#1 2021-02-23 14:00:07
AntoFox
How can I build packages for devuan to put them in the official repo?
I would  like to do a build of MATE 1.25, but not I don't have jenkins permission and don't know the correct workflow gitea cicd, someone can explain me how to?
#2 2021-02-23 16:47:48
Re: How can I build packages for devuan to put them in the official repo?
Here are the current docs for packaging.
https://git.devuan.org/devuan/documenta … aintainers
Quick summary:
Clone from upstream git repo to preserve the history (salsa.debian.org if it's there)
Build it locally to make sure it works.
Push to your devuan git.
Looks like your projects are all personal projects. To get into the repo someone would need to transfer the projects to the devuan group, then build (usually for suites/unstable).  I guess we'd need to figure out where the packages are going. Are they backports, or are you forking for chimaera or ceres?
#3 2021-02-25 17:22:23
AntoFox
Hi fsmithred!
How are you?
At today  yes are "personal" project.
mate 1.25 for chimaera while 1.22 is for beowulf
The source for 1.25.x version comes from github, it doesn't exist 1.25 on salsa sad
if i can build 1.24 for beowulf i bring that maybe
#4 2021-04-01 08:24:13
AntoFox
can you move all mate-* pluma caja atril repo package to devuan-packages? smile
