#1 2021-02-17 13:31:44
MLEvD
Is there a general problem with user settings persistence in 3.1,mate?
Myself and at least one other have noted that certain sound settings do not persist in 3.0 or 3.1, where they do in ascii or debian.
Further to this, I note that backgrounds added by the user are lost in 3.1   This is not a problem in 2.0 or 3.1
Can anyone confirm this on 64 bit please? Just add a background from your pictures folder, then choose a different background, does it loose the one you just added?
This is happening on mate desktop. Is it happening on other de?
#2 2021-02-17 13:55:54
Re: Is there a general problem with user settings persistence in 3.1,mate?
Yes, I can reproduce this stupid bug in 64-bit beowulf mate. It's not a problem in xfce, because you don't have to "add" a picture in your settings if you copy the file into the folder that holds the other bg images. Xfce shows you all the image files in the selected directory.
Does mate not do this in debian?
#3 2021-02-17 14:27:24
MLEvD
I upgraded a 3.0 to 3.1 in the past hour, no sign of this bug so maybe needs a fresh install to reproduce? I've only seen it on my current lightweight mate / netinstall on a 4gb ssd eee pc. No immediate plans to install it on another machine but curiosity builds
Debian mate is fine, LMDE 2,3 or 4 with mate de all fine, ascii is fine, 3.0 is fine, and now 3.0 upgraded to 3.1 is fine.
#4 2021-02-17 14:28:29
Beowulf 3.0 install with Mate dated June 2020, amd64 with backports kernel 5.9, up to date:
Just added a picture from my home folder as background: survives changing the background and a reboot.
#5 2021-02-17 14:30:09
MLEvD
Problem is in fresh 3.1 install.
#6 2021-02-17 14:31:15
MLEvD
Oh, to reproduce, you need to change to a different picture, then see if it persists. It will always persist if it's your current background and the file is present, so far...
#7 2021-02-17 14:32:17
There should be no difference in the Mate desktop if I update an older 3.0 install or do a fresh install from 3.1 when using the same init.
#8 2021-02-17 15:34:38
I've been testing by adding two image files to directories under /usr/share/backgrounds/ (cosmos and mate/abstract). Then right-click desktop to change background. Neither show up when I navigate to the directory that holds the files I just added.
Next step is to click on the Add button and add those pictures. Then select one and close that window.
Then try to change the bg again, and the added image that I'm not currently using no longer shows up. It's still in the directory, but my desktop has forgotten about it.
update/upgrade did not change it.
I think we need to compare package lists.
dpkg -l | awk '/^ii/ { print $2 " " $3 }' > pkglist-debian
Do the same to make pkglist-devuan and compare them. Send them to me and I'll compare them (I have a script to do that).
#9 2021-02-17 15:41:11
Just done a Mate install from 3.1 in VBox, can confirm that that installation forgets the picture from the home folder.
#10 2021-02-17 16:13:00
MLEvD
for dpkg -l | awk '/^ii/ { print $2 " " $3 }' > pkglist-debian
I get:
dpkg-query: no packages found matching /^ii/ { print $2 " " $3 }
what did I do wrong?
update: am using runit on the 3.1 problem box, sysvinit on the no-problem upgraded box
#11 2021-02-17 16:16:03
You are missing a quote before the print command. Use copy/paste.
#12 2021-02-17 16:28:23
MLEvD
I typed it exactly as it is there.
My comment was copied and pasted from your example.
In just pasted it into terminal on this my lmde3 main machine, and, wait, a package-list appeared in /home..
So I figured maybe I needed a desktop so I went on another getty and did a startx and had no kb or mouse so now I am stuck with avril lavign looping in moc until the battery dies
,,,sorry for the delay, that list is coming...
OK, so I needed to install awk-original, and had missed the  |  (what do you call the upright bar?)
