Pages: 1
Refractux GNU/Linux is a "Devuan" "Refracta" pulseaudio free derivative that focuses on
providing common applications and services that most users will need instead of trying to provide for more specialized uses. It provides a basic desktop with simple applications that are easy to use.
The default install includes internet, graphic, multimedia, office software, various system tools and utilities
along with some "easy to use gui scripts" that i did in my spare time and a touched basic dark theme/icons.
Hundreds more applications are available from a trusted source and can be quickly and easily installed.
Screenshot of the current version + patches:
https://archive.org/details/refractuxgnulinux [this link can be outdated]
You can suggest better [Apps/Scripts/Other changes] that you want to be [fixed/replaced/added/deleted]
Thank you.
Refractux X 2020 BIOS/UEFI
System apps/System scripts:
timeshift
disk-manager
*spacefm + easy scripts
devilspie
exfat
*ventoy gui script
*zzz_idd (interactive dd)
*lshw script
gsmartcontrol
erfr
*res_spacefm gui script (restore file manager session)
Apps/Scripts:
libasound2-plugin-equal
*aconnect gui script
galculator
smplayer
Network:
*macchanger gui script
*anonymous gui script from "backbox"
tor-browser
*palemoon + privacy configuration
riot.im (element now)
Other changes:
*dark theme
*icons
Get [this section can be updated before 2021-01]:
https://mega.nz/file/B8RFBYCR#2p23JR9Qr … xHplMIWZ6s
https://mega.nz/file/ktAFnSob#VCyhvY4_J … R0YX6bV43o
password: 404
Screenshots:
01 02 03
To be fixed [this section will be deleted on 2021-01]:
*res_spacefm gui script (restore file manager session) [Patch 01]
UI [Patch 01]
README [Patch 02]
sources.list [Patch 02]
To be replaced [this section will be deleted on 2021-01]:
finalcrypt [erfr gui script] [Patch 01]
To be added [this section will be deleted on 2021-01]:
erfr gui script [Patch 01]
orage [Patch 01]
orage plugin [Patch 02]
To be deleted [this section will be deleted on 2021-01]:
finalcrypt [Patch 01]
Patch [this section will be deleted on 2021-01]:
01: https://mega.nz/file/4lpQUbba#-eA19rpna … 1dtIeRF668
password: 404
02: https://mega.nz/file/1ppBCI7Q#2MUvWYnma … 3oxxQGz8-U
password: 404
[Info] (Please,don't reply/quote this, a reply/quote to this may can cause a nonsense discussion and a permanent loss of neurons)
Review "X" if you want, but be sure to share your best idea if you have ideas to solve/improve "X".
Are you going to criticize "X"?:
-Stop if you can (you may not know what you are talking about, no one knows everything)
-Explain why and wait for someone that have ideas to solve/improve "X" (if you think you may know what you are talking about)
Interesting spin, seems you have packed in some programs that are not in the stable or testing repos.
For instance finalcrypt. The website for that program doesnt even have https enabled and the program uses java.
https://github.com/ron-from-nl/FinalCrypt
FinalCrypt - The No¹ One-Time Pad Encryption
Why FinalCrypt ?
Today's cyber espionage comes from hidden spyware waiting for you to unlock your drive. Disk Encryption no longer protects!
Even when you're logged on, unopened files have to remain encrypted. Only File Encryption stops spyware reading your files.
Also most crypto software uses broken AES or asymmetric crypto soon broken by The Shor's Algorithm with Quantum Computers.
Today's global cyber espionage can only be stopped by One-Time Pad File Encryption. That's why FinalCrypt.
Is AES broken ?
“That which is below is like that which is above, and that which is above is like that which is below, to perform the miracles of one only thing.”
-Hermes Trismegistos
dice: Is AES broken ?
im not a security professional but after reading part of this:
https://crypto.stackexchange.com/questi … is-cracked
i decided to add finalcrypt in the distribution
neither am i.
Another unique approach to file encryption in this link from stackoverflow using perl6.
https://stackoverflow.com/questions/540 … 4#54093334
and or shell level.
https://github.com/S2-/sshenc.sh/
& this is a good one time pad shell script: https://snippets.bentasker.co.uk/page-1 … -BASH.html
Thank you dice, i will see how this run in the distribution in order to replace "finalcrypt". [ ]
What a load of crap...
Black Lives Matter
dice wrote:https://github.com/S2-/sshenc.sh/
They were just some examples to think about.
There is also https://packages.debian.org/buster/otp
Generator for One Time Pads or Passwords
otp creates key and password lists for verification and security purposes in a variety of formats. Keys can be of any length, consist of digits or letters (capital or lower case), and alphabetic passwords can either be entirely random (most secure) or obey the digraph statistics of English text (easier to remember when transcribing, but less secure).For computer applications, for example one-time login passwords, otp can create a file containing the MD5 signature of each of the generated keys. This permits the computer to verify keys without the need to store the keys in plaintext.
dice wrote:Also most crypto software uses broken AES or asymmetric crypto soon broken by The Shor's Algorithm with Quantum Computers.
Today's global cyber espionage can only be stopped by One-Time Pad File Encryption. That's why FinalCrypt.What a load of crap...
That was an interesting read. So doubling the key size may effectively block quantum attacks.
I was very busy but the "Refractux X 2020 Patch 01" is online.
Screenshot list updated matching the "Refractux X 2020 Patch 01".
Just wanted to report here as well. I tried this version "Refractux", and like I have mentioned with Devuan and also Refracta OS, I couldn't get neither my Ethernet nor WiFI working on this OS with my newer AMD system. I did get a reply on the Devuan thread about the issue and that it's apparently a known issue. Just wanted to report here as well after I tried this one without success. Thank you!
https://dev1galaxy.org/viewtopic.php?pid=26463#p26463
That CPU and the wireless & internet cards are only supported by the kernel version in the beowulf-backports repository. The wireless card also needs the backported iwlwifi firmware package and the ethernet card probably needs the backported Realtek firmware package.
These are known issues and the package versions in the main beowulf repositories will never be bumped because that's not how Devuan works but thank you for your report :-)
Thank you BoneZ
Based on "Head_on_a_Stick" reply, i did a little patch that you can use to try solve your problem after install ["Refractux X 2020" iso + patch 01 + patch 02]
Refractux X 2020 Try 01 [Run as root]: https://mega.nz/file/9l4G1BBJ#5NRT92MbJ … iNz5nepv-s
password: 404
"Refractux X 2020 Patch 02" is online.
Very intresting! FYI another encryption tool is Tomb https://github.com/dyne/Tomb best GUI for it is this https://github.com/dyne/Tomb/tree/master/extras/gtomb but there is also Zulucrypt that supports a bunch of other encryption file formats. Let me know how goes and if you have suggestions how to improve!
Not reading often here, if urgent contact me via E-Mail: J @ Dyne.org
GPG fingerprint: 6113 D89C A825 C5CE DD02 C872 73B3 5DA5 4ACB 7D10
Thank you!
This needs to be fixed, at least in "Devuan" derivatives section, where you need to update/edit the info to avoid waste of space in the topic.
Saved: https://archive.is/clKAw
For now i will try to keep the info updated on the "Internet Archive": https://archive.org/details/refractuxgnulinux
Pages: 1
