#1 2021-01-28 07:12:43
dice
Sudo Vulnerability CVE-2021-3156
if you havent apt updated in a while today would be the day to do it if you use sudo.
https://haxf4rall.com/2021/01/27/cve-20 … ity-alert/
On January 27, 2021, RedHat issued a risk notice for heap-based buffer overflow vulnerability, the vulnerability number is CVE-2021-3156. The vulnerability level is a high risk.  CVSS v3 Base Score is 7.0.
Attackers can use heap-based buffer overflow vulnerability to gain root privileges after obtaining server permissions. Currently, Debian has fixed the vulnerability, Centos is still affected.
Vulnerability Detail
A heap-based buffer overflow was found in the way sudo parsed command line parameters. Any local user (normal user and system user, sudoer and non-sudoers) can exploit this vulnerability without authentication, and the attacker does not need to know the user’s password. Successfully exploiting this vulnerability to gain root privileges.
How to exploit this bug
Log in to the system as a non-root user and use the command sudoedit -s /
-If you see an error that starts with sudoedit:, it indicates that there is a vulnerability.
-If you see an error starting with usage:, then the patch has taken effect.
Demo
Affected version
sudo: 1.8.2 – 1.8.31p2
sudo: 1.9.0 – 1.9.5p1
Solution
In this regard, we recommend that users upgrade sudo to the latest version in time.
The post CVE-2021-3156: Sudo Heap-Based Buffer Overflow Vulnerability Alert appeared first on InfoTech News.
Post navigation
#2 2021-01-28 15:59:22
Re: Sudo Vulnerability CVE-2021-3156
RFP for doas(1) was submitted yesterday:
https://bugs.debian.org/cgi-bin/bugrepo … bug=981176
Looks like it's going to be packaged up for De??an :-)
#3 2021-01-28 16:09:18
dice
There is also a minimalist alternative to privilege escalation that allows normal users
to run other programs as a different user and group..
https://github.com/parazyd/sup
Ive also started to create scripts to handle everyday tasks from the user account using su.
For instance if i want to edit a file as root i have the below script i call "sue"
su -c "$EDITOR $@"
#4 2021-01-28 16:23:24
Marjorie
My once-a-day unattended-upgrades (security fixes only) picked this up 2:52 GMT yesterday.
Must have been bad - they seems to have pushed it out to the downstream repos (I'm on stable) damn fast.
#5 2021-01-28 16:30:38
Why not just use sudoedit? Oh no, wait... roll
Marjorie wrote:
they seems to have pushed it out to the downstream repos [...] damn fast
Yeah, the Security Team rocks :-)
https://security-tracker.debian.org/tra … -2021-3156
#6 2021-01-28 16:48:15
dice
Well if one does not want to use sudo, they could edit a file that way using su.
#7 2021-01-29 09:11:36
On Hyperbola I use doas, surprised more distros within linux haven't started using it yet.
#8 2021-01-29 13:17:19
yeti
Did you check it for having "CVE-2019-25016 (Unsafe, incomplete PATH reset)" fixed?
#9 2021-01-29 15:44:45
mckaygerhard
sudo is a sh*t that makes a linux box acts like a windo one! puff .. is has a larrge history of several security holes, i mean several security interestelar black holes.. in fact
#10 2021-01-29 18:23:38
Alpine Linux updated to v6.8.1 within an hour of the upstream release :-)
#11 2021-01-29 21:42:14
If I had to guess, I think Hyperbola has fixed that already...
But curiously, when did get discovered?
If it was a year or two ago, for sure.
by for sure, I mean its been solved most likely.
#12 2021-01-29 21:49:48
Yesterday.
EDIT: the fixed version is 6.8.1.
EDIT2: it looks like the doas package in Hyperbola is orphaned and stuck on an old version (6.6.1).
#13 2021-01-30 10:05:58
Yesterday.
Hmm, they are doing a lot of different packaging things for 0.4 release, so it may be taking a while.  I hope 0.4 is ready soon.