#13 2021-02-17 16:55:40
MLEvD
accountsservice 0.6.45-2
adduser 3.118
adwaita-icon-theme 3.30.1-1
anacron 2.3-28
apparmor 2.13.2-10
apt 1.8.2.2
apt-utils 1.8.2.2
at-spi2-core 2.30.0-7
avahi-autoipd 0.7-4+b1
avahi-daemon 0.7-4+b1
base-files 10.3+devuan3.5
base-passwd 3.5.46
bash 5.0-4
bash-completion 1:2.8-6
bind9-host 1:9.11.5.P4+dfsg-5.1+deb10u2
bleachbit 2.0-3
bootlogd 2.93-8+devuan1
bsdmainutils 11.1.2+b1
bsdutils 1:2.33.1-0.1+devuan1~beowulf2
bubblewrap 0.3.1-4
busybox 1:1.30.1-4
caja 1.20.3-1+b1
caja-common 1.20.3-1
cmatrix 1.2a+git20181122-1
compton 0.1~beta2+20150922-1
console-setup 1.193~deb10u1
console-setup-linux 1.193~deb10u1
coreutils 8.30-3
cpio 2.12+dfsg-9
cpp 4:8.3.0-1
cpp-8 8.3.0-6
crda 3.18-1
cron 3.0pl1-134+deb10u1
dash 0.5.10.2-5
dbus 1.12.20-0+deb10u1+devuan1
dbus-x11 1.12.20-0+deb10u1+devuan1
dconf-cli 0.30.1-2
dconf-gsettings-backend:i386 0.30.1-2
dconf-service 0.30.1-2
deadbeef-static 0.6.2-2
debconf 1.5.71
debconf-i18n 1.5.71
debian-archive-keyring 2019.1
debian-mate-default-settings 1.20.2-1
debianutils 4.8.6.1
desktop-file-utils 0.23-4
devuan-keyring 2017.10.03
dictionaries-common 1.28.1
diffutils 1:3.7-3
dmidecode 3.2-1
dmsetup 2:1.02.155-3
dosfstools 4.1-2
dpkg 1.19.7
e2fsprogs 1.44.5-1+deb10u3
elogind 241.4-2
emacsen-common 3.0.4
eom 1.20.2-2
eom-common 1.20.2-2
eudev 3.2.9-8~beowulf1
fdisk 2.33.1-0.1+devuan1~beowulf2
fgetty 0.7-5
file 1:5.35-4+deb10u2
findutils 4.6.0+git+20190209-2
firmware-linux-free 3.4
fontconfig 2.13.1-2
fontconfig-config 2.13.1-2
fonts-dejavu-core 2.37-1
fonts-ubuntu 0.83-4
fonts-ubuntu-console 0.83-4
fonts-woowa-bm 20171009-1
gcc-8-base:i386 8.3.0-6
gdebi 0.9.5.7+nmu3
gdebi-core 0.9.5.7+nmu3
gdisk 1.0.3-1.1
gettext-base 0.19.8.1-9
getty-run 2.1.2-25
gir1.2-atk-1.0:i386 2.30.0-2
gir1.2-freedesktop:i386 1.58.3-2
gir1.2-gdkpixbuf-2.0:i386 2.38.1+dfsg-1
gir1.2-glib-2.0:i386 1.58.3-2
gir1.2-gtk-3.0:i386 3.24.5-1
gir1.2-mate-panel 1.20.5-1
gir1.2-matepanelapplet-4.0:i386 1.20.5-1
gir1.2-notify-0.7:i386 0.7.7-4
gir1.2-pango-1.0:i386 1.42.4-8~deb10u1
gir1.2-vte-2.91:i386 0.54.2-2
glib-networking:i386 2.58.0-2+deb10u2
glib-networking-common 2.58.0-2+deb10u2
glib-networking-services 2.58.0-2+deb10u2
gnome-icon-theme 3.12.0-3
gnome-screenshot 3.30.0-2
gnome-system-monitor 3.30.0-2
gparted 0.32.0-2
gpgv 2.2.12-1+deb10u1
grep 3.3-1
groff-base 1.22.4-3
grub-common 2.02+dfsg1-20+deb10u3
grub-pc 2.02+dfsg1-20+deb10u3
grub-pc-bin 2.02+dfsg1-20+deb10u3
grub2-common 2.02+dfsg1-20+deb10u3
grub2-theme-mint 1.1.0
gsettings-desktop-schemas 3.28.1-1
gtk-update-icon-cache 3.24.5-1
gvfs:i386 1.38.1-5
gvfs-bin 1.38.1-5
gvfs-common 1.38.1-5
gvfs-daemons 1.38.1-5
gvfs-libs:i386 1.38.1-5
gzip 1.9-3
hicolor-icon-theme 0.17-2
hostname 3.21
htop 2.2.0-1+b1
ibritish 3.4.00-6
ienglish-common 3.4.00-6
ifupdown 0.8.35
init 1.56+nmu1+devuan3
init-system-helpers 1.56+nmu1+devuan3
initramfs-tools 0.133+deb10u1
initramfs-tools-core 0.133+deb10u1
initscripts 2.93-8+devuan1
insserv 1.18.0-2
iproute2 4.20.0-2+deb10u1
iptables 1.8.2-4
iputils-ping 3:20180629-2+deb10u1
isc-dhcp-client 4.4.1-2
isc-dhcp-common 4.4.1-2
iso-codes 4.2-1
ispell 3.4.00-6+b1
iw 5.0.1-1
kbd 2.0.4-4
keyboard-configuration 1.193~deb10u1
klibc-utils 2.0.6-1
kmod 26-1
less 487-0.1+b1
libaccountsservice0:i386 0.6.45-2
libacl1:i386 2.2.53-4
libaom0:i386 1.0.0-3
libapparmor1:i386 2.13.2-10
