#1 2021-01-25 20:22:28
PengouinPdt
[SOLVED] [Devuan Ceres] Dongle USB Ralink MT7601U Wireless
Hi, all
I bought few days ago a usb dongle, recognized by lsusb as:
Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
On dmesg:
[  878.416457] usb 1-1.4: reset high-speed USB device number 3 using ehci-pci
[  878.531504] mt7601u 1-1.4:1.0: ASIC revision: 76010001 MAC revision: 76010500
[  878.551495] mt7601u 1-1.4:1.0: firmware: direct-loading firmware mt7601u.bin
[  878.551504] mt7601u 1-1.4:1.0: Firmware Version: 0.1.00 Build: 7640 Build time: 201302052146____
[  878.956971] mt7601u 1-1.4:1.0: EEPROM ver:0d fae:00
[  879.183994] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[  879.184474] usbcore: registered new interface driver mt7601u
[  879.258512] mt7601u 1-1.4:1.0 wlx00e0250d7ef2: renamed from wlan0
lsmod:
$ lsmod | grep mt
mt7601u               135168  0
mac80211              983040  1 mt7601u
cfg80211              974848  2 mt7601u,mac80211
usbcore               323584  6 xhci_hcd,ehci_pci,usbhid,mt7601u,ehci_hcd,xhci_pci
module seems loaded!
ip address:
3: wlx00e0250d7ef2: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 00:e0:25:0d:7e:f2 brd ff:ff:ff:ff:ff:ff
iw show the hardware:
$ sudo iw dev wlx00e0250d7ef2 info
Interface wlx00e0250d7ef2
	ifindex 3
	wdev 0x1
	addr 00:e0:25:0d:7e:f2
	type managed
	wiphy 0
	txpower 0.00 dBm
rfkill show no block:
$ sudo rfkill list
0: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
I installed wpa_supplicant, wpa_gui… but it's not appear!
$ sudo wpa_cli -i wlx00e0250d7ef2
wpa_cli v2.9
Copyright (c) 2004-2019, Jouni Malinen <j@w1.fi> and contributors
This software may be distributed under the terms of the BSD license.
See README for more details.
Interactive mode
Could not connect to wpa_supplicant: wlx00e0250d7ef2 - re-trying
^C
How can I use this USB hardware?
#2 2021-01-25 20:29:15
Re: [SOLVED] [Devuan Ceres] Dongle USB Ralink MT7601U Wireless
It's always best to enter the error message into a search engine, here's the top result:
https://raspberrypi.stackexchange.com/q … t-wlan0-re
This is also mentioned in the ArchWiki:
https://wiki.archlinux.org/index.php/Wp … th_wpa_cli
And I'm curious as to why your interface is using the predictable nomenclature — are you using eudev?
apt policy eudev
#3 2021-01-25 22:22:32
PengouinPdt
$ apt policy eudev
eudev:
  Installé : 3.2.9-8
  Candidat : 3.2.9-8
 Table de version :
 *** 3.2.9-8 500
        500 http://deb.devuan.org/merged ceres/main amd64 Packages
        100 /var/lib/dpkg/status
Why is it so so complicated?
#4 2021-01-26 04:13:44
Type man wpa_supplicant in a terminal and have a read...
#5 2021-01-26 07:02:28
Because wpa_supplicant is generally used as a back-end for more "user-friendly" networking solutions such as NetworkManager, connman & wicd.
You can try wpagui but that will still need a basic configuration file that declares the control interface file and allows the configuration to be changed. Also note that the wpa_supplicant package does not configure the routing table (so you will need to either do that manually or run a separate DHCP client) and it does not supply a sysvinit script (so you will have to create one yourself if you want to run it without a front end).
There is iwd, which is a more modern alternative to wpa_supplicant that also has a command line interface (iwctl) but doesn't require you to create a configuration file beforehand, but that also doesn't supply a sysvinit script. It does include DHCP functionality and it has fewer dependencies than wpa_supplicant.
But I would recommend ifupdown instead: https://wiki.debian.org/WiFi/HowToUse#W … d_WPA2-PSK
#6 2021-01-26 11:11:52
PengouinPdt
Hi all.
OK, before yours replies, I set the wpa_supplicant file config.
(today, I installed too connman; wicd seems not available - it's not the problem).
When I plug the dongle USB, it receives one adress IP, but not the gateway's one.
(but, my Android smartphone receive correctly the datas, and can connect on the Internet, for instance)
It seems when I connect with the dongle USB, it not receives or configure the default route:
$ ip route
192.168.xyz.0/24 dev wlx00e0250d7ef2 proto kernel scope link src 192.168.xyz.144
When I use the ethernet wired:
$ ip route
default via 192.168.abc.1 dev eth0
192.168.abc.0/24 dev eth0 proto kernel scope link src 192.168.abc.47
192.168.abc.1 dev eth0 scope link
One idea?
#7 2021-01-26 12:10:22
dice
what is the output of the file /etc/network/interfaces
as ralph mentions you should read the manual for wpa_supplicant
#8 2021-01-26 13:55:29
PengouinPdt
wpa_supplicant.conf:
$ cat /etc/wpa_supplicant/wpa_supplicant.conf
ctrl_interface=/run/wpa_supplicant
update_config=1
network={
	id_str="sh"
	ssid="SH"
	psk=***xyz***
/etc/network/interfaces:
allow-hotplug wlx00e0250d7ef2
iface wlx00e0250d7ef2 inet dhcp
#	wpa-driver wext
#	wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
	wpa-ssid SH
	wpa-psk ***xyz***
#9 2021-01-26 14:15:53
dice
is that all you have in /etc/network/interfaces: ?
i dont believe you need the wpa-ssid and wpa-psk in /etc/wpa_supplicant/wpa_supplicant.conf if you already have them in /etc/network/interfaces ?
see head on a sticks comment from another thread on wpagui wpa_supplicant.
http://dev1galaxy.org/viewtopic.php?pid=26890#p26890
#10 2021-01-26 14:22:38
PengouinPdt
No, it's not all things!
But others lines concern iface lo and eth0. Do you want really?!
The file start with this line:
#	wpa-driver wext
	wpa-ssid SH
	wpa-psk ***xyz***
#11 2021-01-26 14:26:46
dice
#	wpa-driver wext
	wpa-ssid SH
	wpa-psk ***xyz***
well when someone tells me a story i dont want to hear just the end of it !
#12 2021-01-26 14:50:41
PengouinPdt
OK, With iwd and connman, It's run! Yeahhh.
All run correctly, on IPv4 and IPv6!
Thanks @all, but specially @HoaS wink
