#1 2021-02-20 07:14:12
LizziAS
WiFi, and Sixpair
Here is my system:
sudo inxi -Fxzmc0
[sudo] password for lizzias:
System:    Host: devuaned Kernel: 4.19.0-14-amd64 x86_64 bits: 64 compiler: gcc v: 8.3.0 Desktop: Xfce 4.12.4
           Distro: Devuan GNU/Linux 3 (beowulf)
Machine:   Type: Desktop System: Gigabyte product: AB350M-DS3H v: N/A serial: N/A
           Mobo: Gigabyte model: AB350M-DS3H-CF v: x.x serial: N/A UEFI [Legacy]: American Megatrends v: F50d date: 07/02/2020
Battery:   Device-1: hidpp_battery_0 model: Logitech M570 charge: 90% status: Discharging
           Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360 charge: 100% (should be ignored)
           status: Discharging
Memory:    RAM: total: 15.67 GiB used: 1.85 GiB (11.8%)
           Array-1: capacity: 128 GiB slots: 4 EC: None max module size: 32 GiB note: est.
           Device-1: DIMM 0 size: No Module Installed
           Device-2: DIMM 1 size: 8 GiB speed: 3000 MT/s type: DDR4
           Device-3: DIMM 0 size: No Module Installed
           Device-4: DIMM 1 size: 8 GiB speed: 3000 MT/s type: DDR4
CPU:       Topology: Quad Core model: AMD Ryzen 5 2400G with Radeon Vega Graphics bits: 64 type: MT MCP arch: Zen
           L2 cache: 2048 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 57490
           Speed: 1422 MHz min/max: 1600/3600 MHz Core speeds (MHz): 1: 1420 2: 1423 3: 1454 4: 1523 5: 1457 6: 1424 7: 1444
           8: 1525
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480] vendor: ASRock driver: amdgpu v: kernel
           bus ID: 01:00.0
           Display: server: X.Org 1.20.4 driver: amdgpu,ati unloaded: fbdev,modesetting,vesa resolution: 1920x1080~60Hz
           OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.27.0 4.19.0-14-amd64 LLVM 7.0.1) v: 4.5 Mesa 18.3.6
           direct render: Yes
Audio:     Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: ASRock driver: snd_hda_intel v: kernel
           bus ID: 01:00.1
           Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
           bus ID: 0a:00.6
           Sound Server: ALSA v: k4.19.0-14-amd64
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
           port: e000 bus ID: 05:00.0
           IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
           Device-2: Intel Wi-Fi 6 AX200 driver: N/A port: e000 bus ID: 08:00.0
Drives:    Local Storage: total: 2.85 TiB used: 9.23 GiB (0.3%)
           ID-1: /dev/nvme0n1 model: Sabrent Rocket Q size: 931.51 GiB
           ID-2: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB temp: 35 C
           ID-3: /dev/sdb vendor: SanDisk model: Ultra II 500GB size: 465.76 GiB temp: 34 C
           ID-4: /dev/sdc vendor: Micron model: MT-128 size: 119.24 GiB temp: 33 C
           ID-5: /dev/sdd vendor: Toshiba model: MK5075GSX size: 465.76 GiB temp: 34 C
Partition: ID-1: / size: 48.97 GiB used: 9.23 GiB (18.8%) fs: ext4 dev: /dev/nvme0n1p5
           ID-2: swap-1 size: 32.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sdc4
Sensors:   System Temperatures: cpu: 32.2 C mobo: N/A gpu: amdgpu temp: 16 C
           Fan Speeds (RPM): N/A gpu: amdgpu fan: 1491
Info:      Processes: 262 Uptime: 38m Init: SysVinit runlevel: 2 Compilers: gcc: 8.3.0 Shell: bash v: 5.0.3 inxi: 3.0.32
neofetch
   ..,,;;;::;,..                   lizzias@devuaned
           `':ddd;:,.              ----------------
                 `'dPPd:,.         OS: Devuan GNU/Linux 3 (beowulf) x86_64
                     `:b$$b`.      Host: AB350M-DS3H
                        'P$$$d`    Kernel: 4.19.0-14-amd64
                         .$$$$$`   Uptime: 12 hours, 29 mins
                         ;$$$$$P   Packages: 2042 (dpkg), 4 (flatpak)
                      .:P$$$$$$`   Shell: bash 5.0.3
                  .,:b$$$$$$$;'    Resolution: 1920x1080
             .,:dP$$$$$$$$b:'      DE: Xfce
      .,:;db$$$$$$$$$$Pd'`         WM: Xfwm4
 ,db$$$$$$$$$$$$$$b:'`             WM Theme: Clearlooks-Phenix-Cinnabar
:$$$$$$$$$$$$b:'`                  Theme: Xfce-dusk [GTK2], Adwaita [GTK3]
 `$$$$$bd:''`                      Icons: Cinnabar [GTK2], Adwaita [GTK3]
   `'''`                           Terminal: xfce4-terminal
                                   Terminal Font: Monospace 12
                                   CPU: AMD Ryzen 5 2400G (8) @ 3.600GHz
                                   GPU: AMD ATI Radeon RX 470/480
                                   Memory: 1335MiB / 16050MiB
my wifi isnt recognized and i need sixpair working yet
#2 2021-02-20 09:12:26
Re: WiFi, and Sixpair
The AX200 card needs the kernel & firmware from the beowulf-backports repository.
What is "sixpair"?
#3 2021-02-20 20:47:02
LizziAS
What is "sixpair"?
i have enabled the backports directory.  help me remember how to debian.. my apt-cache search doesnt reveal them
## package repositories
deb http://deb.devuan.org/merged/ beowulf main contrib non-free
deb http://deb.devuan.org/merged/ beowulf-updates main contrib non-free
deb http://deb.devuan.org/merged/ beowulf-security main contrib non-free
deb http://deb.devuan.org/merged/ beowulf-backports main contrib non-free
## source repositories
deb-src http://deb.devuan.org/merged/ beowulf main contrib non-free
deb-src http://deb.devuan.org/merged/ beowulf-updates main contrib non-free
deb-src http://deb.devuan.org/merged/ beowulf-security main contrib non-free
deb-src http://deb.devuan.org/merged/ beowulf-backports main contrib non-free
sixpair sixaxis is ps3 controller.  i think i have that worked out but i still need the kernel for the wifi
#4 2021-02-20 20:57:52
LizziAS
sudo apt -t beowulf-backports install linux-image-amd64
#5 2021-02-20 21:01:49
Kernel:
apt list linux-image-5*
apt install linux-image-5.10.0-0.bpo.3-amd64
Firmware:
apt list firmware-linux-nonfree* -a
apt -t beowulf-backports install firmware-linux-nonfree
#6 2021-02-20 21:04:28
Should also work and provide automatic kernel updates.
#7 2021-02-20 21:09:26
The relevant firmware package is firmware-iwlwifi.
