#1 2021-03-21 15:55:07
aghasee
[SOLVED] My Devuan is sluggish.
Hello all,
For about a week now, my computer is running very sluggish, with a lot of Windows-like disk access, delays while typing...
Every now and then the system freezes completely, to the point of having to perform a hard power off.
System is updated and there were no recent installs/uninstalls.
From what I can see, there is no excessive RAM, processor or swap usage.
Disk utility does not report disk failures of any kind (disks are what, 6 months old?)
Initially I suspected Brave browser, but switching to Firefox does not solve anything.
Specs:
Intel Core2quad cpu, 8GB RAM
Beowulf 3 clean install
Gnome DE, gdm3, with tracker-miner disabled.
Any of you knowledgeable ppl care to point me in the right direction?
TIA,
- a collision at sea can ruin your entire day -
#2 2021-03-21 16:25:59
Geoff 42
Re: [SOLVED] My Devuan is sluggish.
Does top show anything grabbing lots of cpu or memory?
#3 2021-03-21 16:29:51
Perhaps also check iotop.
#4 2021-03-22 11:44:24
Andre4freedom
Is your GNOME desktop running in "fallback" mode?
If yes, make sure your graphics controller is supported or install the non-free firmware drivers. Gnome needs 3D acceleration.
It's just my thought, but possibly off-track.
Good luck.
#5 2021-03-22 15:49:50
aghasee
Good luck.
I'm running Gnome on this very hardware since at least 2015; first under Debian, now under Devuan. Problems started only a week ago.
From what I'm reading fallback has been dropped for quite a while now, can't find the setting on my machine anyway.
As for top and iotop; I don't see anything out of the ordinary.
#6 2021-03-22 17:29:40
Check your RAM health.
#7 2021-03-22 17:46:36
ComputerBob
Make sure that your swap file/partition is working?
ComputerBob - Making Geek-Speak Chic (TM)
ComputerBob.com - Nearly 6,000 Posts and over 23 Million Views since 1998
My Massive Second Stroke
Help! (off-topic)
#8 2021-03-22 17:55:08
Does dmesg show any interesting messages when the system starts running slowly?
Are there any interesting messages in syslog (check /var/log/auth.log /var/log/daemon.log /var/log/kern.log /var/log/messages and /var/log/syslog)?
Chris
#9 2021-03-23 06:16:11
aghasee
Ran a check for 5 hrs, no errors.
#10 2021-03-23 16:13:37
aghasee
Going to mark this solved, even though it isn't.
Dual boot machine: Win7 runs flawless.
I'm at a loss here, I don't have the time or the capability to keep on tinkering.
Not even pursuing specialties of any kind: internet, e-mail, text processor, photo viewer and a media player/dlna-server, thats it.
I want my machine to just work.
One more clean offline install.
Maybe /not/ updating will do the trick?
Anyway, thanks for your time and effort all.