libapt-inst2.0:i386 1.8.2.2
libapt-pkg5.0:i386 1.8.2.2
libasound2:i386 1.1.8-1
libasound2-data 1.1.8-1
libasound2-plugins:i386 1.1.8-1
libaspell15:i386 0.60.7~20110707-6
libasyncns0:i386 0.8-6
libatasmart4:i386 0.19-5
libatk-bridge2.0-0:i386 2.30.0-5
libatk1.0-0:i386 2.30.0-2
libatk1.0-data 2.30.0-2
libatkmm-1.6-1v5:i386 2.28.0-2
libatomic1:i386 8.3.0-6
libatspi2.0-0:i386 2.30.0-7
libattr1:i386 1:2.4.48-4
libaudit-common 1:2.8.4-3
libaudit1:i386 1:2.8.4-3
libavahi-client3:i386 0.7-4+b1
libavahi-common-data:i386 0.7-4+b1
libavahi-common3:i386 0.7-4+b1
libavahi-core7:i386 0.7-4+b1
libavcodec58:i386 7:4.1.6-1~deb10u1
libavresample4:i386 7:4.1.6-1~deb10u1
libavutil56:i386 7:4.1.6-1~deb10u1
libayatana-appindicator3-1 0.5.3-4
libayatana-ido3-0.4-0:i386 0.4.4-1
libayatana-indicator3-7:i386 0.6.2-3
libbind9-161:i386 1:9.11.5.P4+dfsg-5.1+deb10u2
libblas3:i386 3.8.0-2
libblkid1:i386 2.33.1-0.1+devuan1~beowulf2
libblockdev-fs2:i386 2.20-7+deb10u1
libblockdev-loop2:i386 2.20-7+deb10u1
libblockdev-part-err2:i386 2.20-7+deb10u1
libblockdev-part2:i386 2.20-7+deb10u1
libblockdev-swap2:i386 2.20-7+deb10u1
libblockdev-utils2:i386 2.20-7+deb10u1
libblockdev2:i386 2.20-7+deb10u1
libbluetooth3:i386 5.50-1.2~deb10u1
libbluray2:i386 1:1.1.0-1
libbrotli1:i386 1.0.7-2+deb10u1
libbsd0:i386 0.9.1-2
libbz2-1.0:i386 1.0.6-9.2~deb10u1
libc-bin 2.28-10
libc-l10n 2.28-10
libc6:i386 2.28-10
libcairo-gobject2:i386 1.16.0-4+deb10u1
libcairo2:i386 1.16.0-4+deb10u1
libcairomm-1.0-1v5:i386 1.12.2-4
libcaja-extension1:i386 1.20.3-1+b1
libcanberra-gtk3-0:i386 0.30-7
libcanberra0:i386 0.30-7
libcap-ng0:i386 0.7.9-2
libcap2:i386 1:2.25-2
libcap2-bin 1:2.25-2
libcodec2-0.8.1:i386 0.8.1-2
libcolord2:i386 1.4.3-4+devuan1~beowulf1
libcom-err2:i386 1.44.5-1+deb10u3
libconfig9:i386 1.5-0.4
libcroco3:i386 0.6.12-3
libcrystalhd3:i386 1:0.0~git20110715.fdd2f19-13
libcups2:i386 2.2.10-6+deb10u4
libcurl3-gnutls:i386 7.64.0-4+deb10u1
libdaemon0:i386 0.14-7
libdatrie1:i386 0.2.12-2
libdb5.3:i386 5.3.28+dfsg1-0.5
libdbus-1-3:i386 1.12.20-0+deb10u1+devuan1
libdbus-glib-1-2:i386 0.110-4
libdbusmenu-glib4:i386 18.10.20180917~bzr490+repack1-1
libdbusmenu-gtk3-4:i386 18.10.20180917~bzr490+repack1-1
libdconf1:i386 0.30.1-2
libdebconfclient0:i386 0.249
libdevmapper1.02.1:i386 2:1.02.155-3
libdns-export1104 1:9.11.5.P4+dfsg-5.1+deb10u2
libdns1104:i386 1:9.11.5.P4+dfsg-5.1+deb10u2
libdrm-amdgpu1:i386 2.4.97-1
libdrm-common 2.4.97-1
libdrm-intel1:i386 2.4.97-1
libdrm-nouveau2:i386 2.4.97-1
libdrm-radeon1:i386 2.4.97-1
libdrm2:i386 2.4.97-1
libedit2:i386 3.1-20181209-1
libefiboot1:i386 37-2+deb10u1
libefivar1:i386 37-2+deb10u1
libegl-mesa0:i386 18.3.6-2+deb10u1
libegl1:i386 1.1.0-1
libelf1:i386 0.176-1.1
libelogind0:i386 241.4-2
libenca0:i386 1.19-1+b1
libenchant1c2a:i386 1.6.0-11.1+b1
libepoxy0:i386 1.5.3-0.1
libept1.5.0:i386 1.1+nmu3+b1
libeudev1:i386 3.2.9-8~beowulf1
libevdev2:i386 1.6.0+dfsg-1
libexempi8:i386 2.5.0-2
libexif12:i386 0.6.21-5.1+deb10u5
libexpat1:i386 2.2.6-2+deb10u1
libext2fs2:i386 1.44.5-1+deb10u3
libfaad2:i386 2.8.8-3
libfdisk1:i386 2.33.1-0.1+devuan1~beowulf2
libffi6:i386 3.2.1-9
libflac8:i386 1.3.2-3
libfontconfig1:i386 2.13.1-2
libfontenc1:i386 1:1.1.3-1+b2
libfreetype6:i386 2.9.1-3+deb10u2
libfribidi0:i386 1.0.5-3.1+deb10u1
libfstrm0:i386 0.4.0-1
libfuse2:i386 2.9.9-1+deb10u1
libgail-3-0:i386 3.24.5-1
