#1 2021-01-30 03:59:10
mcc
Repartioning the SSD after flashing a Devuan Beowulf image
(this is all to be used with a Raspberry Pi 4)
With
xzcat "image".xz > /dev/sdb
I flashed an image of Devuan Beowulf 3.0 onto my SSD. The image was provided by c0rnelius under this link:
https://github.com/pyavitz/rpi-img-buil … tag/images    (THANKS A LOT! smile ).
The image booted fine and sshd via ethernet worked out of the box.
After shutdown the Raspi, attaching the SSD to my Linux PC and looking at the partitioning I found two partitions:
A very small boot partition and a very large root partion (more than 100GBytes).
For backup reasons I would like to have at least an additon partition for my $HOME.
Since this has worked for a lot of cases, I shrinked the root partition with gparted, added an addtional partition with an ext4 file system, wrote whole stuff to the SSD (no error/warning) and fired up my Raspi with the SSD.
It does not boot anymore.
I reflashed the image, and did the partioning before the first boot. Same thing: No boot.
I reflashed the image, and did the partioning, disable the automatic partition resizer, boot the Raspi. Again: No boot.
In all cases the partition for $HOME was left off fstab (to be added, if boot succeeds, which it doesn't).
I searched the forum with "repartitioning" and "gparted" and found either nothing or much too much hits to be of what I wanted.
Did I overlooked something? How can I successfully modify the partion scheme?
Cheers!
mcc
#2 2021-01-30 11:44:41
c0rnelius
Re: Repartioning the SSD after flashing a Devuan Beowulf image
My guess would be that after using gparted the PARTUUID has changed. Attach the SSD and run sudo blkid and see if it matches whats in /boot/cmdline.txt
#3 2021-01-30 12:30:32
Note that you can set the uuid of an ext4 parition with tune2fs, i.e. you should be able to restore the uuid of the shrunk partition.
#4 2021-01-30 13:38:34
c0rnelius
Might be easier just to add the new root=PARTUUID=newid-02 to /boot/cmdline.txt and be done with it. Or you could just hard code it in with something such as root=/dev/sda2.
#5 2021-01-31 00:43:03
Sure.  you might then also need to edit /etc/fstab and if there's anything else have captured the old uuid.
Just in parenthesis: hardcoding the uuid is no less hardcoding than hardcoding the partition device name. At some stage in history there was that idea of partition "label" which survives partition resize, move and copy; that could be used as well.
#6 2021-02-28 17:37:32
kuleszdl
I also highly recommend using partition labels over UUIDs. You can find a detailed example how they can be used in my generic aarch64 tutorial here:
https://www.kulesz.me/post/140-debian-d … 4-install/
#7 2021-03-01 22:33:18
berni51
Hey, great thread!! Thanks to @mcc for sharing the link with Devuan images for the Raspberry 4. c0rnelius made a fine job and the system runs properly and rock solid.
OK, it was a little bit tricky to set up a German keymap, but now it works as well as X. Now I have an alternative to raspian.
Again, many thanks to @C0rnelius and @mcc.
Regards
Berni
