Pages: 1
Has anyone been able to get jellyfin up and running? The install instructions have to be tweaked slightly at one point so that packages are installed from beowulf and not buster. Not a problem. However, beyond this, I cannot start the server:
sudo /etc/init.d/jellyfin startappears to work, but
sudo /etc/init.d/jellyfin statusshows failed, and I cannot connect to the web interface.
jellyfin is a great open-source project with apps for Android and Roku, but unfortunately is uses SystemD.
Same as you.
I tried to setup Jellyfin and switched my home server to Debian just to try it :-(
Have you checked the logs?
No, I have not. I'm pretty much a noob. What logs should I have checked?
Pages: 1
