#1 2021-01-30 20:56:49
mstrohm
Plans for generic ARM installer images that use the EFI boot process?
U-Boot can now run EFI executables and it is possible to run the EFI variant of Grub 2 from U-Boot. Four years ago, there were already some boards that were able to boot Linux using Grub 2 (EFI) and U-Boot: https://www.suse.com/media/article/UEFI … U-Boot.pdf (The list is in section V)
In other words: The abstraction layer that U-Boot provides through the EFI boot process could make it possible to provide generic Devuan GNU+Linux ARM installer images without hardware-specific boot code. The latter could be put in separate (small) image files for each hardware in case one needs to install the boot firmware (blob + U-Boot).
Are there plans to build generic installer images for ARM that use the EFI boot process?
#2 2021-01-31 09:55:42
tuxd3v
Re: Plans for generic ARM installer images that use the EFI boot process?
hello mstrohm,
Apart from RaspberryPI that still need some blobs,
Devuan uses Free and Open Source Software with completely reproducible results by any person that wants to compile the code.. smile
This was to clear a bit the Idea of blobs in Distros,as far as I know, Devuan are usually not in favour of blobs..
Speaking about EFI, the question here is what it brings of new?
And this for me is a big Question..
Because till now what people are thinking is that, they want to boot u-boot so that later start other bootloader on top of that( Grub )..
The problem starts with SBC's being small devices with less memory than desirable, and also a lot less Raw cpu power..
So the Idea is maybe a small bootloader..
u-boot itself is not a small bootloader by any means, it supports a plethora of hardware, and has a plethora of drivers, that are even people, only running a application only on top of it( without the linux vm..).But, after compiled for a determined board, its size is very acceptable.
uboot also supports, extlinux like boot,
Which is a simple way to boot(I personally prefer the 'boor.scr' script because its a lot more powerful and customizable.. ).
In any case, you will always have 2 different things, the bootloader, and the kernel to boot.
You can choose to have 1 partition or several( typically 2 partitions,  one for /boot , and one for / ),
But you always have one bootloader compiled for 1 single device.. unless you have several boards , all being the same model..in this case the bootloader from one board is good for the other one( not always, because of the Hardware revisions on them..sometimes they also differ.. ).
So Devuan, for Installer Images, has 2 components, one being the bootloader part, and the other being the rootfs of the installer..
You combine them together and form one single installer image.
You can see them here in the README.txt.
One good example are the netboot ISO's option. smile
So, Devuan already provide the kernel + UserSpace, in a Generic Way,
If you look into those netboot isos, you will find out that there are a common to all boards part. smile
At same time, that are 1 part that depends on the board were the final iso will run..
In Other Words, Devuan already have that solution. smile
Best Regards,
tux
#3 2021-02-01 21:34:12
mstrohm
EFI would allow building an installer image once without having to care about the specialities of the hardware. That's what an U-Boot that is already installed on the machine (in on-board flash for example) would do. The installer image would just contain Grub and a generic kernel which gets its hardware information (FDT) from U-Boot.
#4 2021-02-03 03:42:19
tuxd3v
Majority of the SBC boards doesn't even have a flash, and those who have, its blank..
So to flash it, you need first an operating system running on it, or very specialized hardware to flash uboot to it..
Majority of people still needs a sd card, as a way, to boot at least the installer, and this is already provided by Devuan.
Devuan has a generic Installer for armhf and also for arm64.
Devuan is using only 1 bootloader, since you cannot escape it( uboot )..
How do you see it as an improvement, loading above the bootloader, a second bootloader( GRUB )?
It doesn't change nothing, for the image point of view, and complicates the process,
In the end you gain nothing from it, only looses..
If EFI were able to provide the kernel with sufficient information, so that the kernel would be able to boot, without uboot,
Then would be a improvement, but since from the beginning you need uboot anyway, I fail to understand what you gain with EFI..
Remember that uboot is the one that objectively needs to be compiled for each board separately..
Best Regards,
tux
#5 Yesterday 17:32:19
kuleszdl
Afaik, there is already a generic aarch64 ISO that works fine and comes with GRUB already. It's the mini.iso that can be found here:
https://pkgmaster.devuan.org/devuan/dis … t/mini.iso
It works fine in QEMU so I assume it should also work with u-boot.
Personally, I like the idea of the OP. Sure, you need to flash a board-specific u-boot once into the SPI. But once you've done it, installing any EFI-compatible OS should be as easy as doing the same on x86_64.
Yet, I'm not sure if having u-boot is enough or if you won't need a 2nd stage bootloader such as TianoCore. But if it already works with u-boot, why not give it a try?