#14 2021-10-05 09:55:59
superurmel
Affected version
Solution
Hi. I don't understand. I do check for updates regulary. My version von sudo is:
~ % apt list sudo -a
Auflistung... Fertig
sudo/stable,stable-security,now 1.8.27-1+deb10u3 amd64  [installiert]
sudo/stable,stable-security 1.8.27-1+deb10u3 i386
And I'm on Devuan 3.1.
My sources-list:
## package repositories
deb http://deb.devuan.org/merged beowulf main contrib non-free
deb http://deb.devuan.org/merged beowulf-updates main contrib non-free
deb http://deb.devuan.org/merged beowulf-security main contrib non-free
deb http://deb.devuan.org/merged beowulf-backports main contrib non-free
What is it I do not understand?
Do I something wroing?
#15 2021-10-05 10:00:15
ah, It's in testing and daedalus  1.9.5p2-3 amd64 [installed,automatic]
glenn@asus-r552jv:~$ su
Password:
root@asus-r552jv:~# apt list sudo -a
Listing... Done
sudo/testing,testing,daedalus,now 1.9.5p2-3 amd64 [installed,automatic]
sudo/stable 1.8.27-1+deb10u3 amd64
root@asus-r552jv:~#
hope this helps.
#16 2021-10-05 10:20:49
superurmel
Thanks for the reply GlennW
hope this helps.
It still confuses me. I thought that, because I'm on stable, I should get security patches.
As I have sudo version 1.8.27-1+deb10u3, I think I still have the vulnerable version.
Affected version
I'm confused hmm
SOLVED:
Ok, after a little search on debian.org if found out that the version I have (1.8.27-1+deb10u3) is fixed!
I have the fixed version (https://www.debian.org/security/2021/dsa-4839) but still the behavior described on https://haxf4rall.com/2021/01/27/cve-20 … ity-alert/.
#17 2021-10-05 21:01:47
Now I'm confused. And I don't use sudo or would have it installed if I could arrange it.
Using the example above... I get
glenn@asus-r552jv:~$ sudoedit -s /
usage: sudoedit [-AknS] [-r role] [-t type] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] file ...
But checking with apt install... I get
root@asus-r552jv:~# apt install sudo
sudo is already the newest version (1.9.5p2-3).
sudo set to manually installed.
I'd get rid of it (sudo), but it is tied to too many other programs...
root@asus-r552jv:~# apt remove sudo
  bluedevil breeze-gtk-theme bup bup-doc gtk2-engines-pixbuf ibus-data ieee-data kde-cli-tools-data kde-config-gtk-style kde-config-sddm kde-style-oxygen-qt5 kgamma5
  khotkeys khotkeys-data kinfocenter kmenuedit ksysguard ksysguard-data kup-backup kwrited libgsettings-qt1 libibus-1.0-5 libkf5su-data libkf5sysguard-bin
  libkpmcore11 libksignalplotter9 liboxygenstyle5-5 liboxygenstyleconfig5-5 libqt5sensors5 libscim8v5 libxcb-record0 oxygen-sounds par2 partitionmanager
  plasma-desktop-data plasma-disks plasma-pa pulseaudio-module-gsettings python3-fuse python3-pylibacl python3-tornado qml-module-gsettings1.0
  qml-module-org-kde-activities qml-module-org-kde-kcm qml-module-org-kde-kio qml-module-org-kde-kitemmodels smartmontools systemsettings xsettingsd
Use 'apt autoremove' to remove them.
  kde-cli-tools kde-plasma-desktop kscreen libkf5su-bin libkf5su5 plasma-desktop sudo
0 upgraded, 0 newly installed, 7 to remove and 3 not upgraded.
After this operation, 12.4 MB disk space will be freed.
Do you want to continue? [Y/n] n
Abort.
That "apt autoremove" list is for after sudo is removed.
Anyhow... I still won't use it. I'm sure I removed the config files from /etc/...
#18 2021-10-05 23:24:51
dvnUsr
@H_O_A_S/@zapper:  Thanks for the tip about doas.
I note it can be installed from the repository (http://deb.devuan.org/merged chimaera/main amd64 Packages).
