#1 2020-12-27 12:25:57
dice
dd command inside script.
hi, ive got a brain freeze on this and cant firgure it out, ive done something similar awhile ago.
what i want to do is fill in the values after the command as i want to put this in a script somehow.
dd if=/dev/urandom of=$1 bs=$2 count=$3 iflag=fullblock
so $1 will be say value.img and $2 will be 100M or whatever size the img should be and lastly $3 counts $2 incrementally.
so on the command line it would look similar to this before its run.
dd if=/dev/urandom of=$1 bs=$2 count=$3 iflag=fullblock value.img 100M 1
#2 2020-12-27 12:53:15
Re: dd command inside script.
Not sure I understand your question but $1, $2 & $3 and the first, second and third arguments applied to a script. These are known as positional parameters.
Example script:
$ cat example
echo "$1" "$2" "$3"
$ ./example value.img 100M 1
value.img 100M 1
#3 2020-12-27 12:55:27
Thinking about how that will expand is making my head hurt. Wouldn't $1 = 'if=/dev/urandom'? And so on...
I like to redefine positional paramaters at the beginning of the script to give them meaningful names and to make sure I know what they really are.
outfile="$1"
blocksize="$2"
blockcount="$3"
dd if=/dev/urandom of=$outfile bs=$blocksize count=$blockcount iflag=fullblock
Then call the script with
myscript.sh value.img 100M 1
#4 2020-12-27 12:59:56
dice
Thanks both, positional parameters is what i need to learn. fsmithred, that looks like the way to go.
#5 2020-12-27 15:04:08
dice
this is the script im working on, im stuck on the dd command as its giving me  dd: invalid number: ‘test.img’  when i run
sudo ./script.sh -C test.img 10 1
This has to be run via root or sudo, could be an issue there.
Im hoping to turn those crypt_open and crypt_close functions for the .img into positional parameters somehow.
EDIT: oops i need to also figure out cryptsetup creation. Ignore this post, keep it here for learning purposes.
cryptsetup options luksFormat device.img
cryptsetup open device.img name
mkfs.fstype /dev/mapper/name
#!/bin/bash
outfile="$2"
blocksize="$3"
create () {
        dd if=/dev/urandom of=$outfile bs=$blocksize count=1 iflag=fullblock
crypt_open () {
        losetup /dev/loop0 /home/$USER/ecrypt.img
        cryptsetup open /dev/loop0 ecryptfs
        mount -t ext4 /dev/mapper/ecryptfs /home/$USER/crypt/
crypt_close () {
        umount /home/$USER/crypt
        cryptsetup close ecryptfs
        losetup -d /dev/loop0
while getopts ":ocC" opt; do
  case ${opt} in
    o ) crypt_open
    c ) crypt_close
    C ) create $2 $3
    \? ) echo "Usage: cmd [-o] [-c] [-C]"
  esac
done
EDIT2; fixed dd function for getopts
#6 2020-12-27 21:16:31
My first step would be to add:
set -x
near the start of the script. This would tell bash to display the dd command as it will be executed after variable substitution. See the man page for bash for details.
Also look at set -n which tells bash to read commands but not execute them. This could be useful to syntax check the script before letting it do anything.
Chris
#7 2020-12-27 23:19:14
If you somehow end up with more than one loop device, you might use something like this:
losetup -f > /tmp/nextloop
LOOPDEV=$(cat /tmp/nextloop)
losetup ${LOOPDEV} ${LOOP_FILENAME}
That's taken from refracta2usb which can make an encrypted loopback filesystem for live-usb persistence.
#8 2020-12-28 03:03:21
dice
thanks chris, set -x is quite helpful.
thanks fsmithred, that is exactly where i am stuck right now having two loop devices.
This not anything serious btw, just trying to learn. Think i would rather use tomb to be quite honest wink
#9 2020-12-28 09:59:47
dice
Managed to cobble this together, not in anyway portable but ill keep trying.
something interesting i found out, luks header keys takes up 16 mb of space so you cant have have a small img like 10mb.
NAME           MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINT
loop0            7:0    0    20M  0 loop
└─cryptfs      254:1    0     4M  0 crypt /home/$u/crypt
Need to look into better command structure using more positional parameters, especially with the use of the crypt.img?
Find out how to use getopts usage better.
#!/bin/bash
set -x
u="<username>"
outfile="$2"
blocksize="$3"
crypt_img () {
crypt_create () {
	losetup --find
	losetup /dev/loop0 crypt.img
	cryptsetup luksFormat crypt.img
	cryptsetup open crypt.img cryptfs
	mkfs.ext4 /dev/mapper/cryptfs
crypt_open () {
crypt_mount () {
	mount -t ext4 /dev/mapper/cryptfs /home/$u/crypt
crypt_umount () {
	umount /home/$u/crypt
	cryptsetup close cryptfs
while getopts ":iComu" opt; do
  case ${opt} in
    i ) crypt_img $2 $3
    C ) crypt_create
    o ) crypt_open
    m ) crypt_mount
    u ) crypt_umount
    \? ) echo "Usage: cmd [-i] [-C] [-o] [-m] [-u]"
  esac
done
#10 2020-12-28 12:40:25
dice wrote:
    i ) crypt_img $2 $3
I think that should be
    i) crypt_img "$@"
Otherwise $2 & $3 will be interpreted as the third and forth arguments applied to the script.