libgbm1:i386 18.3.6-2+deb10u1
libgcc1:i386 1:8.3.0-6
libgck-1-0:i386 3.28.1-1
libgcr-base-3-1:i386 3.28.1-1
libgcrypt20:i386 1.8.4-5
libgdbm6:i386 1.18.1-4
libgdk-pixbuf2.0-0:i386 2.38.1+dfsg-1
libgdk-pixbuf2.0-common 2.38.1+dfsg-1
libgeoip1:i386 1.6.12-1
libgfortran5:i386 8.3.0-6
libgirepository-1.0-1:i386 1.58.3-2
libgl1:i386 1.1.0-1
libgl1-mesa-dri:i386 18.3.6-2+deb10u1
libglapi-mesa:i386 18.3.6-2+deb10u1
libglew2.1:i386 2.1.0-4
libglib2.0-0:i386 2.58.3-2+deb10u2
libglib2.0-bin 2.58.3-2+deb10u2
libglib2.0-data 2.58.3-2+deb10u2
libglibmm-2.4-1v5:i386 2.58.0-2
libglu1-mesa:i386 9.0.0-2.1+b3
libglvnd0:i386 1.1.0-1
libglx-mesa0:i386 18.3.6-2+deb10u1
libglx0:i386 1.1.0-1
libgmp10:i386 2:6.1.2+dfsg-4
libgnutls30:i386 3.6.7-4+deb10u6
libgomp1:i386 8.3.0-6
libgpg-error0:i386 1.35-1
libgraphite2-3:i386 1.3.13-7
libgsm1:i386 1.0.18-2
libgssapi-krb5-2:i386 1.17-3+deb10u1
libgstreamer-gl1.0-0:i386 1.14.4-2
libgstreamer-plugins-base1.0-0:i386 1.14.4-2
libgstreamer1.0-0:i386 1.14.4-1
libgtk-3-0:i386 3.24.5-1
libgtk-3-common 3.24.5-1
libgtk2.0-0:i386 2.24.32-3
libgtk2.0-common 2.24.32-3
libgtkmm-2.4-1v5:i386 1:2.24.5-4
libgtkmm-3.0-1v5:i386 3.24.0-2
libgtksourceview-3.0-1:i386 3.24.9-2
libgtksourceview-3.0-common 3.24.9-2
libgtop-2.0-11:i386 2.38.0-4
libgtop2-common 2.38.0-4
libgudev-1.0-0:i386 232-2
libharfbuzz-icu0:i386 2.3.1-1
libharfbuzz0b:i386 2.3.1-1
libhogweed4:i386 3.4.1-1
libhunspell-1.7-0:i386 1.7.0-2
libhyphen0:i386 2.8.8-7
libice6:i386 2:1.0.9-2
libicu63:i386 63.1-6+deb10u1
libid3tag0:i386 0.15.1b-14
libidn2-0:i386 2.0.5-1+deb10u1
libimobiledevice6:i386 1.2.1~git20181030.92c5462-2+deb10u1
libindicator3-7:i386 0.5.0-4
libinput-bin 1.12.6-2+deb10u1
libinput10:i386 1.12.6-2+deb10u1
libip4tc0:i386 1.8.2-4
libip6tc0:i386 1.8.2-4
libiptc0:i386 1.8.2-4
libisc-export1100:i386 1:9.11.5.P4+dfsg-5.1+deb10u2
libisc1100:i386 1:9.11.5.P4+dfsg-5.1+deb10u2
libisccc161:i386 1:9.11.5.P4+dfsg-5.1+deb10u2
libisccfg163:i386 1:9.11.5.P4+dfsg-5.1+deb10u2
libisl19:i386 0.20-2
libjack-jackd2-0:i386 1.9.12~dfsg-2
libjansson4:i386 2.12-1
libjavascriptcoregtk-4.0-18:i386 2.30.4-1~deb10u1
libjbig0:i386 2.1-3.1+b2
libjpeg62-turbo:i386 1:1.5.2-2+deb10u1
libjson-c3:i386 0.12.1+ds-2+deb10u1
libjson-glib-1.0-0:i386 1.4.4-2
libjson-glib-1.0-common 1.4.4-2
libk5crypto3:i386 1.17-3+deb10u1
libkeyutils1:i386 1.6-6
libklibc:i386 2.0.6-1
libkmod2:i386 26-1
libkrb5-3:i386 1.17-3+deb10u1
libkrb5support0:i386 1.17-3+deb10u1
liblapack3:i386 3.8.0-2
liblcms2-2:i386 2.9-3
libldap-2.4-2:i386 2.4.47+dfsg-3+deb10u5
libldap-common 2.4.47+dfsg-3+deb10u5
liblightdm-gobject-1-0:i386 1.26.0-4+devuan2
libllvm7:i386 1:7.0.1-8+deb10u2
liblmdb0:i386 0.9.22-1
liblocale-gettext-perl 1.07-3+b4
libltdl7:i386 2.4.6-9
liblwres161:i386 1:9.11.5.P4+dfsg-5.1+deb10u2
liblz4-1:i386 1.8.3-1
liblzma5:i386 5.2.4-1
libmad0:i386 0.15.1b-10
libmagic-mgc 1:5.35-4+deb10u2
libmagic1:i386 1:5.35-4+deb10u2
libmarco-private1:i386 1.20.3-1
libmate-desktop-2-17:i386 1.20.4-2
libmate-menu2:i386 1.20.2-1
libmate-panel-applet-4-1:i386 1.20.5-1
libmate-slab0:i386 1.20.4-2
libmate-window-settings1:i386 1.20.4-2
libmatekbd-common 1.20.2-1
libmatekbd4:i386 1.20.2-1
libmatemixer-common 1.20.1-1
libmatemixer0:i386 1.20.1-1
libmateweather-common 1.20.2-1
libmateweather1:i386 1.20.2-1
libmm-glib0:i386 1.10.0-1
libmnl0:i386 1.0.4-2
libmodplug1:i386 1:0.8.9.0-2
