#1 2021-02-01 13:07:52
dice
easy script to mount luks encrypted drives, usb etc.
This something to make my life easier, it just basically opens and mounts/unmounts a luke encrypted usb drive, could be any sort of pluggable drive i suppose. Thinking of adding some options to easily create full disk encryption to go along with these options as well.
Just thought i would share.
all that needs to be done is to have a usb or disk with a partuuid and a label and those are the parameters it opens and mounts by. But these parameters need to be added to the script manually.
so usage is as root cryptmount -m to open and mount
and cryptmount -u to unmount and close
u=$(logname)
crypt_mount () {
        cryptsetup luksOpen "/dev/disk/by-partuuid/00000-1" usb;
        mount -L "BACKUPS" /media/"${u}"
crypt_umount () {
        umount -R /media/"${u}";
        cryptsetup close usb
while getopts ":mu" opt; do
  case "${opt}" in
        m ) crypt_mount
        u ) crypt_umount
  esac
done
I would like to explore how to make this a kind of menu where you could pick available devices to encrypt and mount
#2 2021-02-01 19:15:59
Re: easy script to mount luks encrypted drives, usb etc.
Maybe you can do something with these.
From refractainstaller. This lists partitions. It does not differentiate between encrypted and non-encrypted. Using blkid would be one way to find the encrypted partitions.
find /dev -mindepth 1 -maxdepth 1  | egrep  "*[shv]d[a-z][1-99]|*nvme[0-9]n[0-9]p[1-99]|*mmcblk[0-9]p[1-99]"   | sort | awk '{print "\n" $0 }'
Same thing with a graphical interface (yad)
device=$(find /dev -mindepth 1 -maxdepth 1  | egrep  "*[shv]d[a-z][1-99]|*nvme[0-9]n[0-9]p[1-99]|*mmcblk[0-9]p[1-99]" \
  | sort | awk '{print "\n" $0 }' \
  | yad --list   --title="Select device" --center --borders=10 --text="Select a device." \
  --separator="" --column ' ' --column$'Partitions' --height=380 --width=200 --button="OK":0)
From refracta2usb. These list usb devices.
usbdevlist=$(/usr/sbin/hwinfo --usb --short|grep "/dev/sd"|awk '{print $1}')
usbdevfulllist=$(/usr/sbin/hwinfo --usb --short|grep "/dev/sd"|awk '{print $0}')
And used with yad.
device=$(yad --width=400 --height=200 --center --title="$TITLE" --list --separator="" --column="" --text=$"Detected USB devices:\n\n$usbdevfulllist\n\nSelect the target device you want to copy the live image to." $usbdevlist \
	--button="OK":0 --button="Exit":1
I had to alter some of these so they would make sense. I hope I didn't break anything.
#3 2021-02-01 20:31:22
dice wrote:
        m ) crypt_mount "$@"
        u ) crypt_umount "$@"
Why are you passing the arguments applied to the script to those functions? They don't appear to do anything with them unless I'm missing something obvious.
No need for grep:
usbdevlist=$(/usr/sbin/hwinfo --usb --short|awk '/\/dev\/sd/{print $1}')
usbdevfulllist=$(/usr/sbin/hwinfo --usb --short|awk '/\/dev\/sd/{print $0}')
And here's a whiptail alternative for the yad dialogue:
usbdevlist() {
   /usr/sbin/hwinfo --usb --short|awk '/\/dev\/sd/{print $1,$1}'
device=$(whiptail --notags --menu "Please select the target device to which you want to copy the live image:" 0 0 0 $(usbdevlist) 3>&2 2>&1 1>&3)
#4 2021-02-01 23:05:01
dice
thanks fsmithred i will look into those today.
head on a stick, yes i forgot to remove those. I copied over that part of the script from anther script which is using them. Thanks for pointing that out and cheers for the whiptail reference.
#5 2021-02-02 09:57:52
dice
I just found out that pmount does what i want as far as mounting luks encrypted usb drives.
edited out script. Im just not getting it !
#6 2021-02-02 10:56:25
Oh yeah, pmount. Try this -
https://sourceforge.net/projects/refrac … nt-1.2.deb
It works for removable USB, CD and mmc devices. Add any fixed drives to /etc/pmount.allow.
#7 2021-02-02 11:09:25
dice
thats excellent fsmithred, even opens spacefm in the required directory. I dont use gvfs or polkits so this is why im doing this. Will stop work on my script now, seems to redundant lol. Thanks again