Not sure about the encryption stuff though, I don't use that.
#11 2020-12-28 13:19:24
dice
Hi fsmithred, if you see this would you say this is the right way to implement loopdev?
here is just the code to the cryptsetup commands, im yet to figure out how to use that in the main script.
#!/bin/bash
set -x
img="$2"
crypt_create () {
        losetup ${LOOPDEV} $img
        cryptsetup luksFormat $img
        cryptsetup open $img cryptfs
while getopts ":c" opt; do
    case "${opt}" in
        c ) crypt_create $2
       \? ) echo "Usage: cmd [c]"
    esac
done
seems to work although set -x throws some errors?
sudo ./ccreate.sh -c test.img
++ cat /tmp/nextloop
cat: /tmp/nextloop: No such file or directory
+ LOOPDEV=
+ img=test.img
+ getopts :c opt
+ case "${opt}" in
+ crypt_create test.img
+ losetup -f
+ losetup test.img
losetup: test.img: failed to use device: No such device
+ cryptsetup luksFormat test.img
WARNING!
This will overwrite data on test.img irrevocably.
Are you sure? (Type 'yes' in capital letters): YES
Enter passphrase for test.img:
Verify passphrase:
+ cryptsetup open test.img cryptfs
+ mkfs.ext4 /dev/mapper/cryptfs
mke2fs 1.45.6 (20-Mar-2020)
Creating filesystem with 4096 1k blocks and 1024 inodes
Allocating group tables: done
Writing inode tables: done
Creating journal (1024 blocks): done
Writing superblocks and filesystem accounting information: done
+ getopts :c opt
#12 2020-12-28 13:24:03
dice
dice wrote:
    i ) crypt_img $2 $3
    i) crypt_img "$@"
Yes that seems to work as well. Im having a hard time wrapping my head around this stuff, thanks.
#13 2020-12-28 14:42:24
You should also be quoting your variables to avoid globbing and word substitution.
https://mywiki.wooledge.org/Quotes
#14 2020-12-28 14:56:13
You got this output for the line that says losetup ${LOOPDEV} $img but there's nothing for $LOOPDEV in the output. "No such device." The error also shows up in the first lines of the output where it shows that cat failed and LOOPDEV is empty.
+ losetup test.img
I think you need to define LOOPDEV after you run 'losetup -f'.
crypt_create () {
#15 2020-12-28 15:20:51
dice
still showing two loop devices, thanks for your help though.
 ~ $ > sudo ./ccreate.sh -c test.img
+ img=test.img
+ getopts :c opt
+ case "${opt}" in
+ losetup -f
+ LOOPDEV=/dev/loop0
+ losetup /dev/loop0 test.img
WARNING!
Verify passphrase:
+ getopts :c opt
 ~ $ > lsblk
loop1            7:1    0    20M  0 loop
#!/bin/bash
set -x
img="$2"
crypt_create () {
    case "${opt}" in
        c ) crypt_create $2
    esac
done
#16 2020-12-28 18:03:32
It looks like it worked. The previous error is gone. Maybe loop1 is left from before? I think you can just delete it manually.
#17 2020-12-28 19:33:39
OalSkuul
Admin, please delete.
#18 2020-12-28 21:52:11
OalSkuul wrote:
what is it for?
See random(4). If you have any other questions then please open a new thread rather than hijack this one, thanks.
#19 2020-12-29 01:03:15
dice
that seems to be the case. Thanks again.
#20 2020-12-29 10:31:56
Thought it better to post this here rather than pollute your new thread but just to let you know that https://shellcheck.net thinks you should double-quote the variables:
Line 13:
        mkdir -p /home/${u}/${dir}
                       ^-- SC2086: Double quote to prevent globbing and word splitting.
Did you mean: (apply this, apply all SC2086)
        mkdir -p /home/"${u}"/"${dir}"
Line 19:
        dd if=/dev/urandom of=${outfile} bs=${blocksize} count=1 iflag=fullblock
        dd if=/dev/urandom of="${outfile}" bs="${blocksize}" count=1 iflag=fullblock
Line 27:
        losetup ${LOOPDEV} ${img}
        losetup "${LOOPDEV}" "${img}"
Line 28:
        cryptsetup luksFormat ${img}
        cryptsetup luksFormat "${img}"
Line 29:
        cryptsetup open ${img} ${name}
        cryptsetup open "${img}" "${name}"
Line 30:
        mkfs.ext4 /dev/mapper/${name}
        mkfs.ext4 /dev/mapper/"${name}"
Line 36:
Line 42:
        mount -t ext4 /dev/mapper/${name} /home/${u}/${dir}
        mount -t ext4 /dev/mapper/"${name}" /home/"${u}"/"${dir}"
Line 49:
        umount /home/${u}/${dir}
        umount /home/"${u}"/"${dir}"
Line 50:
        cryptsetup close ${name}
        cryptsetup close "${name}"
Oh, and I'm pleased to see that you've dropped bloaty old bash — POSIX sh ftw! :-)
#21 2020-12-29 11:56:01
dice
Thanks head on a stick, i forgot to do that. This has been a good learning experience and its good to make mistakes and learn from them. I will definitely be looking into more posix orientated scripts in the future. Updated the script as per shellcheck.