libmount1:i386 2.33.1-0.1+devuan1~beowulf2
libmp3lame0:i386 3.100-2+b1
libmpc3:i386 1.1.0-1
libmpcdec6:i386 2:0.1~r495-1+b2
libmpdec2:i386 2.4.2-2
libmpfr6:i386 4.0.2-1
libmtdev1:i386 1.1.5-1+b1
libncurses6:i386 6.1+20181013-2+deb10u2
libncursesw6:i386 6.1+20181013-2+deb10u2
libndp0:i386 1.6-1+b1
libnetfilter-conntrack3:i386 1.0.7-1
libnettle6:i386 3.4.1-1
libnewt0.52:i386 0.52.20-8
libnfnetlink0:i386 1.0.1-3+b1
libnftnl11:i386 1.1.2-2
libnghttp2-14:i386 1.36.0-2+deb10u1
libnl-3-200:i386 3.4.0-1
libnl-genl-3-200:i386 3.4.0-1
libnl-route-3-200:i386 3.4.0-1
libnm0:i386 1.14.6-2+deb10u1
libnma0:i386 1.8.20-1.1
libnotify4:i386 0.7.7-4
libnspr4:i386 2:4.20-1
libnss3:i386 2:3.42.1-1+deb10u3
libnuma1:i386 2.0.12-1
libogg0:i386 1.3.2-1+b1
libopenjp2-7:i386 2.3.0-2+deb10u1
libopus0:i386 1.3-1
libopusfile0 0.9+20170913-1
liborc-0.4-0:i386 1:0.4.28-3.1
libp11-kit0:i386 0.23.15-2+deb10u1
libpam-elogind:i386 241.4-2
libpam-modules:i386 1.3.1-5
libpam-modules-bin 1.3.1-5
libpam-runtime 1.3.1-5
libpam0g:i386 1.3.1-5
libpango-1.0-0:i386 1.42.4-8~deb10u1
libpango1.0-0:i386 1.42.4-8~deb10u1
libpangocairo-1.0-0:i386 1.42.4-8~deb10u1
libpangoft2-1.0-0:i386 1.42.4-8~deb10u1
libpangomm-1.4-1v5:i386 2.42.0-2
libpangox-1.0-0:i386 0.0.2-5+b2
libpangoxft-1.0-0:i386 1.42.4-8~deb10u1
libparted-fs-resize0:i386 3.2-25
libparted2:i386 3.2-25
libpci3:i386 1:3.5.2-1
libpciaccess0:i386 0.14-1
libpcre2-8-0:i386 10.32-5
libpcre3:i386 2:8.39-12
libpcsclite1:i386 1.8.24-1+devuan1
libpeas-1.0-0:i386 1.22.0-4
libpeas-common 1.22.0-4
libpipeline1:i386 1.5.1-2
libpixman-1-0:i386 0.36.0-1
libplist3:i386 2.0.1~git20190104.3f96731-1
libpng16-16:i386 1.6.36-6
libpolkit-agent-1-0:i386 0.105-25+devuan8
libpolkit-backend-1-0 0.105-25+devuan8
libpolkit-backend-elogind-1-0:i386 0.105-25+devuan8
libpolkit-gobject-1-0 0.105-25+devuan8
libpolkit-gobject-elogind-1-0:i386 0.105-25+devuan8
libpopt0:i386 1.16-12
libprocps7:i386 2:3.3.15-2+devuan1
libprotobuf-c1:i386 1.3.1-1+b1
libproxy1v5:i386 0.4.15-5+deb10u1
libpsl5:i386 0.20.2-2
libpulse-mainloop-glib0:i386 12.2-4+deb10u1
libpulse0:i386 12.2-4+deb10u1
libpulsedsp:i386 12.2-4+deb10u1
libpython-stdlib:i386 2.7.16-1
libpython2-stdlib:i386 2.7.16-1
libpython2.7:i386 2.7.16-2+deb10u1
libpython2.7-minimal:i386 2.7.16-2+deb10u1
libpython2.7-stdlib:i386 2.7.16-2+deb10u1
libpython3-stdlib:i386 3.7.3-1
libpython3.7:i386 3.7.3-2+deb10u2
libpython3.7-minimal:i386 3.7.3-2+deb10u2
libpython3.7-stdlib:i386 3.7.3-2+deb10u2
libquadmath0:i386 8.3.0-6
librcc0 0.2.12-0.1
librcd0 0.1.13-3
librda-common 0.0.5-1
librda0:i386 0.0.5-1
libreadline7:i386 7.0-5
libresid-builder0c2a 2.1.1-15
librest-0.7-0:i386 0.8.1-1
librsvg2-2:i386 2.44.10-2.1
librsvg2-common:i386 2.44.10-2.1
librtmp1:i386 2.4+20151223.gitfa8646d.1-2
libsamplerate0:i386 0.1.9-2
libsasl2-2:i386 2.1.27+dfsg-1+deb10u1
libsasl2-modules-db:i386 2.1.27+dfsg-1+deb10u1
libseccomp2:i386 2.3.3-4
libsecret-1-0:i386 0.18.7-1
libsecret-common 0.18.7-1
libselinux1:i386 2.8-1+b1
libsemanage-common 2.8-2
libsemanage1:i386 2.8-2
libsensors-config 1:3.5.0-3
libsensors5:i386 1:3.5.0-3
libsepol1:i386 2.8-1
libshine3:i386 3.1.1-2
libsidplay2 2.1.1-15
libsidutils0 2.1.1-15
libsigc++-2.0-0v5:i386 2.10.1-2
libslang2:i386 2.3.2-2
libsm6:i386 2:1.2.3-1
libsmartcols1:i386 2.33.1-0.1+devuan1~beowulf2
libsnappy1v5:i386 1.1.7-1
libsndfile1:i386 1.0.28-6
