#1 2021-01-11 09:10:15
chomwitt
Install runit in Beowulf.
Do i have to follow those instructionshttp://smarden.org/runit/replaceinit.html  or installation script will cover that?
@ devuanwiki/Chomwitt
#2 2021-01-11 10:06:00
Re: Install runit in Beowulf.
It should already be covered, if you do
sudo apt install runit runit-init
then you should be all set. smile
