#1 2021-02-25 20:17:57
mclien
change timezone [solved]
I messed up my timezone.
But I'm not totally sure how to fix it.
Is it "just" to set the correct link here:
ls -l /etc/localtime
EDIT:
Yes it is. Use
ln -sf /usr/share/zoneinfo/US/Central /etc/localtime
Example to set it to US Central "on the fly"
#2 2021-02-25 20:40:08
Re: change timezone [solved]
You should probably use the provided abstraction instead:
# dpkg-reconfigure tzdata
This isn't Arch wink
#3 2021-02-25 20:58:04
mclien
Well, yes, perhaps. But nowadays most of the searches will give you the "timedateclt" solution.
And I find it quite interesting to finally "kinda by accident" found out how it is done internally.
Also: I was wondering what requires less typing ;-)
Btw: I must have messed up this while installing. (wonder where I missed the "Europe" path in installation.
#4 2021-12-31 08:13:45
kapqa
problem here is that even with "dpkg-reconfigure tzdata" and the correct timezone (rome) the hour is one h behind.
