postgresql-11 packages.
For the detailed security status of postgresql-11 please refer to
https://security-tracker.debian.org/tra … tgresql-11
This does not look right:
$ apt policy postgresql-11
postgresql-11:
  Installed: (none)
  Candidate: 11.11-0+deb10u1
  Version table:
     11.11-0+deb10u1 500
     11.7-0+deb10u1 500
#9 2021-05-16 16:21:51
Thanks for the alert. It's been brought up to date.
