#1 2021-01-25 11:46:16
martin.hodges@getmail.no
Enable middle button drag (libinput)
After a deal of de-bugging I have middle button drag on the Trackpoint middle button AND vertical scrolling on the Touchpad on my laptop. This is not simple.
1) libinput can only use udev found devices and does not seem to play nicely with other xorg pointer drivers.
2) libinput uses the same parameters by default for all mouse devices.
3) driver parameters my be placed in *.conf files in /etc/X11/xorg.conf.d/.
I have a file: 40-libinput.conf
Section "InputClass"
  Identifier "Touchpad"
  MatchDriver "libinput"
  MatchIsTouchpad "on"
  Option "Tapping" "on"
  Option "ButtonMapping" "1 0 3"
  Option "ScrollMethod" "edge"
EndSection
Section "Inputclass"
  Identifier "Trackpoint"
  MatchIsTouchpad "off"
  Option "ScrollMethod" "none"
EndSection
The key to this is the MatchIsTouchpad lines which differentiate parameters between mouse types.
The Tapping "on" is my preference.
The ButtonMapping is to disable chord emulation of middle button on the TrackPad. Again, my preference
The key to getting middle mouse drag is by disabling the ScrollMethod. The default uses middle button hold to convert mouse movement to scroll events.
That is not my e-mail address :-)
