#1 2021-03-28 14:52:48
Shutdown delay caused by anacron
Correction: Chimaera amd64 with openrc
Sometimes there is a delay during the computer shutdown waiting for anacron, range one or two mins. Both PCs affected have the package update indicator installed.
What might be the reasons? What can I do about this delay?
#2 2021-03-28 18:37:06
Re: Shutdown delay caused by anacron
Can we see the output of this command (as root):
# crontab -l
#3 2021-03-28 21:20:39
Correction: Chimaera is affected, not Beowulf. In both my Beowulf installs anacron isn't installed. It is on both Chimaera installations.
In crontab I just find the usual @reboot script that connects my nfs shares on my file server.
The effect is sporadic.
#4 2021-03-29 16:21:50
Check the logs and system mail. I don't use {ana,}cron in Debian so I might not be much help here (sorry).
