#1 2021-02-17 18:37:22
kapqa
How to get a working jessie sources.list
please help me to get a working devuan jessie sources.list.
the netinstaller would no longer function on the proposed net-repository.sources, thanks!
EDIT:
deb http://deb.devuan.org/merged jessie main contrib
deb http://deb.devuan.org/merged jessie-security main contrib
deb http://deb.devuan.org/merged jessie-updates main contrib
deb http://deb.devuan.org/merged jessie-backports main contrib
seems somehow to function;
the security branch is no longer active,
and i think the netinstaller iso wanted to use auto.mirror.devuan.org or similar instead of "deb.devuan.org", maybe therefore it did not function.
#2 2021-02-17 19:26:54
Re: How to get a working jessie sources.list
Actually your post is off topic, you would have better written a new post.
Read https://www.devuan.org/os/packages
#3 2021-02-17 19:26:56
If you want help then you should probably open your own thread.
But anyway Debian jessie reached EOL on June 30th last year so you probably shouldn't bother with Devuan jessie.