libsoup-gnome2.4-1:i386 2.64.2-2
libsoup2.4-1:i386 2.64.2-2
libsoxr0:i386 0.1.2-3
libspeex1:i386 1.2~rc1.2-1+b2
libspeexdsp1:i386 1.2~rc1.2-1+b2
libsqlite3-0:i386 3.27.2-3+deb10u1
libss2:i386 1.44.5-1+deb10u3
libssh2-1:i386 1.8.0-2.1
libssl1.1:i386 1.1.1d-0+deb10u4
libstartup-notification0:i386 0.12-6
libstdc++6:i386 8.3.0-6
libswresample3:i386 7:4.1.6-1~deb10u1
libtag1v5:i386 1.11.1+dfsg.1-0.3+deb10u1
libtag1v5-vanilla:i386 1.11.1+dfsg.1-0.3+deb10u1
libtagc0:i386 1.11.1+dfsg.1-0.3+deb10u1
libtasn1-6:i386 4.13-3
libtdb1:i386 1.3.16-2+b1
libteamdctl0:i386 1.28-1
libtext-charwidth-perl 0.04-7.1+b1
libtext-iconv-perl 1.7-5+b7
libtext-wrapi18n-perl 0.06-7.1
libthai-data 0.1.28-2
libthai0:i386 0.1.28-2
libtheora0:i386 1.1.1+dfsg.1-15
libtiff5:i386 4.1.0+git191117-2~deb10u1
libtinfo6:i386 6.1+20181013-2+deb10u2
libtwolame0:i386 0.3.13-4
libuchardet0:i386 0.0.6-3
libudisks2-0:i386 2.8.1-4+devuan1
libunistring2:i386 0.9.10-1
libunwind8:i386 1.2.1-10~deb10u1
libupower-glib3:i386 0.99.10-1
libusb-1.0-0:i386 2:1.0.22-2
libusbmuxd4:i386 1.1.0~git20181007.07a493a-1
libutempter0:i386 1.1.6-3
libuuid1:i386 2.33.1-0.1+devuan1~beowulf2
libva-drm2:i386 2.4.0-1
libva-x11-2:i386 2.4.0-1
libva2:i386 2.4.0-1
libvdpau1:i386 1.1.1-10
libvorbis0a:i386 1.3.6-2
libvorbisenc2:i386 1.3.6-2
libvorbisfile3:i386 1.3.6-2
libvpx5:i386 1.7.0-3+deb10u1
libvte-2.91-0:i386 0.54.2-2
libvte-2.91-common 0.54.2-2
libwacom-common 0.32-1
libwacom2:i386 0.32-1
libwavpack1:i386 5.1.0-6
libwayland-client0:i386 1.16.0-1
libwayland-cursor0:i386 1.16.0-1
libwayland-egl1:i386 1.16.0-1
libwayland-server0:i386 1.16.0-1
libwebkit2gtk-4.0-37:i386 2.30.4-1~deb10u1
libwebp6:i386 0.6.1-2
libwebpdemux2:i386 0.6.1-2
libwebpmux3:i386 0.6.1-2
libwebrtc-audio-processing1:i386 0.3-1
libwnck-3-0:i386 3.30.0-2
libwnck-3-common 3.30.0-2
libwoff1:i386 1.0.2-1
libwrap0:i386 7.6.q-28
libx11-6:i386 2:1.6.7-1+deb10u1
libx11-data 2:1.6.7-1+deb10u1
libx11-xcb1:i386 2:1.6.7-1+deb10u1
libx264-155:i386 2:0.155.2917+git0a84d98-2
libx265-165:i386 2.9-4
libxapian30:i386 1.4.11-1
libxau6:i386 1:1.0.8-1+b2
libxaw7:i386 2:1.0.13-1+b2
libxcb-dri2-0:i386 1.13.1-2
libxcb-dri3-0:i386 1.13.1-2
libxcb-glx0:i386 1.13.1-2
libxcb-present0:i386 1.13.1-2
libxcb-render0:i386 1.13.1-2
libxcb-shape0:i386 1.13.1-2
libxcb-shm0:i386 1.13.1-2
libxcb-sync1:i386 1.13.1-2
libxcb-util0:i386 0.3.8-3+b2
libxcb-xfixes0:i386 1.13.1-2
libxcb1:i386 1.13.1-2
libxcomposite1:i386 1:0.4.4-2
libxcursor1:i386 1:1.1.15-2
libxdamage1:i386 1:1.1.4-3+b3
libxdmcp6:i386 1:1.1.2-3
libxext6:i386 2:1.3.3-1+b2
libxfixes3:i386 1:5.0.3-1
libxfont2:i386 1:2.0.3-1
libxft2:i386 2.3.2-2
libxi6:i386 2:1.7.9-1
libxinerama1:i386 2:1.1.4-2
libxkbcommon0:i386 0.8.2-1
libxkbfile1:i386 1:1.0.9-2+b11
libxklavier16:i386 5.4-4
libxml2:i386 2.9.4+dfsg1-7+deb10u1
libxmu6:i386 2:1.1.2-2+b3
libxmuu1:i386 2:1.1.2-2+b3
libxpm4:i386 1:3.5.12-1
libxpresent1:i386 1.0.0-2+b10
libxrandr2:i386 2:1.5.1-1
libxrender1:i386 1:0.9.10-1
libxres1:i386 2:1.2.0-2
libxshmfence1:i386 1.3-1
libxslt1.1:i386 1.1.32-2.2~deb10u1
libxss1:i386 1:1.2.3-1
libxt6:i386 1:1.1.5-1+b3
libxtables12:i386 1.8.2-4
libxtst6:i386 2:1.2.3-1
libxv1:i386 2:1.0.11-1
libxvidcore4:i386 2:1.3.5-1
libxvmc1:i386 2:1.0.10-1
libxxf86dga1:i386 2:1.1.4-1+b3
libxxf86vm1:i386 1:1.1.4-1+b2
libzstd1:i386 1.3.8+dfsg-3+deb10u1
libzvbi-common 0.2.35-16