Tried it, but the one thing I need is its "persist" functionality, which doesn't work for me; here's my /etc/doas.conf contents:
permit persist <my-username> as root
doas runs fine but *always* asks me for the password.
I understand persist doesn't work because the package must have been compiled without first enabling persist.  I assume it comes directly from Debian ... https://bugs.debian.org/cgi-bin/bugrepo … bug=983505
#19 2021-10-06 00:42:12
dvnUsr
Oho, just discovered that:
doas -s
is a handy workaround while persist is not working.
I've uninstalled sudo.  (There were no dependencies in my installation.)
#20 2021-10-06 05:18:05
superurmel
My bad. I used the command wrong.
~ % sudoedit -s/
sudoedit: Ungültige Option -- /
usage: sudoedit [-AknS] [-r role] [-t type] [-C num] [-g group] [-h host] [-p
                prompt] [-T timeout] [-u user] file ...
I also get this
~ % sudoedit -s /
I will give doas a try.
#21 2021-10-07 00:13:34
Thanks for letting me know, I thought I must be doing something wrong... But, good to know.
ahahaha. relief!
#22 2021-10-07 13:03:46
hevidevi
you can also program in completions for doas if you are so inclined.
a few examples i found here https://git.xosc.org/config/tree/.kshrc
# COMPLETIONS
# Mostly copied from
# https://github.com/qbit/dotfiles/blob/master/common/dot_ksh_completions
if [ -d ~/.password-store ]; then
	PASS_LIST=$(
		cd ~/.password-store
		find . -type f -name \*.gpg | sed 's/^\.\///' | sed 's/\.gpg$//g'
	set -A complete_tpm_1 -- $PASS_LIST usage
	set -A complete_tpm_2 -- $PASS_LIST edit insert show rm
fi
set -A complete_kill_1 -- -9 -HUP -INFO -KILL -TERM
set -A complete_ifconfig_1 -- $(ifconfig | grep ^[a-z] | cut -d: -f1)
if [ -d /var/db/pkg ]; then
	PKG_LIST=$(/bin/ls -1 /var/db/pkg)
	set -A complete_pkg_info -- $PKG_LIST
	alias dpkgdel="doas pkg_delete"
	set -A complete_dpkgdel_1 -- $PKG_LIST
fi
# relayctl completion.  Second level only for 'show'
set -A complete_relayctl_1 -- monitor show load poll reload stop redirect table host log
set -A complete_relayctl_2 -- summary hosts redirects relays routers sessions
set -A complete_unwindctl_1 -- reload log status
if [ -d /etc/rc.d ]; then
	RCD_LIST=$(/bin/ls /etc/rc.d)
	set -A complete_rcctl_1 -- get getdef set check reload restart stop start disable enable order ls
	set -A complete_rcctl_2 -- $RCD_LIST
	alias drcctl="doas rcctl"
	set -A complete_drcctl_1 -- get getdef set check reload restart stop start disable enable order ls
	set -A complete_drcctl_2 -- $RCD_LIST
fi
set -A complete_tarsnap_1 -- --list-archives --print-stats --fsck --fsck-prune --nuke --verify-config --version --checkpoint-bytes --configfile --dry-run --exclude --humanize-numbers --keyfile --totals
# /tmp/.man-list is generated upon boot by /etc/rc.local with
# find /usr/share/man/ -type f | sed -e 's/.*\///' -e 's/\.[0-9]//' | sort -u
[[ -f /tmp/.man-list ]] && set -A complete_man -- $(cat /tmp/.man-list)
[[ -d $HOME/.marks ]] && set -A complete_j -- $(/bin/ls $HOME/.marks)
#23 2022-04-17 10:00:26
czeekaj
I was suspicious and not surprised.
I don't really have this issue anymore, I don't install proprietary Nvidea drivers anymore but I've since smartened up.
But Nvidea drivers the screen would flash.
I uninstall sudo, install Nvidea driver and it didn't flash the screen.
Nvidea must of known about some way to exploit sudo. I couldn't say why or what happened but I was suspicious.
