#1 2021-02-25 21:10:00
mclien
Graphic on a Thinkpad with NVidia card
My "new" thinkpad T460p has 2 video cards:
 lspci
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 530 (rev 06)
02:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 940MX] (rev a2)
I found this instruction:
https://www.unixmen.com/how-to-make-nvi … on-debian/
But this is how to set up to use the two cards alternating. So you choose which video card is running every time you start a program.
I'm not entirely sure if I want that or rather  have the nvidia card running all graphic all the time.
#2 2021-02-26 06:02:24
Re: Graphic on a Thinkpad with NVidia card
The Debian wiki has a Bumblebee page with the same instructions but you don't have to wade through a swamp of adverts & javascript to read that.
Check the firmware ("BIOS") options, there may be a setting to change from "Hybrid" to "Discrete" for the NVIDIA card. Try looking under Config → Display → Graphics Device.
See https://download.lenovo.com/pccbbs/mobi … r_v1.0.pdf & https://download.lenovo.com/pccbbs/mobi … n_v1.0.pdf for some examples.
Black Lives Matter
#3 2021-02-26 21:51:59
mclien
1. thanks for the hint
2. sadly this menu point is missing in my Thinkpad (T460p)
But I start to kinda like the idea of using the nvidia card only when necessary (power consumption wise)
(First I need to get a working docking station, which is a pain because there are docks with DP and DVI, which are mutually exclusive. In whatever universe that should make sense)
#4 2021-02-27 21:30:23
mclien
The BIOS on my specific machine has no BIOS setting
hence no "discrete"
I think I should look into the Bumblebee stuff.
Is there a good way to find out, if this Notebook actually has a Nvidia Optimus feature?