libzvbi0:i386 0.2.35-16
lightdm 1.26.0-4+devuan2
lightdm-gtk-greeter 2.0.6-1
linux-base 4.6
linux-image-4.19.0-14-686 4.19.171-2
locales 2.28-10
login 1:4.5-1.1
logrotate 3.14.0-4
lsb-base 10.2019051400
lsof 4.91+dfsg-1
man-db 2.8.5-2
marco 1.20.3-1
marco-common 1.20.3-1
mate-control-center 1.20.4-2
mate-control-center-common 1.20.4-2
mate-desktop 1.20.4-2
mate-desktop-common 1.20.4-2
mate-icon-theme 1.20.3-1
mate-media 1.20.2-1
mate-media-common 1.20.2-1
mate-menus 1.20.2-1
mate-notification-daemon 1.20.2-1
mate-notification-daemon-common 1.20.2-1
mate-panel 1.20.5-1
mate-panel-common 1.20.5-1
mate-polkit:i386 1.20.2-1
mate-polkit-common 1.20.2-1
mate-power-manager 1.20.3-2
mate-power-manager-common 1.20.3-2
mate-session-manager 1.20.2-1
mate-settings-daemon 1.20.4-1
mate-settings-daemon-common 1.20.4-1
mate-terminal 1.20.2-2
mate-terminal-common 1.20.2-2
mate-tweak 18.10.2-1
mawk 1.3.3-17+b3
menu-xdg 0.6
mesa-utils 8.4.0-1+b1
mime-support 3.62
mint-themes 1.8.2
mint-x-icons 1.4.3
mint-y-icons 1.3.4
moc 1:2.6.0~svn-r2994-3
mount 2.33.1-0.1+devuan1~beowulf2
mousepad 0.4.1-2
mozo 1.20.2-1
mtools 4.0.23-1
ncurses-base 6.1+20181013-2+deb10u2
ncurses-bin 6.1+20181013-2+deb10u2
neofetch 6.0.0-2
netbase 5.6
network-manager 1.14.6-2+deb10u1
network-manager-gnome 1.8.20-1.1
original-awk 2012-12-20-6
os-prober 1.77
paprefs 1.0-1
parted 3.2-25
passwd 1:4.5-1.1
pciutils 1:3.5.2-1
perl-base 5.28.1-6+deb10u1
policykit-1 0.105-25+devuan8
policykit-1-gnome 0.105-7
popularity-contest 1.67+devuan1
procps 2:3.3.15-2+devuan1
pulseaudio 12.2-4+deb10u1
pulseaudio-module-gsettings 12.2-4+deb10u1
pulseaudio-module-zeroconf 12.2-4+deb10u1
pulseaudio-utils 12.2-4+deb10u1
python 2.7.16-1
python-apt-common 1.8.4.3
python-cairo:i386 1.16.2-1+b1
python-configobj 5.0.6-3
python-gi 3.30.4-1
python-gobject-2 2.28.6-13+b1
python-gtk2 2.24.0-5.1+b1
python-mate-menu 1.20.2-1
python-minimal 2.7.16-1
python-numpy 1:1.16.2-1
python-pkg-resources 40.8.0-1
python-six 1.12.0-1
python-xdg 0.25-5
python-xlib 0.23-2
python2 2.7.16-1
python2-minimal 2.7.16-1
python2.7 2.7.16-2+deb10u1
python2.7-minimal 2.7.16-2+deb10u1
python3 3.7.3-1
python3-apt 1.8.4.3
python3-chardet 3.0.4-3
python3-debian 0.1.35
python3-gi 3.30.4-1
python3-minimal 3.7.3-1
python3-pkg-resources 40.8.0-1
python3-psutil 5.5.1-1
python3-setproctitle:i386 1.1.10-1+b2
python3-six 1.12.0-1
python3.7 3.7.3-2+deb10u2
python3.7-minimal 3.7.3-2+deb10u2
readline-common 7.0-5
runit 2.1.2-25
runit-helper 2.8.6
runit-init 2.1.2-25
sed 4.7-1
sensible-utils 0.0.12
shared-mime-info 1.10-1
sound-theme-freedesktop 0.8-2
startpar 0.61-1
sudo 1.8.27-1+deb10u3
synaptic 0.84.6
sysuser-helper 1.3.3
sysv-rc 2.93-8+devuan1
sysvinit-utils 2.93-8+devuan1
tar 1.30+dfsg-6
tzdata 2021a-0+deb10u1
ucf 3.0038+nmu1
udisks2 2.8.1-4+devuan1
upower 0.99.10-1
util-linux 2.33.1-0.1+devuan1~beowulf2
util-linux-locales 2.33.1-0.1+devuan1~beowulf2
whiptail 0.52.20-8
wireless-regdb 2016.06.10-1
wpasupplicant 2:2.7+git20190128+0c1e29f-6+deb10u2
x11-apps 7.7+7
x11-common 1:7.7+19
x11-session-utils 7.7+3
x11-utils 7.7+4
x11-xkb-utils 7.7+4
x11-xserver-utils 7.7+8
xauth 1:1.0.10-1
xbitmaps 1.1.1-2
xdg-dbus-proxy 0.1.1-1
xdg-utils 1.1.3-1+deb10u1
xfonts-100dpi 1:1.0.4+nmu1
xfonts-75dpi 1:1.0.4+nmu1
xfonts-base 1:1.0.5
xfonts-encodings 1:1.0.4-2
xfonts-scalable 1:1.0.3-1.1
xfonts-utils 1:7.7+6
xinit 1.4.0-1
xkb-data 2.26-2
xorg 1:7.7+19
xorg-docs-core 1:1.7.1-1.1
xserver-common 2:1.20.4-1+deb10u2
xserver-xorg 1:7.7+19
xserver-xorg-core 2:1.20.4-1+deb10u2
xserver-xorg-input-all 1:7.7+19
xserver-xorg-input-libinput 0.28.2-2
xserver-xorg-video-intel 2:2.99.917+git20180925-2
xterm 344-1
xxd 2:8.1.0875-5
xz-utils 5.2.4-1
zenity 3.30.0-2
zenity-common 3.30.0-2
zlib1g:i386 1:1.2.11.dfsg-1
#14 2021-02-17 19:19:57
The problem is also present in a fresh install based on Beowulf 3.0.0 netinstall in VBox. Same procedure used as for the 3.1.0 install, only difference is runit on 3.1.0 and openrc on 3.0.0.
I guess there must be a bug somewhere in Mate. Strangely enough my workstation is fine.
#15 2021-02-17 19:37:29
My script for comparing the package lists is spammed with packages that are different only in architecture. Here's a simper diff showing what mate packages we have. Anything that starts with a + is one that I have and you don't. Anything that starts with - is one you have that I don't. The only one of those is mate-tweak, and when I added it (without Recommends) it didn't fix the problem. Not sure where to go with this now.
$ diff -u mlevd-list my-mate-list | grep "^[\+|\-]mate"
+mate-applet-brisk-menu 0.5.0-9
+mate-applets 1.20.3-2
+mate-applets-common 1.20.3-2
+mate-backgrounds 1.20.0-2
+mate-calc 1.20.3-1
+mate-calc-common 1.20.3-1
+mate-desktop-environment 1.20.0+5
+mate-desktop-environment-core 1.20.0+5
+mate-icon-theme-faenza 1.20.0+dfsg1-2
-mate-polkit:i386 1.20.2-1
+mate-polkit:amd64 1.20.2-1
+mate-screensaver 1.20.3-3
+mate-screensaver-common 1.20.3-3
+mate-system-monitor 1.20.2-1
+mate-system-monitor-common 1.20.2-1
-mate-tweak 18.10.2-1
+mate-themes 3.22.18-1
+mate-user-guide 1.20.2-1
+mate-utils 1.20.2-3
+mate-utils-common 1.20.2-3
Note: That vertical bar that we use to pipe the output of one command to another is called a pipe. Or it could mean "OR" when there are two in a row.
#16 2021-02-23 13:44:49
AntoFox
Hi to all,
which MATE version you have installed from devuan or from hezeh.org??
#17 2021-02-23 14:01:48
Mate 1.20.4 from the Devuan repository.
Rolfie
#18 2021-02-23 16:36:31
Same here. 1.20 from devuan beowulf main repo
#19 2021-03-11 11:57:02
MLEvD
I found a clue. This problem is also in debian but, wait for it...
I did a netinstall of the latest kali. Select and install software was broken so went ahead anyway. Added light mate desktop
Stunned to see that it happily retains your user defined backgrounds across reboots.
Question? Which package or procedure provides the magic where you get your special home folders generated? I seem to keep doing net installs and not getting a proper home directory
#20 2021-03-11 23:07:25
If you mean the subdirectories in your home for MUSIC PICTURES and whatever else, that would be xdg-user-dirs and xdg-utils. If those are installed, look in /etc/xdg/ if you want to edit the configs. There are a few xdg- commands, too. You might be interested in xdg-user-dirs-update.
If you mean /home/<username> does not exist, then you somehow failed to create a user during the installation. You would have had to say no when asked if you wanted to create a user. In an already-installed system, the adduser command does all the things you need to create a user. You can change those defaults in /etc/adduser.conf.
